Question about Dryers
Need wiring diagram for ge dryer dwsr405eb2ww
Ater replacing drive belt on dryer, tw wires came of control panel switches as i was putting back together, now machine wont start
  •  james malloy
    james malloy Jan 21, 2013
    the wires came from the timer switch , A, B, C.(the red one not sure which one it came off). and one from the start switch (small brown wire)
aborcass
  • 2651 Answers
SOURCE: wiring harness diagram
which wires popped of exactly ??? the wires from light/door switch?? grey, white, black, wires???if so thats the order top to bottom
Posted on Mar 18, 2008
TheMobilian
  • 8220 Answers
SOURCE: Wiring Diagram for GE dryer
You ain't got but two legs to connect right?
Does not matter which way you hook it. When you press the button all it does is complete the circuit. Ain't no way to screw that up.
Posted on Dec 19, 2008
godtech
  • 51 Answers
SOURCE: i need a wiring diagram for a hotpoint tumble dryer model vtd00
CALL 1-800-626-2005 ALSO CHECK THEIR WEB PAGE WWW.HOTPOINT.COM
Posted on Jan 16, 2009
ginko
  • 19396 Answers
SOURCE: I need a diagram of how to put back the dryer
See diagrams below, click on pictures to open:
Here you find all parts for dx4500.
If that was not your model , try entering model numbers below, they have the assembly diagram for almost all models:
Appliance Parts From PartSelect
Do not forget to rate the solution.
Thanks.
Posted on Feb 20, 2009
mek363
  • 18 Answers
SOURCE: I need the wiring diagram for an Asko T700 dryer.
I'll add the diagram that was inside my Asko T700 to the documents section.
Posted on Aug 16, 2009
The wiring to my hotpoint tumble dryer
You would have had to disassemble the dryer to replace the belt, so the video was correct. The door switch assembly wiring at the front of the dryer mates with a matching connector which you would have separated for cabinet removal. Don't know why you messed with control panel wiring for belt replacement but you can go to www.repairclinic.com and enter tcym 750c to see a list of common replacement parts and maybe a video showing disassembly of a generic Hotpoint dryer. You might be able to get an answer to your wiring question.
Aug 10, 2016 | Hotpoint Dryers
Tip
Whirlpool Dryer Various Test Procedures - Part 1
TEST #1 Supply Connections
This test should only be done after confirming proper voltage at the outlet.
1. Unplug dryer or disconnect power.
2. Remove the cover plate from the back of the dryer.
3. Check that the power cord is firmly connected to the dryer’s wire harness.
4. Access the machine control electronics without disconnecting any wiring to the control board.
5. With an ohmmeter, check for continuity between the neutral (N) terminal of the plug and P8-3 (white wire) on the machine control board. If there is continuity, go to step 6. If there is no continuity, disconnect the white wire of the harness from the power cord. Test the continuity of the power cord neutral wire . If an open circuit is found,
replace the power cord. Otherwise, go to step 6.
6. In a similar way, check the continuity between the L1 terminal of the plug and P9- 2 (black wire) on the control board. If there is continuity, go to step 8. If there is no continuity, check the continuity of the power cord for power cord’s L1 wire. If an open circuit is found, replace the power cord. Otherwise, go to step 7.
7. Replace the main harness.
8. Visually check that the P5 connector is inserted all the way into the machine control electronics.
9. Visually check that the user interface assembly is properly inserted into the front console.
10. If both visual checks pass, replace the user interface assembly.
11. Plug in dryer or reconnect power.
12. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
13. If indicators still do not light, the machine control electronics has failed: Unplug dryer or disconnect power.
Replace the machine control electronics. Plug in dryer or reconnect power. Perform the Console Buttons and Indicators Diagnostic test to verify repair.
TEST #2 Machine Control Power Check
This test is used to determine if power is present at the machine control electronics.
NOTE: The drum light is controlled by the machine control on all models.
2. Open the door.If the drum light illuminates, then power is present at the machine control, and it is functional. Go to TEST #6. If the drum light fails to illuminate, do not assume the machine control electronics needs replacement. Several conditions may cause the drum light not to illuminate, including a bad bulb. If the drum light does not illuminate, go to TEST #1.
TEST #3 Drive Motor Circuit
This test will check the wiring to the motor and the motor itself. The following items are part of this motor system:
Harness/connection Belt/belt switch Drive motor Centrifugal switch Door switch Machine control electronics
2. Access the machine control electronics and measure the resistance across P8-4 and P9-1.
If resistance across P8-4 and P9-1 is in the range of 1 to 6 ohms, replace the machine control electronics.
Otherwise, go to step 3.
3. Check the wiring and components in the path between these measurement points by referring to the appropriate wiring diagram and strip circuit in Section 7.
4. Check the belt switch and drive motor. Access the belt switch and drive motor by removing the front panel/drum assembly. Slowly remove the drum belt from the spring-loaded belt switch tension pulley, gently letting the belt pulley down.
