Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Probleme Plasma Philips 37FD9944/01S - Mitsubishi WS-65513 65" Rear Projection HDTV
My Plasma 42FD9954 42 TV doesnt work
Familiar problem on Philips Plasma units. PSU or Sustain board failing.
Jan 16, 2013 | Philips 42FD9954 42 in. Plasma HDTV
Philips plasma service manual
Look for service manuals and schematic diagrams for Philips Plasma for troubleshooting and maintenance here
http://myfixbase.com/service_manuals/philips/plasma.html
Sep 07, 2012 | Philips 50PF9731D 50" Plasma HDTV w/ Pixel...
Philips tv plasma
What is the problem with your Philips Plasma?
Visit this site for more details. The site name is 'Electro-help'. Type in "electronicshelponline.blogspot" to your browsers search box, and click search. There are so many posts related to Plasma TV problems and repair. This is a blogspot site, in English language. Sometimes, ads related with each post might help you to get details about the availability of spare parts and price.
Jun 27, 2012 | Philips Televison & Video
I have a 50" plasma Philips tv 50pfp5332d/37 it
Most Common problem is Bad Capacitors on the power supply board, they will be vented or swollen on Top. 1000uf 16v 2200uf 10v 3300uf 10v
Jun 25, 2011 | Philips 50PF7321D 50 in. Plasma HDTV
I have 42 plasma tv that makes a clicking noise then show 8 blinking red lights anyone now whats the problems my model # 42pf9431d/37
I don't have a fix, but the same thing happened to my Philips Plasma and the V repair man tells me that Philips no longer make the service pack which contained all the parts required to fix the TV. Basically Plasma screens run very hot and the components on the main board breakdown. So when the power supply goes so do many other parts. Philips used to supply all the bits in a service pack so it would seem that they (Philips) knew all about this inevitable fault from early production.
I am livid and if you paid what I paid then you are probably livid too. I expected it to breakdown one day but I never thought that it would be impossible to fix. I would never have bought a plasma if I knew it was considered to be a disposable item by the manufacturer. It could be worse, apparently Samsung don't support their TV's after 2 years.
I am phoning Philips in the morning and will post the results of that call if they have anything positive to say.
Dec 09, 2009 | Philips 42PF9630A 42 in. Plasma Television
2003 philips 50" plasma tv with picture fading. How do I fix this?
Hi,my philips plasma 50FD9934 dont turn on just led flasing red and green contniusly.Please help!!!!This is a power suply problem?thanks
Nov 14, 2009 | Philips 50FD9934 50 in. Plasma Television
Philips Plasma won't upgrade firmware.
You need to copy the autorun.upg file from the sub folder to the root directory of the zip drive. I had the same problem and it worked after I did this.
Nov 05, 2009 | Philips 42PF9631D 42 in. Plasma Television
Phillips plasma tv. Settings menu pops up all the
Philips.com should have a software upgrade for your TV to fix the problem. This is a common problem with Philips TVs and they have made upgrade software to address the problem.
Go to the Philips web site and all the procedures for download to your TV will be there. The only thing you will need to this is a USB memory stick. Download should be FREE.
Aug 03, 2009 | Philips 42PF9630A 42 in. Plasma Television
42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
Jun 03, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Philips plasma 42pf5520d pictures has gone?
My Philips Plasma TV model 42PF7220A/37 went into "no menu exit" mode on 11/28/2007. I went to www.usasupport.philips.com and downloaded an upgrade. Just followed the instructions and my TV is all better.
Nov 21, 2007 | Philips 42PF9630A 42 in. Plasma Television
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
