Question about E-Machines eMachines Desktop PC
E-Machine T6216 PSU fan runs, computer will not boot
When I press the power button, the fan runs super-fast constantly, nothing on monitor (as if no connection, tried different monitors), CD-ROM and HDD lights stay on steady. [here's a little history] A few months ago, machine would have same problem randomly while in use. It seemed that if you let it sit for 10-15 minutes, everything would be back to normal and problem wouldn't occur for days or weeks. Problem got more severe, thought it was a temperature or temperature sensor problem. Opened case and blew out dust and reseated processor and RAM, problem disappeared for about 6 months. Mother-in-law blew circuit breaker with space heater, blow dryer, TV and other random things, that's when the computer starting to refuse to start with fan running high.
  • 1 more comment
  • juanpenasdur Feb 12, 2009
    e-machine D3315, no video, only fan on high. Disconnected all peripherals and still the same thing, I strongly believe is the motherboard, but i will verify the PS first and let you know..
  • Klassactguy Mar 23, 2009
    I have the same issue. I have replaced power supplies already and also swapped memory and only used one at a time. and still no luck, any other suggestions.
  • frankanaya3 Apr 28, 2009
    I have the same problem with emachine D3315. no video and fan unning on high. Any suggestions?
    Sergeant:
  • 306 Answers
It is the power supply. EMachines have a long history of using cheap power supplies. I have replaced over a dozen EMachine power supplies with a 100% success rate. They are easy to replace and can be had for less than $20. Just write down the model number and take that to a computer parts store or remove the power supply and take that with you. Steve
Posted on Jan 27, 2009
  • 27 Answers
Have you tried buying new ram because if you have 2 or 3 or four you computer can see both but not accept one of them. due to shock or damage. You could also try to take the ram out take a eraser from a pensil and rub as if you were trying to erase something but only do this on the teeth both sides. also try swithching the ram in different plases. or take one out then power on. if no change try the other. if still no change you could need new ram. you can also check the 2 connecttions to you motherboard.Try those if still fail let me know what other mods you have added such as video card sound card ect.
Posted on Jan 26, 2009
Its definitely not the power supply. Usually its the video card. If it is built in then you may need to get another one to plug into a pci-e or agp slot. If you already have one of these then its gone bad. Sometimes they get hot and just burn out. Sometimes they take the mother board with them.
Posted on Aug 05, 2009
2 Suggested Answers
rtrahan
  • 741 Answers
SOURCE: E-Machine T6216 PSU fan runs, computer will not boot
Giving the fact that your fan is constantly running and you had an electrical spike you should take it in to be looked at. If it overheats then the motherboard will go and it will cost more to fix it than to buy a new one.
Don't forget to rate this solution before you log off.
Hp P6000 fans stop after 15 seconds. Hard drive light stays on. nothing on monitor
dead PC, DESKTOP PC ,as old as 2009.
the fans tells you the PSU shut off, for cause.
fans, so you saw all fans turn off or just 1. or 2 of 3.
my pc has 4 fans many have 3;
CPU fan stops ,cpu overheats , PC goes slow or dead. clean the lint off it.
GPU fan , video goes dead. if it overheats.
PSU fan is inside the PSU if it goes bad, PSU is bad.
no monitor stated, is it CRT or LCD is it 15 years old.
if the monitor is 2002 or newer the OSD screen works
even with PC turned off, press the select button see that OSD screen ? telling you the monitor is not dead in 1second flat;
i caN NOT understand why the HDD lamp glows,
if the PSU shuts off , most LEDs go dead, on my PC
the standby LED on the MOBO glows, unless you pull the PSU power cord.
your HP PC came with 9 different mobo, during its production run.
at least. so answers come harder from that reason.
here are some simple tests.
test 1
power on, hear fans run
does the DVD drive (or cd) button eject work,.?
do all fans not just 1 or 2 worK? look for all fans clean the lent out
or things will overheat,
PSU can be bench tested or in the PC case.
using a jumper wire, even the HP service manual covers that.
power on the PC (after keeping monitor on for 5 full minutes)
test 2
the Screen must say, "hit ESC key to enter HP setup" BIOS.
press the ESC key on the monitor
if no text shows up that is a dead PC< "text above missing{"
if the PC told you to hit another key do so.
The ESC key , activates the BIOS brain. this cause
all those pages to work as seen in your service manual;.
if BIOS is dead that is a bad PSU (monitor ok)
or CPU is overheated.
bad ram, take all sticks out and test 1 by 1, ask how. !
The PSU will shut down on up to 12 or more faults
but never shuts down the standby power bus. unless AC line pulled.
