Question about Motorola Mobility ATRIX Cell Phone
My motorola atrix hd phone froze. what do i do?
S a motorola atrix hd cell phone. there is no removeable battery and I do not know how to remove the backing anyways. waht do i do
How much is a battery for a Motorola Atrix LTE CE0168
Judith-
The Atrix 4G (MB860) has a removable battery.
The Atrix 2 (MB865) has a removable battery.
The Atrix HD does not have a removable battery.
I believe the battery for the original Atrix was SNN5865. but look for the SNN number on your battery and then you can look online for availability of that same battery. Please ensure you use Motorola Original batteries rather than knock-offs.
Mark
Motorola Support
Jul 01, 2015 | Motorola Cell Phones
Will the phone work without the flex cable connected to the battery
Hi larry scott
Unfortunately, no the device will not work without that.
Regards
Marge
Motorola Mobility
Oct 01, 2014 | Motorola Mobility ATRIX HD MB886 Android...
Does the motorola atrix hd work if the flex cable on the battery torn
Hi larry
The device will not work without that cable or if it broke.
Regards
Marge
Motorola Mobility
Remove gmail account
to delete gmail account from Motorola Atrix 4G
follow the simple steps to delete the G-mail account -----
1st-->>open the home page from the device.
2nd-->>select the option of setting.
3rd-->>open the option of sync & accounts & tap on it.
4th-->>open the G-mail accounts on the device.
5th-->>open & click to remove accounts.
6th-->>now delete the G-mail accounts on the screen.
RECAP==MENU--SETTING--ACCOUNTS--REMOVE --OK
Apr 17, 2014 | Motorola Mobility ATRIX HD MB886 Android...
My son entered an incorrect pattern 20 times on my motorola atrix hd, now it says 'to access phone sign with google account'
Give it some time and maybe you will have another chance. Otherwise you'll have to do an external reset. Hopefully things are saved to the cloud so minimal is lost.
Jan 19, 2014 | Motorola Mobility ATRIX HD MB886 Android...
Motorola hd atrix screen went black wont respond to anything
Turn off the phone then press Volume Up button and power . See what hapens.
Jul 31, 2013 | Motorola Mobility ATRIX HD MB886 Android...
Subsidy unlock code for atrix hd lite
You can get the subsidy unlock code for your Motorola Atrix HD LTE by visiting the site Prounlocking.com .Here,they ask to provide the model,country,network provider name and IMEI number of your mobile.After they deliver the unlock code for your Motorola Atrix HD LTE cellular phone through mail.After unlocking it ,you can use any GSM network on your mobile.
Jan 08, 2013 | Cell Phones
My motorola atrix 2 wont turn on
try pressing power key + home key + volume up key at the same time, see if you can boot to recovery, then, once rebooted, select clear cache partition, then select wipe data/factory reset..
and better not use a charger not compatible to your phone.. hence it would burn those leads inside..
Dec 29, 2012 | Motorola Mobility Atrix 2 - 8gb - Black...
Motorola Mobility ATRIX Cell Phone Logo
153 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
