Question about Canon imageCLASS MF-3110 Laser Printer - Copier - Scanner Multi-Function Center, MF 3110, MF3110
Piece of paper torn inside canon mf3110, how to remove
Paper jammed, I ripped it taking it out. I can see a piece of paper inside the back when opened but dont know how to get it
SOURCE: paper jam
We had this same problem. You need the back cardboard section of a legal pad. Take out the cartridge and slide the back of the cardboard slowly into the rollers, pushing it out the end where the paper comes out. This helps push the paper jam out. You may have to do this several times slowly to get the jammed paper out. But it worked for us!
Posted on May 21, 2008
SOURCE: Paper Jam
I have just had the same problem on one of these Canon MF4150 machines.
The manufactures warranty on our machine had expired just one week before this happened so I had to fix this myself.
The problem we had (which is very likely to be the same cause as yours) is when we removed some torn jammed paper, it had somehow pulled off a spring from inside the machine. The spring was linked to the paper jam sensor.
It does involve a LOT of work to fix it, and unless you are very 'techy' it may be quite a difficult task to do this for the 'average' person.
I had to completely disassemble the machine: Take off the front first (lift up the cover and there is 2 screws at the front and 2 clips on the bottom of the machine) Then remove the 2sides and finally the top (screws should be easy to see, to get the sides off, un-clip along the front edges and gently move them outwards and slide them backwards to release the clips on the back) being careful with the wires going to the scanner part). Then look for the fuser unit which is near the top at the back, there is a black rounded cover over the fuser. To remove the cover, look for 2 small clips one at each side and unclip the cover and gently lift upwards.  Under the cover on the left side you will see a small plastic rod which goes from the left side to a small tab in the middle, if you look about half way along that rod you should see a tiny spring, make sure this is clipped on properly and that you are able to rotate the rod and it should spring back to the proper position when you let go.
Once this is done, put it all back together again and it should work fine.
I'm sure a lot of other people probably have this same problem too so I hope this helps someone.
Posted on Sep 09, 2008
  • 42 Answers
SOURCE: Canon D880 Printer/Fax
1. Take off 3 plastic covers one above exit area-slide top to left to access screw
remove lower exit cover and side cover -unsnaps with 2 pins and there is one more cover I think over the fan that needs to come off.
2.Locate black plastic sheet covering a circuit board carefully pull this back-disconnect 3 plastic connectors that lead from the heater to the circuit board
3. using a offset phillips #2 screwdriver remove 3 screws that hold the fuser to the frame. carefully lift fuser up and out toward the exit area.
4. pop off black cover remove 2 screws from top of fuser, disengage cover lid locks with a small screwdriver, lift upper fuser heater-be careful NOT to damage
plastic heater membrane. remove paper jam and reassemble.
Posted on Nov 21, 2008
ghassun
  • 499 Answers
SOURCE: canon ip4300 Error code 1300
u have to reset ur printer try to hold ur finger on power button for more than 15 sec then turn it on again
Posted on Jun 09, 2009
digitalhubz
  • 109 Answers
SOURCE: My canon MP620 Paper Jam Pull out the Jam Paper Al
There are pieces of paper stock on the sensor, when the paper jam happened then you pull out the paper did you get the whole page of the paper or have missing pieces? open the paper guide, turn off and on the printer and observe the unusual objects in the roller, this error is caused by objects in the sensor.
Posted on Oct 21, 2009
I have a paper jam on my very old canon fax machine...Canon Super G3. The paper is held up in the rollers and has torn...how can I release the rollers so that I can get the torn piece of paper...
To remove the paper jam, follow the procedure---
1. Open the front cover.
2. Remove the cartridge.
3. Open the face up cover and push down the green paper release levers on both sides of the face up paper output.
4. Hold sides of the jammed paper and carefully move it inward then gently pull out.
5. Remove if any paper bits present near the rollers.
6. Don?t pull the paper upwards but straight between the rollers.
Please check page#62 for details in the manual---
Canon Super G3 Fax
Apr 01, 2011 | Canon Office Equipment & Supplies
Paper is jammed in my HP Photosmart C3180 All-in-One. Can't figure out how to open machine to remove paper.