IF the PSU has fan as most do this is the first place I look.
try this guide
https://support.hp.com/us-en/document/bph06788
Jul 08, 2017 | HP Computers & Internet
Compaq FS7600 Computer not turning on
what tower? model, the monitor has nothing to do with power and dead fans in the tower.
'Sounds, (and silent to) means the PLUS in the PC is dead.
all things can be repaired, that is what technicians do.
here is the chain of events, ! to get noise (fans)
power in the wall 120vac , usa
power to the PSU,
the power button goes to the MOBO, and standby power is there
now and pushing said button the MOBO commands the PSU on
if the PSU is happy (PWROK) thinks PSU IS safe the PSU tells the PC its ok, and power stays up.
and fans run.
so my guess bad PSU, its easy to test with anyf $10 voltmeter,
ask.
tower PSU, 101
http://pcdied.com/power.html
May 21, 2017 | HP Compaq FS7600 17" CRT Monitor
Dell Dimension E510 Wont Boot up. PSU is working 100% CPU is working 100% Ram is working 100% Disconnected all other hardware. No Power On Light. Light on Motherboard is green. Once you plug in the PSU...
Hi
With that scenario i would recommend you check the front panel assembly where the power button is located and also have you tried to reset the CMOS from the motherboard.
Dec 29, 2010 | Dell Dimension E510 PC Desktop
Computer does not display any boot screen, although it turns on. no USB ports work, not do any other inputs on the rear of the machine. this was done after migration of parts to a new case for the...
DC5000MT (i think you left off the"T" right?) MT=mini-tower then.
they at SFF then too.
old old desktop pentium 4, with pata hard drive?
no monitor stated, make nor model #
no vga card stated.
migrating? oops.. why do that? nor if PC ran before?
NO OS stated,? windows XP what? (it came with XP)
ok the mobo turns on with case power button?
and the CPU fan spins fast, as does PSU fan?
what does USB ports mean>? using what there?
PS/2 keyboard. using that? or pS2/mouse?
does it beep:?
are you sure the monitor is ok?
if monitor is ok ?
and PSU and 1 stick of ram is ok
the BIOS screens work.
or the PSU
does this mobo have onboard VGA jack GPU:>
if yes, try both it and PCI video card.
and 1 stick of ram at a time. slot1, bank 0
Aug 12, 2017 | HP DC5000M PC Desktop
My T6216 Emachine stopped working. None of the
Even if those things power up doesn't mean your PSU is still good.
In particular the PSU in eMachines are known to be cheap/bad and one of the first things to go out.
If you have access to one try another ATX power supply.
You don't have to remove the old one just to test.
1) Unplug the existing PSU power cable from the back.
2) Remove all it's connections (MB, drives, etc).
3) Plug the other PSU in with just the two MB connections (the main, and 12v one), skipping any drives for now.
It's probably ok if the test one is not touching, but I like to put the PC on the side with the test PSU setting on top where the original one is making sure it has good contact with the case to make sure it's grounded.
4) Now plug the AC into the test PSU and power it up.
If it still dosn't power up it's probably MB, or CPU.
You could also unplug it again (you always want to unplug the PSU when doing anything, the power is always on), and try removing any add on cards (like your wireless card), and try again.
If it does power up (you get a POST screen), unplug PSU again, now plug-in drives, then AC back and see if it will boot up.
Jul 20, 2010 | E-Machines T6216 (827103077834) PC Desktop
When I turn it on, only the fans run. I cannot hear the hard drive run and the hard drive light on the bezel is solid yellow
look on bios to see if detects the hard drive ...if does not boot to windows...the hard disk has no reason to go on ....and the issues could be many ....check the Ram memory if do not appear anything on screen at all ...and just runs the coolers and clicks without boot at all...in this case its the Ram memory ...so check it ...get it out ..put it back ...and remove the bios battery to force it see them again .....if it is booting until the operating system should appear ...and after that nothing ...reinstall ...
Also .....if there is anything written on the screen ..read carefully ..usually it will say whats wrong ...and advise in same issues..like replace hdd ...or files missing ...or blue screen error from memory issues..
Nov 07, 2009 | E-Machines T6216 (827103077834) PC Desktop
Computer won't boot up.
If you don't hear anything on bootup then it is most likely the power supply and you can purchase one from your local Best Buy Comp USA type store. It is very easy to replace if you have repair/troubleshooting skills. I can elaborate if you want to give it a try but it sounds like the power supply that is bad.
Hope this helps,
TankMurdock
Apr 24, 2009 | eMachines T3406 PC Desktop
Jan 26, 2009 | Computers & Internet
E-Machines eMachines Desktop PC Logo
1,889 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
