Question about Kustom KPM8420T PA Amplifier/Mixer
I need the schematic diagram of Kustom model: III BC.PA serial no. K208113
I have a Kustom KPM8420 PA mixer and the monitor channel comes through both the monitor and main speakers and vice versa. The two channels are not separate.How do I fix that?
On the back panel there is a section labelled Patch Bay
There are 2 small switches which assign each Power Amp to either Monitor or Main Output.
It would seem you have them both set the same at present. Set one to Monitor and one to Main, and use the corresponding Power Amp outputs direct to speakers.
Note you can send signal to external amps or powered speakers from the preamp outputs. This is really handy.
Download and print the manual from https://www.manualslib.com/manual/90516/Kustom-Kpm-8420t.html
and keep it with the mixer.
( Of course don't send speaker outputs to other amps or powered speakers )
Sep 11, 2017 | Kustom Music
How do I connect a 8channel mixer to a Kustom PA PA112S Powered Sub and 2 JBL EON615
I'd have to know the make and model mixer to properly advise you. In general, if I were you, I'd come out of the L/R mixer outs to the JBLs and run the sub from an aux send set to post faders.
However, I would suggest getting a different sub. That one will not keep up with the eon's.
You would probably need 4 of them to get close to matching.
Jul 12, 2016 | JBL Music
B.C. Rich Ironbird Pro guitar serial no G01111219. What year was it made and where?
Dating Your Rich Guitar Dolphin Music
The relevant part -
In November of 2000 B.C. Rich implemented a new date stamp format for serial number coding of it's imported models. . This started on the January 2001 models. All B.C. Rich models, both imported and usa handmades implement this same year time date stamp and guitar production number format:
121XXXXX first digit = year of manufacture
second digit = means nothing until double-digit years get here again
third digit = quarter of manufacture
digits 4 thru 8 = production number
Current US-made B.C. Rich serial numbers follow the same year and guitar production number format. (example - serial number #24123 was the 123rd guitar made in 2004)
Jun 10, 2016 | B.C. Rich Music
Schematic diagram
Line 6 does not supply schematics to end users.
Feb 04, 2014 | Line 6 Spider Iii 15 Modeling Guitar...
Kustom KPM8420T schematic
Where can I find a schematic for a Kustom KPM8420T?
Jul 07, 2013 | Music
Kustom KPM7250T mixer made a loud popping noise and lost sound to speakers during gig, but front power lights stayed on. Accessible fuse good. have it at dealer to see if can be repaired but he needs...
Pilot lights mean very little. Either a filter capacitor failed or other part(s) failed. Needs to go to the repair shop. The damage MAY be visible or require test equipment to diagnose.
Aug 11, 2011 | Kustom KPM7250T PA Amplifier/Mixer
Hi! I need two input/output plates for my Kustom floor monitors (KSC10ML). By input/output plate, I mean the unit that has the volume knob plus the two input/ output jacks that is screwed ino the side...
The KSC10ML has NO volume control... only two 1/4 inch jacks. To get a matching "jack cup" you will probably have to go to Kustom. I have searched for the item on the web and only jack cups that seem to come up are for Marshall or ones that use binding posts. I found one blank one but it is 5 by 7 inches... too big for that Kustom cabinet. In a pinch if you don't need it to be recessed, cut metal or ABS plastic plates and drill for two jacks.
Apr 16, 2011 | Kustom KSC10ML PA Monitor
I NEED THE SCHEMATICS FOR A KUSTOM AMPLIFIER MODEL 4-15C SO WE CAN REPAIR IT, THANK YOU
Here is a link that might help:http://www.vintagekustom.com/FUDforum2/index.php?t=i&cat=2&rid=0&S=c04218e7e0f8ac8bb52d5b4ecde8a9d3 Also try here:http://www.stereomanuals.com/man/rep/kustom/index.htm Scroll down and be advised you will have to pay for it but at least it will be legible. This forum may or may not be of assistance:http://music-electronics-forum.com/t19128/ You might try here:http://www.kustom.com/MessageCenterDetail.aspx?ContentID=1325 Someone there might know someone who has one.
Nov 08, 2010 | Epiphone Blues Custom 30watt 2x12 Combo...
Kustom KPM8420T PA Amplifier/Mixer Logo
127 people viewed this question
Top Kustom Music Experts
Torashi
Level 1 Expert
Lawrence Nentwig
Lawrence Nentwig
Level 1 Expert
Are you a Kustom Music Expert? Answer questions, earn points and help others