Follow these steps to clear the jam from the product. Step one: Remove any loose paper Remove any loose sheets of paper from the input tray and the output tray.
CAUTION: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Remove any loose paper Do not pull jammed paper c01954290.gif c01961869.gif Step two: Clear the jam from the rear of the All-in-One Follow these steps to clear the paper jam from the rear of the product.
CAUTION: Never pull jammed paper from the front of the product. Pulling paper from inside the front cover can cause mechanical damage to the product. Always access and clear paper jams through the rear access door.
  1. With the product powered on, disconnect the power cord, USB cable, and Ethernet cable from the rear of the product.
  2. Press in the tab on the rear access door to release the door. Pull the door away from the product to remove it. Figure 1: Remove the rear access doorc00703963.gif
  3. To avoid tearing jammed paper, gently grab both edges of the jammed paper, and then pull with even pressure to remove.
  4. Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product.
    CAUTION: Make sure to remove any bits of torn paper from the rollers inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure 2: Check the product for bits of torn paperc01979299.gif
  5. While you have the rear access door removed, check the rollers with your fingers. Rollers should roll freely and feel springy. If rollers are missing or do not turn freely, buy a replacement rear access door. Click here to order a replacement part from HP .
  6. Reattach the rear access door. Gently push the door toward the product until it snaps into place.
Step three: Clear the jam from the front of the All-in-One
CAUTION: Carefully remove bits of torn or jammed paper from the front of the product. If you pull too hard on jammed paper, you might damage the print mechanism.
  1. Make sure that you disconnect the power cord from the rear of the product.
  2. Open the cartridge access door. Figure 3: Open the cartridge doorc00372271.gif
  3. Gently pull out any jammed bits or torn pieces of paper from the rollers inside the product.
    CAUTION: If the paper tears when you remove it from the rollers, check the rollers for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams might occur.
  4. Close the cartridge access door.
  5. Reconnect the power cord to the rear of the product.
  6. Press the Power button (c01602202.gif ) to turn on the product.
Mar 13, 2011 | HP Photosmart C5180 All-In-One InkJet...
Paper jam in back of printer. Do not see the paper. How to get to it?
maybe a small piece is torn and stuck inside and it is not visible. if possible open the back cover and look for the paper thoroughly.
Jan 06, 2011 | Canon Office Equipment & Supplies
How to fix paper jam! problem
Clear the paper jam Followthese steps in the order presented to clear the paper jam. Step one: Remove any loose paper: Remove any loose sheets of paper from the input tray and theoutput tray. Take note: Do not remove jammed paper at this stage. Trying to clear jammed paper from the front of the product can damage the print mechanism. Step two: Clear the jam from therear of the product Take note : Never pull jammed paper from the front of the product. If you can pull it from the rear of the product or the tray, always try the rear first. Pulling paper from inside the front cover can cause mechanical damage to the product. 1. Pressthe Power button ( clip_image001.gif ) to turn off the product. 2. Disconnectthe USB cable from the rear of the product. 3. Disconnectthe power cord from the rear of the product. 4. Pressin the tab on the left side of the rear door to release the door. Remove thedoor by pulling it away from the HP All-in-One. Figure 1: Press the left side tab torelease the rear access door Gently remove any jammed paper orbits of torn paper from the rollers inside the product. Use both hands to pullout any whole sheets of paper to avoid tearing them. Take Note: Use a flashlight to thoroughly check the rollers and wheels for torn pieces of paper that might remain inside the product. If any torn pieces of paper remain inside the product, more jams are likely to occur. Figure2: Remove scraps of paper Replacethe rear access door. Gently push the door forward until it snaps into place. Step three: Clear the jam from theautomatic document feeder (ADF) 1. Openthe cover of the ADF. Figure 3: Open the cover of the ADF 1. Gentlypull the paper out of the rollers. CAUTION: If the paper tears when you are removing it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If you do not remove all the pieces of paper from the product, more paper jams are likely to occur. 2. Closethe cover of the ADF. Step four: Clear the jam from thefront of the product 1. Lookinside the product through the paper output tray to check if any loose or tornpaper is stuck in the rollers. 2. Gentlypull the paper out of the rollers. You must Remove paper from the front of the product as carefully as possible. If any torn pieces of paper remain inside the product, more paper jams are likely to occur, and this could damage the print mechanism. Use a flashlight to make sure that you find all traces of paper. 3. Reconnectthe power cord to the rear of the product. 4. Pressthe Power button (clip_image001.gif ) to turn on the product. Step five: Print a self-test report Printa self-test report. Please inform me if this help you with the paper jamproblem.
