Question about Samsung SCH-u740 Cellular Phone
I can't format my new micro sd card
When I try to format the new Samsung 8GB card I get an error message that only says "Format failed" That happened on both of my Samsung Alias phones. Looking at the card information shows no memory used and no memory available. I checked the card on my desktop computer and it is good. I need to get photos off these phones. Any suggestions?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
The Samsung Alias works with microSD cards. Your 8GB card is actually a microSDHC card and will not work in devices not designed to work with them. You need to use a microSD card, 2GB or smaller.
Posted on Jan 19, 2013
  • dd836
    dd836 Jan 20, 2013
    Thank you!
5 Suggested Answers
SOURCE: the 2g kingston micro sd card fails to format in
I have the same problem to beginning with. The new 2GB SD Micro card/with adapter didn't work at all. It didn't see it by window explorer. Others older once did work properly. Make sure you update your SD card reader driver to the latest version. It should be work. My did after updated the card reader driver.
Or update your all in once card reader if you have one.
Good Luck
Flyfox........
Posted on Mar 14, 2009
  • 10 Answers
SOURCE: SD Micro card- Formatting
your micro SD card may be damaged in some small way, or the card reader is a defect in it, to see which one it is,
****TRY TO BUY ANOTHER SD card, your phone can support up to a 2 GB micro SD card, if it persists, then *********** board in the phone has a defect.
Posted on Jul 18, 2009
thydzik
  • 86 Answers
SOURCE: Some memory card files wont show on samsung U900
you will need to do some fault finding here to narrow down the problem.
First on your computer turn on show hidden files and show systems files. and still confirm that there are no extra files in any of the folders that are not showing up on the phone
then create a new folder and copy a single file to that folder and confirm if the phone sees that folder and the file. If it does, then copy a file that it previously could see into that folder.
If you can't see that file still, copy a non seeing file into the folder it can see.
See what I am getting at? you need to narrow things down. Let me know how the above goes, I will further help once you reply.
Posted on Jul 19, 2009
sachin_37
SOURCE: Unable to add default folder, root directory full
after restarting the phone don't press any key until 2 minutes.
Posted on Aug 23, 2009
After i insert my 1 gb sandisk micro sd card into my blackberry 8530, an error message comes up: "cannot access media card due to fatal errors" i have tried to install, repair, and format it...
It sounds like in your situation that you may have a bad card. If you cannot get your card to mount to your phone for storage, I would try to find access to a pc that has an SD card slot that you can try to format it that way. If the card still wont format, your looking at a defective card and will need to purchase a new one.
You can find Micro SD cards here for purchase.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&Depa=0&Order=BESTMATCH&Description=micro%20sd&IsRelated=1&cm_sp=KeywordRelated-_-micro_sd_card-_-micro%20sd
Sep 22, 2011 | SanDisk 2GB microSD Memory Card
Formatting the memory card not functioning,it response "format failed try again?"but my memory card are new..
If the known sd-micro card is new and you test it in another device then, the ol' RAZR is done in. I miss my RAZR 3V
Sep 09, 2011 | Motorola Mobility RAZR V3i Cellular Phone
"the format did not complete
The memory chip inside your stick has failed, the stick is dead. Junk this and get a new one.
May 19, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I have a new 8gb Kodak SDHC and it says on my camera "Format not supported" How can I format this card?
From what I have read, the Samsung SC-X300L only supports memory cards up to 4gb. I also tried an 8gb card, with no luck.
Mar 04, 2011 | Samsung SC-X300L Micro MV Camcorder
I have an 8GB micro sd card for my blackberry storm when i put it in. It says media card has inserted contains errors. to correct the errors use a disk error-checking utility on a computer. what do i need...
The chances on any micro sd card showing errors can be either the files stored in it are corrupted or the card is simply bad already. You may try to identify the problem by performing the following steps.
1· Access micro sd card through a card reader. May it be built-in in a computer or an accessory that needs to be plugged-in to a computer.
2· Wait for a few seconds for the computer to read the micro sd card.
a· If it asked you to "open the folder to view files", do so then copy all contents in a new folder on your desktop. This is to make a backup copy of your files. Then, format the micro sd card with FAT32 format. Copy all files back to your micro sd card.
b· If it asked you to format the micro sd card, most likely all files are corrupted. Try to format the card for re-use. If not successful, your micro sd card is bad already and needs replacement.
I hope this works for you. Good Luck!
Mongkey
"Understanding explains better..."
Jan 30, 2011 | SanDisk 2GB microSD Memory Card
I just bought a new memory card (8gb) for my digital camera (Samsung NV10) and when I inserted the memory card, I kept getting "Card Error". It said I should format the new memory card and I tried to...
The largest SD card you can use in your Samsung NV10 is 2GB. thats why once you insert the 8GB sd card its shows card error or need to fromat.
FYI. for every digital camera there's a compatible memory card and you can see from the box or manual and Its writen SD or SDHC.
goodlukc and thank you
Aug 10, 2010 | Samsung NV10 Digital Camera
8gb PNY micro sd card isn't recognized in my samsung Alias
If the phone failed to format the SD card, try to format it through your computer. Connect the phone through the USB port located at the back of the tower. You'll be prompted that the PC detected 2 USB drives, the phone and the SD card. You will see it by going to My Computer folder. From there, right click the Letter drive represents the SD drive then select Format. I hope this helps.
Jun 16, 2009 | PNY 8GB Secure Digital High Capacity...
LG Cookie Won't Recognise Memory Card
it will need to be smaller then 8gb...... also micro SD......... NOT micro SDHD .....you also need to format it using the phone (check user guide for info on how to do this)
hope this works for you .....good luck
Apr 23, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Problems with formating samsung e250 micro sd card
Did you try to format the card in the device thru Windows Media Player, or Rhapsody? If so, try formatting it thru My Computer instead. My Computer>Device Name>Right Click and select format. It is most likely NOT a virus if you have only put music on the device. It is most likely a corrupt file, or a database error. Best of Luck.
Sep 12, 2007 | Cell Phones
Samsung SCH-u740 Cellular Phone Logo
197 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
