Question about Maytag MER7765WW Freestanding Smoothtop Electric Range
MY maytag flashes a error code while trying to self clean. It is a MER7765
It starts to work for a few minutes then flahes the code. There is some burnt stuff on the broiler element. It does heat up, but not sure if maybe it is burnt out. Will the stove work correctly if that does not work
    Sergeant:
  • 475 Answers
No the stove don't work right then you have to have a repair man look at that.
Posted on Mar 11, 2013
Why is door locked and will not self-clean?
Hey Kimberly, thank you for your inquiry!
I understand that the door on your Frigidaire range is locked and it will not start a self-clean cycle, it is also displaying an error code of "F91". The "F91" error code means that the door has exceeded maximum oven door unlock time. This means you could be experiencing an issue with your door latch, control panel, or a miscommunication within the range. To clear out a miscommunication within your range you need to disconnect power from it for at least ten minutes. I hope that this information is helpful to you. -Matt
Feb 11, 2016 | Frigidaire Gas & Electric Stove/Oven/Range...
What does the code"F5E2" mean when trying to use the self-cleaning function?
This error means that the door lock didn't engage properly. This could be a wiring problem or a problem with the switch. First disconnect the range from power and check the wiring and switches from the control to the switch and back. If the door was locked when the F5E2 error was observed, then replace the door switch.
If the door was not locked, then check the door switch and the latch switch. Replace the bad switch.
The rear door switch is part W10107830, https://www.partstore.com/Part/Maytag/Maytag/MER7765WW/Whirlpool/Whirlpool/W10107830/New.aspx . A useful parts diagram is here: http://www.searspartsdirect.com/model-part/mer7775ww0/3048/0124111/W0908230/00003.html .
After replacing the bad part, reconnect the power to the range. Press and hold any key for a minute to clear the F5 code from the memory. Then press Cancel to clear the next code you see. Check if the range works.
I hope this helps.
Dec 23, 2015 | Maytag MER7765WW Freestanding Smoothtop...
Oven Lock stuck open before start of self-cleaning cycle I get a code F9, a flashing lock light, a continous beep and a dr code on the panel when I try to set self-cleaning cycle again.
Thank you for your inquiry, Lucie!
From what you have described your Frigidaire oven lock is stuck open and you are receiving error codes "F9" and "DR". The "F9" error code stands for runaway temperature (overheating). This could be an issue with your RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control). I would recommend performing a reset on your oven and you can do that by disconnecting from your oven for ten minutes. The "DR" code means that the door is not closed or the door latch is not recognizing the door is closed. This could be an issue with your door latch or control panel. If the reset does not help correct your issues I would recommend having a professional technician out to perform a proper diagnosis and repair. Best of luck! -Matt
Apr 30, 2015 | Frigidaire Stove/Oven/Range Black Glass...
I have a Maytag MIR8890AS induction range and after 10-15 minutes of running either the cleaning cycle or the having the oven at around 400F, it will start beeping every few seconds for a long time. A
new ovens and electronics have error codes programmed in, my new stove does, you need to call an electrician and tell them the exact beeping issue and this will give them an idea on what may be wrong. In the meantime see if the manual it came with has a trouble shooting or error code page, or go to http://www.maytag.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10562&langId=-1&storeId=10212
Dec 16, 2014 | Maytag MIR8890AS 6.2 cu. ft. induction...
I have a drop-in oven from frigidaire.I started the self cleaning process the door did not lock and the light keeps flashing,I dont know how to stop it and i cant use the oven at all.
Good Morning friend, thank you for your post!
I understand that your Frigidaire range is not allowing you to cancel and you are unable to use the oven. I would suggest holding down the "Cancel/Clear" button for ten seconds and that should cancel the self-cleaning. If that does not work I would recommend a reset on your range, you can do that by flipping off the household circuit breaker for ten minutes. I hope this has been helpful. -Matt
Oct 13, 2014 | Frigidaire 30 in. Electric Self-Clean Coil...
How do I stop the door lock from flashing on my self cleaning oven
Hello Brian Pelletier, thanks for your inquiry!
I understand that you are having issues with your door not locking upon using the self-clean feature. It sounds like a possible issue with your EOC (Electronic Oven Control) or dock latch assembly. I would suggest unplugging your range if possible or flipping you breaker for ten minutes to perform reset. If the light continues to flash you may want to seek assistance from a professional for proper diagnosis and repair. -Matt
Owners manual amana stove
Try turning off power to stove for a few minutes then re try
Jul 15, 2014 | Amana 30" Self Cleaning Electric Range...
Stopped working, flashing code F7 and beeping
Hello Michelle, thank you for your inquiry!
Typically error code F7 indicates that your Frigidaire range is experiencing a failure with either the potentiometer or UIB (User Interface Board). Let's try resetting you range by unplugging it or flipping the household circuit breaker off. This usually clears most false error codes. It is best to wait approximately ten minutes and then turn on your appliance. If the error code persists, it would be advisable to contact an experienced appliance repair tech to assist further.
Best regards - Z
Mar 16, 2014 | Frigidaire Stove/Oven/Range Cooktop -...
F3 Error ?
I think it's time for a new one.
Jul 30, 2012 | Maytag MER7662WW - 30"Self-Cleaning...
Sparker turned on by itself and would not stop
Hi rlimaye1,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 11, 2011 | Maytag MGC5430BDS Gas Cooktop
Maytag MER7765WW Freestanding Smoothtop Electric Range Logo
82 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
