Question about Tricity Bendix Cooker Main Oven Thermostat Switch For Dsie502gr currys
Top oven tricity bendix not working
Top hot plate not getting hot
  • 116 Answers
SOURCE: Tricity Bendix washer won't take fabric softner in rinsing cycle
Your machine possibly has a defective water inlet valve which is preventing water from entering the dispenser channel to flush the fabric softner into the machine. The inlet valve in inside of your machine right where the washer hoses attach. the solenoid valves on the inlet will need to be checked with a multimeter to verify if they are working properly.
Posted on Mar 11, 2007
  • 38 Answers
SOURCE: Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Posted on Aug 26, 2007
SOURCE: tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
Posted on Feb 26, 2008
ginko
  • 19396 Answers
SOURCE: tricity bendix dh101 wont empty
Check the drain hose and the drain lines, if you find no obstructions, then you have a defective drain pump.
If you find no problem with the drain lines, you may need to replace the pump.
If you enter model number here , you can find parts and diagrams.
Posted on Dec 08, 2008
futureloginn
  • 734 Answers
SOURCE: TUMBLE DRYER NO HEAT
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
How do I wash between the two glass pieces on my tricity bendix top oven as it has what looks like fluff between the glass
I used a hand duster with extendable handle type or
similar thin stick the right length
wrap pino wipes or similar product
around a the handle a few times or around the stick
I used a few of them but got the job done
Jun 07, 2016 | Tricity Bendix Washing Machines
Hi i bought a Tricity Bendix TMC209 microwave combination oven yesterday but have no user manual. any ideas where to get one. please.
Tri City Bendix is now part of Electrolux. They do not have manuals on line for this product as yet but you should be able to request one using this link:
http://www.electrolux.co.uk/Support/Manuals/?modeld=TMC209
It does seem odd that this Combi Microwave unit has been in the market since Nov 2009 and there still are not any downloadable manuals on-line.
Kelly
Sep 12, 2011 | Tricity Bendix TMC209 Microwave Oven
Hi I have just moved property and I now have a tricity bendix oven that I can't get to work I have used the grill but can't use the oven
Its most probably the clock that needs resetting,by pressing the 2 rhs buttons depending on the model.Try this and hopefully the oven will work again as long as the cooker has been connected correctly.
Hope this has helped.
Jun 25, 2010 | Tricity Bendix Cooktops
Main oven won't work
On ours you have to use the the timer controls; press the button with a hand symbol and the one next to it with a "-" symbol at the same time. Try a combination of the buttons on yours if this doesn't work. Weird, and took me months to figure!
Jan 12, 2009 | Tricity Bendix SE454 Electric Kitchen...
Tricity bendix fan oven
The element is almost certainly burnt out .A replacement element is fare cheaper than a new cooker and relatively easy to fit
Apr 07, 2008 | Ovens
SE454S Tricity Bendix
I have the same problem as the cooker is old.We are trying to fix the problem and when i have figured it out we will email back.
Nov 22, 2007 | Tricity Bendix SE454 Electric Kitchen...
Tricity Bendix WDR1240W Condenser dryer problem
Check the fan that is supposed to blow the hot air into the drum. It may be seized or jammed. It should be situated on the top of the outer drum. You will need to remove the top cover from the machine and identify the blower fan.
Nov 01, 2007 | Tricity Bendix WDR1240W Front Load Washer...
Tricity Bendix Cooker Main Oven Thermostat Switch For Dsie502gr currys Logo
12 people viewed this question
Top Tricity Bendix Dishwashers Experts
Are you a Tricity Bendix Dishwasher Expert? Answer questions, earn points and help others