5. Remove the white connector from the drive motor switch.
6. Check for the resistance values of the motor’s Main and Start winding coils. NOTE: Main and Start winding coils must be checked at the motor.WINDING RESISTANCE ω CONTACT POINTS OF MEASUREMENT
MAIN 1.4–2.6 Blue wire in back at pin 4 and bare copper wire on pin 5 of black drive motor switch
START 1.4–2.8 Blue wire in back at pin 4 and bare copper wire on pin 3 of black drive motor switch. If the resistance at the motor is correct, there is an open circuit between the motor and machine control electronics.
Check for failed belt switch. If the Start winding resistance is much greater than 4 ohms, replace the motor.
7. Check the belt switch by measuring resistance between the two blue wires while pushing up the belt switch tension pulley.If the resistance reading goes from infinity to a few ohms as pulley arm closes the switch, belt switch is OK. If not, replace the belt switch. If belt switch is OK and there is still an open circuit, check and repair the wiring harness.
8. Door switch problems can be uncovered in the Door Switch Diagnostic Test; however, if this was not done, the following can be done without applying power to the dryer. Connect an ohmmeter across P8-3 (neutral, white wire) and P8-4 (door, tan wire).With the door properly closed, the ohmmeter should indicate a closed circuit
(0–2 ohms). If not, replace the door switch assembly.
on Apr 11, 2009 | Whirlpool LER4634J Electric Dryer
Need a color coded wiring diagram of the timer M460-G for the GE electric dryer DSXH43EAOWW
All GE dryers have a wiring diagram inside the control panel on the left side as you stand in front of the dryer. It should show the wiring in black but with color coding listed for each wire. If yours is missing I will try to locate a copy. SearsPartsDirect use to have some wiring diagrams on their parts site.
Jun 03, 2015 | GE Dryers
I replaced the heating element in my dryer (GE model#DPSB620EC4WW) and am putting it back together. I am uncertain where the wires go on the control panel. There is one gey, one purple, and 2 black that...
There should be a tech envelope in the console labeled "tech data" that has the wiring diagram on it. Dig thru that envelope and you should have the termation points you need. If not I am still looking for the wiring diagram and will respond with it when located. Be patient because I may have to download a service manual.
Kelly
Aug 21, 2011 | Dryers
How to replace belt on samsung dv218ae
Hello & Welcome to FixYa
Please follow the step by step instructions for belt replacement given in this video:
Please get back to me if you have any other questions.
Kevin
Aug 07, 2011 | Samsung DV218AEW Electric Dryer
Need color coded wiring diagram to install timer switch on ge dryer model#dbxr463eg2ww asap!
what happened to the wiring diagram that was located inside of the control panel
Jul 23, 2011 | General Electric DBXR463EG Dryer
I need to replace my heating element for my dryer. The model number nvlr333etowb. how do I replace it and where is it located?
Greetings,
the first thing you do is remove the top...sometimes there is two screws going up from inside the door....or just pop the top using a putty knife.....there are two screws on each corner of front, remove these and you can set the front aside or disconnect the wiring at the door......next, you will need to remove several screws that hold the cabinet to the frame. this allows you to move the cabinet slightly to get the drum out....next, reach in and remove drive belt..pay attention how it goes before removing...ater the belt is off, you can actually slide the drum out of dryer....located on rear bulkhead is the heater. the best thing to do for you is to replace the complete pan assembly...or use a re-string kit...reverse order in putting back together
Dec 14, 2010 | GE DPSR610EGWT Electric Dryer
My Whirlpool WED8300SW stop turning yesterday. Clothes got really hot. I ran the diagnostic and got the F26 error code (motor drive failure). It is just 1 year old (about 15 months actually). I am fairly...
The standard warranty on appliances is two years, contact Whirpool at (866) 698-2538 to check warranty status.
Regarding the motor, the motor is tested by energizing it directly, and reading volts from MCU (motor control unit) or timer control board.
Here diagrams and parts for your model.
Call Whirpool first.
Aug 04, 2009 | Whirlpool WED8300S Dryer
Need to get into dryer to check heating element unit does not heat up all else seems ok model no. MDE9316AYW 5600 watts...help rubenandyolie
Check the house electrical panel dryer breakers (pair), push OFF, then ON. If breakers trip again, problem is a short inside the dryer. Pull the power plug from the socket. The top must be opened which allows access to front panel screws from inside. Lift the panel and pull away from cabinet. Disconnect the wiring to door switch and light. Make a diagram of wiring colors and where they went. Uncouple the drive belt from the motor--go through a sub-panel in the back and release a large tension spring from the idler pulley, then remove belt from motor. Remove several screws from inside of drum center, then lift the drum from the case. The heating element(s) are mounted in back of the drum on a supporting wall. Look for any burned areas or wires that touch the surrounding metal. On reassembly, check the condition of the drum belt--any cracks or missing pieces--replace the belt now.
Aug 01, 2009 | Dryers
GE DRYER WON'T TURN ON
when you changed the belt, you had to take it apart and remove the front of the dryer am I correct? If so when you put it back together did you make sure to re-connect the wires that go to the door switch? Those wires are the only ones that you should have disconnected to remove the door along with the front. See if you forgot to re-connect them ok?
Feb 17, 2009 | GE Dryers
Dryers Logo
48 people viewed this question
Top Dryers Experts
