Question about Nordic Track Exercise & Fitness
F63 SOLE TREADMILL SCREEN LED FADING
The led lights on my sole treadmill screen are fading. You can see most of the stats, but some are hard to read due to lights being out. Thanks, Dayna
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
1) replace the batteries by new ones, with the same type, and polarity
clean the contacts batteries v. well
2) tight the ribbon cable from keypad , clean it and tight the connector.
3) Adjust the REED SWITC H, see the diagram attached. clean it. test for open or faulty. Tight the conector very well.God bless youF63 SOLE TREADMILL SCREEN LED FADING - 1_19_2013_4_55_39_pm.gifG
Posted on Jan 19, 2013
3 Suggested Answers
  • 33 Answers
SOURCE: my sole f63 treadmill shows an elevation error and
pls do re-calibration
Posted on Dec 11, 2010
ercupa190
  • 12223 Answers
SOURCE: F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Dec 01, 2011
Sole f63 e4 error why
If you wish to get some details about treadmill error codes; check the site linked here. http://electro-medical.blogspot.com/
Nov 07, 2016 | Sole Fitness F63 Treadmill
Just bought sole f63 runs data press start nothinges e4 is displayed then not happy
If you wish to get some details about treadmill repair and error codes ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
My sole F63 treadmill is stuck up in the storage state. I tried to use the yellow lever and it isn't lowering and I can not use it!
Lift the treadmill slightly to take pressure off of the locking pin as you work the release lever.
Oct 08, 2014 | Sole Fitness F63 Treadmill
Sole f63 error codes
Make sure the safety key is clean and not corroded . Check connections on lower board.
Aug 07, 2014 | Sole Fitness F63 Treadmill
Sole F63 treadmill controls won't work
Stuck button or bad hand switch. Remove covers between hand rails and console disconnect both hand switches should fix it.
Jul 06, 2014 | Sole Fitness F63 Treadmill
Why wont my sole f63 treadmill incline?
Are you getting a reading on the display? Are you getting a incline error?
May 09, 2014 | Sole Fitness F63 Treadmill
The belt on my Sole F63 will not turn
It sounds like you have a blown motor controller. If your machine is older than 5 years then that's pretty normal for sole. Their belts don't last very long and they cause stress on the controller. You'll have to replace the motor controller and the walking belt.
Aug 05, 2017 | Sole Fitness F63 Treadmill
My Sole F63 will slow down a few seconds after I start it then I get a low speed displayed on my control panel
please LUBE the deck belt+ rollers bearings too. You must do it evey 150 miles apros. This happen because the lack of maintenance schedule.
God bless you
Jan 21, 2013 | Sole Fitness Sole F63 Treadmill
My sole f63 wont fit through the door, how can i take it apart?
see the video attached and proceed according. God bless you
Other alternative is your read the instr. manual and follow the section how to assembly or disassembly your treadmills.
Dec 06, 2012 | Sole Fitness F63 Treadmill
Exercise & Fitness Logo
147 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
