Question about Sony Handycam DCR-TRV120BT Digital Camcorder
Choppy playback from my Sony Digital 8 DCR-TRV120
I have a nearly 9-years-old Sony Digital 8 camcorder. Recently, it has been playing video back very poorly - sometimes the screen on the TV just turns blue. I had been planning on capturing all the video and putting it on my computer for conversion to DVD but haven't had a hard drive with the space for that...until now. Unfortuantely, I can not capture the video the way the playback is performing. Sometimes, it plays more cleanly than others but it seems to be on a downhill slide.
Is this a tape head problem? Is there any potential relatively low-cost action I can take to see if I can fix the problem. I don't want to have to spend a lot of money to pay someone to convert this all to DVD. And I certainly can't get rid of the years of valuable video I've shot.
I will add that a couple of years ago, we did leave the camera outside and it got rained on. I thought it was ruined but after drying out it appeared to work ok, although there are some minor glitches now.
Is there any advice on what I can try with my existing camera that might fix the playback problem?
Thanks.
  • hollyeby Apr 08, 2009
    My TRV-120 just developed the same problem and it's never experienced any abuse. Is there a device that you can plug hi8 tapes into to capture directly to my computer?
I think you are don with that camera , If you know of a friend or someone who has a similar try playing back your tapes if they do then just forget about your camera and simply replace it
Posted on Jan 26, 2009
  • bahabala Oct 29, 2010
    i bought mine off Amazon, not sure how old it really is... I have the same problem.. I've noticed tho.. if i record a bit @ the beginning of the tape, or record onto a new blank tape, the tape i wanted to watch plays back fine... other than that the audio, and frames stutter.. so now with every tape i record like 10 seconds of "whatever" to insure i have that little bit to record again to make the tape play back fine.. lol.. i hope that may help with your situation as well!
DCR-TRV530 Digital 8 . . . Problem started with tape being caught in heads. Got a 3121 error message afterward . That stopped but in video playback mode only blue screen with play arrow at top? In...
If video head got clogged then camcorder wont read tape in playback so result comes as blue screen.
Please use video head cleaning tape and clean video head of camcorder. This will solve your problem.
Video-8 head cleaning tape is available with amazon.com
Thanks.
Dec 03, 2010 | Sony Handycam DCR-TRV530 Digital Camcorder
What would cause a sony dcr trv120 zoom button not
There is control switch block that has zoom/wide switch along with play, rewind, forward, stop, pause buttons and this switch block flip up and down while ejecting/ load tape in camcorder, this will be replaced as zoom/wide switch got defective and sending continues command of zoom to system control chip.
Let me know if you need part number of switch block control for DCR-TRV120
Jul 27, 2010 | Sony Handycam DCR-TRV19 Mini DV Digital...
Sony DCR-TRV510 Playback Blank or Choppy
I recently had similar problem. Sony Phone tech support was very helpful. The answers were strange. You need to make sure the cameral is turned off, unpluged and take the battery out for at least 5 minutes. (something to do with reseting firmware). That sort of worked when coupled with there last comment which was to RECORD about 15 seconds and play it back. Mine was instantly healed!
Jan 13, 2009 | Sony Handycam DCR-TRV510 Digital Camcorder
Mode for playback of older 8mm tapes using Sony DCR-TRV730 ?
In 1990s Sony camcorder records movie in analog format so playing in digital camcorder like DCR-TRV730 doesn't mean it will be converted in digital format and you can not import file in PC for editing purpose. You will get analog signal while playing back old cassettes.
Regarding SP, LP speed, its decided at time of recording. Camera sens SP or LP automatically in playback and set itself accordingly.
If you want to convert old cassettes into digital format, connect our camcorder to DVD recorder and burn DVD which is digital format, copy DVD files in to PC and do desired editing.
Nov 24, 2008 | Sony Handycam DCR-TRV730 Digital Camcorder
Sony Handycam DCR-TRV330 Digital Camcorder: choppy hi-motion play
It very well could be a bad drum causing your problem. Be sure that the servicer you select is a Sony trained and recommended service center as they will have the latest bulletins information and training for your camcorder. I just checked on your camcorder and found this bulletin relating to your problem:
Blocking and Choppy Playback (Appears to be a dirty or defective head drum)
Symptoms / Customer Description
Blocking noise in the video during playback. Objects that were taped in motion are choppy.
[Primary Symptom Code: 1330 ]
Cause
Multiple D8 models utilizing the M2000 tape mechanism.
Cleaning the tape path has no effect on improving the symptom.
Solution
Service resolution, clean the point of contact on the video drum where the drum ground arm, ref # 804 comes into contact with the drum assy. After cleaning the point of contact, make sure the drum ground arm #804 is still touching the Head drum
assy.
(Note:After the tape path has been cleaned, the symptom in this issue will persist and lead most technicians to believe that the drum assy itself is defective. Replacing the drum assy complete will correct the problem, but it is not necessary if
the only problem is a dirty contact point on the drum assy from the ground contact.)
So you may not have a bad drum, but only a poor connection. This is why you want a Sony authorized tech to look at it. If you have any further questions, please let me know.
Nov 18, 2008 | Sony Handycam DCR-TRV330 Digital Camcorder
Playback choppy
Camera needs Tape Path adjustment and qualified camera tech person can do the job.
Nov 06, 2008 | Sony Handycam DCR-TRV265E Digital...
Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
Aug 01, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Camcorder won't playback most Hi8 tapes
may be your camera not design to play the analog tape...there are some model that can playback a analog tape...i think your camera is for digital playback only.... check your user manual
Aug 11, 2007 | Sony DCR-TRV285E Digital-8 Digital...
Hi8 playback problem
your guides have come loose , probably - the digital sound will be next to go because the bottom edge of your tapes are being folded - open the cassette tape lid by pressing the small pin near one hinge and gently lifting the door - if there are any creases ? get the guides aligned ! to protect your library ; ( if there are no creases , try a sony d8 cleaning tape - once ! before getting a repair quote ) ;
Jul 27, 2007 | Sony Handycam DCR-TRV460 Digital Camcorder
Sony Handycam DCR-TRV120BT Digital Camcorder Logo
642 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
