Question about Mitsubishi WS-48613 48" Rear Projection Television
Mitsubishi hd rear projection WT-46807
We are experiencing a problem with our 46" Misubishi TV, which is about 6 years old. While in the OFF position, the TV will randomly turn on. This is happening frequently during the day and lately in the middle of the night. When the TV turns on, it is on the Antena A position (where we did not leave it), it is on a different channel than we left it, and it is blaring loud! Also, while we are watching TV in the Cable S-Vid mode, it will sometimes switch over to the Antena A position and a different channel, in the middle of our program. Please advise if this is a known problem. Also, is it something worth fixing?
    Novelist:
  • 192 Answers
The front panel on this set has a history of bad switches and is more than likely the problem. To find out, disconnect the switch assembly and use the remote to operate the set. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. Unplug it. If the set returns to normal then you can either replace the switches or leave it like that and just use the remote. Since the front panel indicator light will be disabled, you will have to remember to let the set reinitialize one and a half minutes before turning on the set after reattaching the AC Cord. If it continues: Check for a picture tube leaking on the boards. You may find an oily type of liquid on the boards and if so, unplug the set and call a servicer. Another cause may be the remote. Remove the batteries. If you have any other questions, reply to this solution and I will respond.
Posted on Jul 15, 2007
SOURCE:
My Mitsubishi WT-46807 rear projection TV worked fine last night but this morning though it "clicks" and the green light comes on, there is no picture or sound from the television. I have tried to unplug...
I have a 64' samsung tv , It did the same thing and it was the lamp inside it. I bought it online at parts store.com, it works fine now. We fixed it ourselves and didnt know the first thing about tvs. Good luck
Sep 29, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 Bottom of picture cut off
YOU HAVE A VERTICAL DEFLECTION PROBLEM, THE RETURN CAP IS DRYING OUT AND MUST BE REPLACED
Dec 27, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Does the Mitsubishi WT-46807 need a converter box to receive a HD signal?
Yes, this model only has one HD input--it is the one marked on the back of the set as DTV---you need to hook a box for HD to that input.
SD TECH
Oct 23, 2009 | Mitsubishi WT-46807 46" Rear Projection...
Mitsub tv
can you be more specific ? i don't understand your posting. what is the problem with your tv?
Nov 22, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi 50" (14 yr old tv) rear projection TV
Yes this is the same as the others the voltage regulator is gone on your tv, replace it and take a good look at the power supply and horizontal ckt look for some cold solder
good luck
[email protected]
Oct 29, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807
MY FRIEND YOU HAVE A POWER SUPPLY PROBLEM AND MAYBE THE CONVERGENCE IC'S ARE BAD.THERE ARE A FEW TRANSISTOR IN THE POWER SUPPLY THAT HAVE TO BE REPLACED FIRST.
[email protected]
Sep 23, 2008 | Mitsubishi WT-46807 46" Rear Projection...
TV is Ghosting
if convergence problem color would be bowed and off. If it is the convergence replace ic stks there are 2 inside tv if you could solder and good at this stuff. parts cost is 30.00 . if you are going to get fixed cost is 300.00 . www.part store.com has parts just give them model number .They can tell you part number.I would pay someone to do this it is trickey.
I think ghosting is ground problem on cable connections check connections and replace cable wire.
thanks doctor video
May 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
WT-46807 HD PRoblems
GO TO INPUTS ON THE MITSUBISHI AND TURN THEM ON, THEY COME IN THE OFF POSITION
Nov 17, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi HD 65" thin squiggly line in upper right corner that moves
Is the problem there on every source? DVD playback ok?
Suspect signal source  box.
May have bad connection since move.
Is the problem same on every channel,if source is cable direct?
Please provide more info if more help needed....T.
Oct 17, 2007 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WS-48613 48" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