Nov 22, 2010 | HP J3680 Officejet All In One Printer
Paper jammed message won't go away
Presumably this error follows an actual paper jam (whether the culprit has admitted it or not). The following is general advice that applies to paper jams in most printers, copiers, etc.
In my experience at least 98% of paper jam errors are because a piece of paper is still caught inside the printer. The remainder are generally due to a damaged paper jam detector (usually a small plastic arm which actuates a switch inside the printer) or less commonly a failure on the PC board which senses paper jams.
Please return to point 1 and look (again) for a piece of paper jammed in the printer. If the jammed paper was torn from the printer, only a small remnant has to remain inside the printer to generate an unclearable paper jam error.
Switch off the printer at the wall and unplug it. Remove the paper tray from the printer. Check to see if the printer has an access door in the rear to allow you to see inside (open it). Open any other external flaps (eg. manual paper feed tray) that will allow you to see inside. Open any internal flaps or levers designed for user operation and usually indicated with a green or orange coloured tab. Occasionally a page can wrap completely around a roller and be very hard to see. Be very suspicious of any 'white' roller' - check at the ends to note if the roller is actually a different colour with a complete page wrapped around it (generally then only removable by tearing other than complete disassembly by a professional). If paper was torn you may need a pair of tweezers and some determination to remove any small paper pieces wedged inside the printer. Ensure the printer is unplugged from the wall and avoid damaging any rollers or other parts inside the printer. Always remove jammed paper by pulling it in the direction of normal travel only. On rare occasions very serious paper jams may need expert service to dismantle and reassemble the printer.
After finding and removing all paper pieces, return all levers, flaps, doors, paper trays etc to original positions, reconnect power to the printer and test.
Mar 05, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Error message 6a80 mx700 printer canon what is this?
Hello
Ok, the error code you are getting refers to a paper jam, which the paper is usually torn from the big piece and stuck, you need to have a good lok to find it.
Most probably the paper was ripped inside, and one piece is stuck somewhere on a sensor. Usualy is the purge unit that clean up the print head, and it's located inside on the right side (printhead parking place).
Take a torch, lift up the scanner unit, with the unit ON, wait for the print head to come in the middle, move it to left to make more room, and check the right side, inside the unit.
Kind regards
Andrea
Dec 13, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon mf3110 does not pick up paper
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Aug 22, 2009 | Canon MF3110 All-In-One Laser Printer
Canon MF4370 Paper jam
Ok fine and it is simple: trying blowing using portable blower concentrate in the area of paper parth.If this does not solve your problem attempt to remove all covers and ensure that all shutters of the paper sensors are working ok and in place.(paper parth areas)
Jul 27, 2009 | Canon imageCLASS MF4370 Black and White...
Paper jam
Remove the toner, and try to gently pull out the paper jam.. If the page gets torn, or ripped, make sure you have all the pieces of the paper removed. Then re-start the printer. Print a test page to make sure the paper path is clear..
Nov 21, 2008 | HP LaserJet 4L Printer
Canon imageCLASS MF-3110 Laser Printer - Copier - Scanner Multi-Function Center, MF 3110, MF3110 Logo
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
