Question about LG Televison & Video
LG flatscreen tv, volume on max 100 but can hardly hear it
Volume on max 100 but can hardly hear it
SOURCE: Vizio Volume Control
I am sure you did this but recheck your audio menu on all your inputs. I have found that cables can go bad so make sure they are in good shape. Are you haveing the problems with all your inputs dvd, cable (direct cable or a cable box) whatever? It is hard to affect the audio by just moving the set. I am hoping that you changed something or the cables went bad that would be the easy solution.
Good Luck!
Posted on Aug 08, 2008
jerryg50
  • 1689 Answers
SOURCE: LG TV 32LB9D VOLUME STUCK AT 100, NO RESPONSE TO REMOTES
The fault may be on the control board. Sometimes the button switches can be stuck, or there may be something causing some conduction on the control circuit board. It is also possible to have a component failure that is causing a continuous command to keep the volume to the high position.
Something that causes failures of controls in TV sets is when people clean the screen, they spray liquid cleaner on the screen. Some of it drips down in to the controls and on to the circuit board. This will usually cause damage, and thus the set will require shop service.
Jerry G.
Posted on Apr 10, 2009
SOURCE: Low volume on LG HDTV
I encountered the same thing using the HDMI interface on my new TWC cable box (Motorola DCX-3200). After a little bit of research, I finally fixed it by changing the digital audio mode in the cable box using this procedure:
1. Be sure the TV is on and connected to the cable box.
2. Using the cable box remote turn power OFF.
3. Immediately press the MENU key on the remote. The USER SETTINGS menu should appear on the TV screen.
4. Select the ADDITIONAL HDMI SETTINGS >>> menu item.
5. The ADDITIONAL HDMI SETTINGS menu will appear.
6. Scroll to the AUDIO OUTPUT item and select this.
7. Change the setting from AUTO to L-PCM.
8. Return to the main page
9. Using the remote, cycle power OFF.
10. When the cable box is turned on again, you should be good to go.
I realize these instructions are specific to the DCX-3200, but there may be a similar setup option available in your cable box as well.
The problem here is that the cable box is by default configured to use Dolby Digital audio, which requires an additional 10dB of headroom to deal with the boosted LFE channel. If the cable operator hasn't taken pains to set the system up correctly (and most haven't, apparently), the digital audio level sent on the HDMI interface will be approximately 11dB down from normal analog line levels on the HDTV channels. Changing to straight linear PCM sets the TV receiver audio level on the HDTV channels to match the levels on the non-HD channels.
The only problem with this fix is that if you intend to feed a Home Theater receiver that uses Dolby Digital processing with the cable box output you will lose the Dolby encoding feature and be forced into straight 2-channel stereo. For a simple installation like mine where I'm just feeding the TV, this fix works fine. If you have a more complex setup that takes advantage of Dolby Digital features (when it's available in program material), you may have to live with the problem.
For a technical reference on why this happens, see http://www.megahz.com/specimages/Dolby/LM100%20Cable%20App%20Note%2011-05.pdf
Hope this is useful.
Posted on May 22, 2009
vinnyq
  • 157 Answers
SOURCE: why does my lg tv vibrate as i turn the volume up?
This is a inherent problem in the LG 7 series LCD. It is because of poor padding in between the speaker and the bezel along with a very thing back that causes the TV to vibrate at certain frequencies and volumes. LG is aware of this issue and has new speaker brackets and spaces that will fix the issue. You can contact them and explain your situation if they can send a service center out to fix the issue under warranty as it is less than a year old. If you cannot get it covered, it should still be a cheap repair as the parts should only cost around $20 and take less than one hour of labor for a technician familiar with the issue.
Posted on Oct 09, 2009
SOURCE: My Vizio Tv volume does not work properly. When
Okay I just called and found this out. I have the 32 inch vizio hd flat screen. My problem with weak and fluctuating volume, was that I have a cable box. Go into menu, then audio and under the advanced audio section you will see srs trusurround HD and srs trusurround. Basically this function automatically adjusts volume levels for satelites and whatnot. But because cable boxes automatically have this feature you could just turn off the srs trusurround. Hopefully that should help you.
Posted on Jun 29, 2010
My sound is not loud enough on my rca 9" dual core tablet model"RCT6691W3, and volume is on max
Some devices just suck at audio. I have a Lenovo laptop that does the same. Bad onboard speakers require external speakers to produce suitable sound level.
Feb 22, 2015 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
LG 15LW1R audio is weakening
I found with mine that the volume of the LG is dependent upon the volume setting of the main source TV. Set the volume for the source TV louder and the LG should respond accordingly. Maybe it's just the way I have it hooked up (and maybe yours is the same)... YMMV
Mar 31, 2013 | LG 15LW1R 15 in. LCD Television
Have to turn the tv up to 100 to hear but it works fine when playing a dvd
When your watching tv you must be using a cable box or a pvr that has it's own volume control. Make sure it's volume is at it's max and then use only the volume of the tv.
Jul 06, 2011 | Daewoo Televison & Video
Ringer is set at max but is hard to hear
If the ringout volume is very low, then try not to select a soft, silent or low ringing tone. Try to choose a ringing tone that is loud so that you can hear your phone ringout.
Hope that was helpful?
Mar 18, 2011 | One Touch Jitterbug One-Touch Cellular...
Very low sound volume
1. In bottom right of your taskbar is an icon of a small speaker, click on that and make sure the slider bar is at 100%.
2. Click the windows button in lower left corner and then click on control panel. Then click Hardware and Sound, then click adjust system volume and make sure those are at max volume and not muted.
3. Depending on your system there may be software that installed to manage your sound card or onboard sound, if there is usually there will be an icon representing it on the lower right of your taskbar. Open that and make sure sound levels are set to max and not muted as well.
4. Make sure you plugged the speakers into the right jack in the back, sometimes when plugged into the wrong hole you can faintly hear sound but thats it, USUALLY its the light green jack you want but that can vary (some sound card/connections will have small icons by each of the colored jacks as well though they are usually faint and kinda hard to see...they can help make sure speakers are plugged into the right spot)
5. Its possible your speakers are just old or defective and simply need replaced.
Feb 18, 2011 | Computers & Internet
NO SOUND OUT OF RECIEVER, TURN VOLUME TO MAX AND CAN HARDLY HEAR ANYTHING
TURN THE VOUME CONTROL DOWN TO SOMETHING REASONABLE. MAX VOLUME IS ONLY USED TO DESTROY SPEAKERS.
Unmute it, de-select Tape Monitor, de-select M.Input.
http://www.retrevo.com/support/Kenwood-1060VR-Receivers-manual/id/478ci953/t/2/
Jan 27, 2011 | Kenwood 1060VR Receiver
Televison & Video Logo
223 people viewed this question
Computer Repairing
Computer Repairing
