Question about AutoCommand Remote Start and Security with Keyless Entry
Wiring diagram autocommand 21921/V9.11/1BD/4201
Tools required for installation
  • Design Tech Master
  • 625 Answers
Really?!
Posted on Jan 21, 2013
How to Replace a p1355 on a 2000 volkswagen new beetle
Is this for a ignition coil output stage open circuit? If so you need to rerun the ground wire. Just but the wire close enough to the coil that you can still get to the wire and splice another wire to it. Just splice a wire to the brown wire and run the rest of the wire to a ground lug under the battery. You will need to remove the battery and the tray. Also when you hook the battery back up make sure the key is on. This will reset alarm and radio. Remember, you are grounding the coil so the wire should go from the coil to ground. Hope this helps
May 29, 2014 | 2000 Volkswagen Beetle
Installation
horn was fun to find, green, it goes in with the air bag wires. mine is a 92 metro convertible
Feb 05, 2014 | AutoCommand Remote Car Starter Add-On
Is a autocommand model 21921 remote starter compatible with 2007 chevy trailblazer with factory keyless entry
go to IDATALINK.com,you can enter your car specs and buy correct interface module, door locks park lights dome lights and ignition module.i installed audiovox aps 997c remote start alarm with their module works like a champ.VERY INVOLVED INSTALL
Jan 19, 2013 | Design Tech Vehicle Parts & Accessories
I bought an add-on remote start that said it works with factory installed alarms and we can't get it to work. I have a 2003 chevy s-10 zr2. we were trying to find a wiring diagram but no luck to see if we...
The red/white wire needs to see two ground (-) pulses to start the car. The door lock wires in your vehicle are positive(+). So, you will have to use a relay to make this work. The diagram for the relay will be like so: red/white from autocommand to 30, chassis ground will go to 85 and 87, and tap into the blue wire and connect it to 86 of the relay. This way when you press the lock button on your factory remote, the positive pulse at 85 will activate the relay and make the connection with 87 and 30, sending a ground pulse to the red/white wire. The blue lock wire can be located at the body control module(BCM) located to the right of the gas pedal. There are a couple of 7mm bolts holding a plastic piece that needs to be removed to access the BCM. The door lock wire is in the brown plug facing the drivers side.
Jan 26, 2011 | AutoCommand Remote Car Starter Add-On
I need feeler gauge settings for tappet adjustment on a 1967 ford mustang 4.9 engine please
Found this online:
Engine
  • Measure the camshaft lobe lift with Ford Tool Numbers 4201-C, 6565 and 6565-AB. Use Ford Tool Number 4201-C to measure crankshaft end play. Check valve clearance with Ford Tool Number 6513-K unless the engine is a 390 or a 428, in which case Ford Tool Number T58P-6565-A must be used. If the engine is equipped with rocker arm studs, remove the studs with Ford Tool Number T62F-6A527-B. Install the studs with Ford Tool Number T62F-6A527-A4. Remove the harmonic balancer with Ford Tool Numbers T58P-6316-A and T62F-6316-B. Install the harmonic balancer with Ford Tool Number T52L-6306-AEE. Replace the crankshaft front oil seal with Ford Tool Number T58P-6700-B. Remove the camshaft bearings with Ford Tool Number T58L-101-A. Install the camshaft bearings with Ford Tool Number T53L-200-A.
  • Read more: Classic Mustang Restoration Tools ' eHow.com http://www.ehow.com/list_6908584_classic-mustang-restoration-tools.html#ixzz1B8AZ6fjK
    Jan 15, 2011 | Computers & Internet
    98 chevy truck Z71- When using the remote starter every thing works good except the engine light comes on with transmission codes stored in memory. The transmission then has a shifting problem until...
    The remote start system has been improperly installed. This is a common occurrence for the vehicle that you have. To correct the problem, you need to make sure that the vehicle's primary ignition (pink), ignition #2 (orange) and ignition #3 (white) wires are connected to separate ignition sources from the remote starter. This may require the addition of relays depending on the number of high current ignition outputs available from the remote start module.
    If you have the model #25622 remote start installed than you need 2 extra relays. The relay terminals need to be wired as follows:
    30 = to vehicle extra ignition wire
    87 = to 12V constant source (fused at 20A)
    87a = no connection
    86 = to r/s module thick green wire
    85 = to chassis ground
    Both relays need to be wired the same way.
    Nov 08, 2010 | AutoCommand Remote Car Starter Add-On
    I have a 99 Dodge Durango and I installed the remote starte with keyless entry and I am haveing a problem withe trans when it starts in the remote mode. The trans makes a noise like a seloniod is running...
    what type of remote starter did you install? I have run into a particular brand that had published a bad diagram drove me nuts.Make sure the wires in diagram are wired to its correct corrisponding places.
    Dec 27, 2009 | AutoCommand Remote Car Starter Add-On
    1998 ford 4 cyl. 2.0 over drive over head cam timing diagram looking for the timing diagram
    There are no marks on this motor. To do the install it requires the special tools to lock the camshafts in place (requires valve cover removed) and crankshaft in place for the install.
    Jun 07, 2009 | 1998 Ford Contour
    AutoCommand Remote Start and Security with Keyless Entry Logo
    Top Design Tech Vehicle Parts & Accessories Experts
    Thomas Perkins
    Thomas Perkins
    Are you a Design Tech Vehicle Part and Accessory Expert? Answer questions, earn points and help others
