Question about Kenmore Oasis HE 27082 Top Load Washer
Winterize? How do I get it ready for storage?
    President:
  • Kenmore Master
  • 2,651 Answers
Ifyou tip the unit back yollsee 2 pumps n either corner ofmachine, ifyou remove the hoses form each of these pumps, ans sit back up, all waterfom machine will drop out, it will be thelowest partofmachine, aside form disconnectn watersupply you should be fine wihtthat
Posted on Jan 26, 2009
I need a video on how to winterize and de winterize a Winnie Minnie 2015 22R.
hi john.
i have had a look around the internet and all i can find is to look on youtube.
or you could try this link.
video on how to winterize and de winterize Winnie Minnie 2015 22R Google...
Oct 30, 2017 | Cars & Trucks
Tip
Time to Winterize your lawn equipment.
Fall is here and now is the time to winterize your lawn equipment. <br /> <br /> If you plan on using your equipment into the winter, then this is the time to stabilize and winterize your fuel. If you have any fuel left over from the summer, use it up now and get fresh fuel for the winter. Gasoline starts to "oxidize" in as little as 60 days. So take the older, stale fuel and use it up. Mix it with the good gas in your car if you have very much left over.<br /> <br /> To winterize your fuel, start with fresh gasoline. Buy fresh gas from a station that sells alot of fuel, that way you are getting the freshest fuel possible. Add a stabilizer to the gasoline. I use "Sta-bil" brand, but you can use any brand of stabilizer that is local to you. Read the directions on the bottle and mix it with the gasoline. Fill the tank on your equipment and allow it to run for about 5 minutes. This will make sure the stabilized fuel is in all sections of the engine that have gasoline. Top off the tank and then store you equipment in a dry area. When spring comes around, you will be ready to use your equipment.<br /> <br /> If you are still using your equipment, prep your fuel as above and make sure to top off the tank after each use. A full gas tank is less likely to absorb water from the humidity in the air.<br /> <br /> This is also a good time to check the air filter.<br /> <br /> We'll change the oil and sharpen the blade in the Spring.<br /> <br /> Good Luck!
on Oct 21, 2010 | Garden
How do I winterize there is no place to put the fluid
Hi, Marvin not sure which fluid you're talking about back in the day I use to slowly pour about 4 oz. of clean motor oil down the carburetor while the engine was running to coat the combustion chamber so rust doesn't move in the following is geared towards Harley's but it will work for any motorcycle, if you know your bike is going to be idle for months or longer here are some tips you can use to make restarting whenever that day comes to a hassle-free breeze.
A. Remove battery and keep it close to a battery tender/charger that you can hook up to at least once a month for 24 hours.
B. Drain the fuel tank and inspect the inside for rust, dirt, ethanol sludge, etc, remove and clean the petcock filter if you are carbureted, remove the fuel pump and check the pickup filter and the plastic delivery line for pin holes as these are common with age.
C. Drain the fuel lines going from the fuel tank to the carburetor/induction module.
D. On carbureted models remove the main jet access plug and drain the float bowl or, if necessary, remove and drain the float bowl!!!! this is very important as old fuel can turn to sludge and gum up your jets.
E. Drain engine, transmission, and primary oil this will eliminate wet-sumping and other various leaking situations during the storage time.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a nice day.
How to Winterize Your Motorcycle
http://www.bikebandit.com/blog/post/ten-steps-to-winterize-your-motorcycle
How to Winterize Your Motorcycle at RevZilla com
Nov 07, 2016 | Motorcycles
How to winterize a kawasaki VN1500E
Hi Bridgetsommerfield, there are many different methods out there to winterize a bike but this is what I do to my Harley every winter if you know your bike is going to be idle for months or longer here are some tips you can use to make restarting whenever that day comes to a hassle-free breeze.
Winterize
How To Winterize
How to Winterize Prepare Motorcycle for Winter
Nov 07, 2016 | 2004 kawasaki VN 1500 Vulcan Classic
How to winterize 175 mariner outboard motor
Take a look at these instruction videos.
How to Winterize an Outboard boat, step by step guide in ...
9k=? 11:25 https://www.youtube.com/watch?v=x217iM77Qjc Oct 30, 2012 - Uploaded by Warren Hardy A detailed step by step guide to winterizing your outboard boat motor for ... most 2-stroke outboards ...
Winterizing Your Boat: Step 2 The Engine & Lower Unit ...
9k=? 10:01 https://www.youtube.com/watch?v=5kiOms2f4gg Oct 6, 2009 - Uploaded by West Marine How to Prepare Your Boat for Winter - Step 2 in the five step process on How to Winterize Your Boat: The ...
How to Winterize a Four Stroke Outboard Motor - YouTube
9k=? 2:44 https://www.youtube.com/watch?v=PRBnwYk8_Yk Nov 7, 2012 - Uploaded by boats.com Four stroke outboard motors are by far the most popular on the market. But there's a lot of confusion about ...
How to winterize your outboard
www.classicglastron.com/gl-outboard-winterizing.htm For smaller outboards, the simplest way to flush your outboard is by using a large ... water or purchase a set of "ear muffs" (available at your local marine dealer).
How to Winterize an Outboard Motor - Adventure
adventure.howstuffworks.com/outdoor.../how-to-maintain-a-boat4.htm ... the winter and prolong its. Learn how to properly winterize an outboard motor. ... Buy lubricant, oil, and fuel conditioner at a marine store. Time: about 2 hours.
Jan 09, 2016 | Boating
Cannot find the water pump to winterize 2010 Forest River Sierra. I can hear it running but am unable to locate it. The bypass valves are in the correct winterize position but the antifreeze will not go in...
You don't need to find the water pump. Make sure your water tank is empty before adding RV winterizer to the water tank. Run each faucet in the RV with bypass valve NOT in winterize position until you see the antifreeze begin to come out of the faucet. Do this for both cold and hot water side for each faucet. Then move bypass valve to winterize position and run for a few seconds.
Oct 29, 2013 | Forest River 2009 Sierra 355QBQ
Winterize minimax heater
Lost the manual to my heater. Would like to know how to
winterize the heater. mini max ch 250 M
bl.wilson @ hotmail.com .. thank you, hope you can help me.
Oct 03, 2009 | Pentair Minimax NT Heater
2005 Kymco 250cc quad 4 stroke, all auto. Won't start
get a can of starter fluid and spray a short burst into the air intake...it should fire up...if it won't stay running or idle your carb is clogged from storage i presume...right? usually storage for more than 3 mos will clog a carb if you did not winterize it...Good luck to you friend...Tim
May 11, 2009 | 2005 Kymco Grand Dink 250
Kenmore Oasis HE 27082 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
