Question about Toshiba 2860 Copier
Close side door error message
The right side door was opened and feel off pulling the wires out of the connector. I put them pack in the connector and now I get a 'Close side door error message'.
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 41 Answers
Garry, you're gonna need a new harness buddy. And with that being a 2860, sorry to say it's obsolete and chances of finding a new harness is somewhat unlikely. Time for a much needed upgrade, it's an analog run away.
Posted on Feb 15, 2013
5 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: Toshiba e 350 "close finisher door"
Finisher door is the sorter. there is a switch or door in the sorter not closed (or triggered)
Posted on Aug 12, 2008
checkitright
  • 1362 Answers
SOURCE: TOSHIBA E STUDIO 351 C
check the bottom door on the right, I beleive there are three doors on the right, if not there is a door sensor loose.
Posted on Oct 01, 2008
mce_sys
  • 41 Answers
SOURCE: Close side door
Good solutions for u :
1. Cheak all the connectors in cool mind
2. On the other hand this fault may me come from main board.
3. and the last say is this error can come out from power supply.
4. Cheak your closing again.
Posted on Jul 24, 2010
  • 44 Answers
SOURCE: I have a Toshiba 455 copier. The error message
Please check the actuator for the front door switch, it could be bent or out of position. Hope this helps.
Posted on Jul 17, 2011
How i open the machine's door because it is lock
usual cause is a faulty interlock/ wiring.
to open the door, disconnect the machine from the mains, remove the lid and then put your hand down the right hand side of the door between the door and the drum. you should feel the locking mechanism, there is a manual release, its just a case of feeling for it and its usually a pull
May 09, 2014 | Washing Machines
Mp 161
open the right cover where you normally remove the paper jams,then open front cover/door where you put toner,lift the green handle up,push green lock towards the right side while pulling the hopper out,then theres a connector beneath the PCU,pull it then pull out the PCU,use the same same procedure to put it in,start with the PCU,return the connector and put in the hopper,then close all doors/covers
Apr 29, 2013 | Ricoh Aficio MP 161 Black and White Copier
Ink door open meassage
Open cartridge access door, observe left side door switch located, manually operate it feel weather its working or not, close door & check.. not rectified, insert peace of paper in it. check...
Feb 02, 2012 | HP Photosmart C6180 All-In-One InkJet...
The code f-28 appears on my whirlpool washer, and my washer will not do anything. the dooor will not unlock either
To unlock the door remove lower kick panal reach up to door latch there is a small tab at the bottom of door latch that will release door pull down on it . The f 28 is a comun between the motor control board and ccu. What you need is a can of electronics cleaner.unplug washer remove top of washer should be white box top right side remove each wire clean wire contact and board contacts do one at a time so u don't get messed up..Go to lower section of washer white board in rear left/that is the motor control board clean the contacts on board and wires /put unit back together....tip if that does not work///// best to get in a pro with a meter to do further test......good luck
Feb 01, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Hi yes i have a Lanier LD015f. I just received the photoconductor. Hoow do you replace it?.
Hi, you should have received instructions with the photoconductor, but replacing it is pretty straightforward.
To remove the old photoconductor:
- Open the front door and the right side door. - Remove the toner hopper. - Unplug the connector going from the photoconductor into the machine. - Pull out the photoconductor.
To install the new photoconductor:
- Remove all of the tape, paper, and packing materials. - Slide the photoconductor into the slot left empty by the old one. - Attach the connector and route it behind the plastic guide. - Reinstall the toner hopper. - Close the right side door and front door.
If the machine was on when you replaced the photoconductor, it should automatically detect the new one.
Dec 01, 2010 | Lanier UNKNOWN
I have a ricoh spc232sf multifunction printer which is giving a error message of cannot copy and it says feeder adf what do i do?
the ADF is the upper cover where you put the document to be automatic feed by the machine, that is the part which you pull up when you want to copy on the exposure glass, on the left side of the ADF has a little door which you need to open. It is opened like a car door opener and pull it on the right side. see do have some paper inside if do not have paper close the door and lift the ADF in to up position and than set it back. with this you will rest the message.
Please answer do this is helpful for i to know do i should post some more information.
Regards
Jan 12, 2010 | Ricoh Aficio SPC232SF All-In-One Laser...
Elite front-load washer error code F22 then F28
This is an indication of a door latch failure and/or interconnecting wiring problem. The first step in troubleshooting the problem is to unplug the washer for AT LEAST 30 minutes in an attempt to reset the Central Control Unit (CCU). This is the main "brain" of your washing machine. Sometimes these error codes are erroneous and can be easily cleared by resetting the CCU. If the error code reappears following a CCU reset, then you have a genuine problem. In addition, if the door latch remains locked following this procedure, there is a manual release you can use to open the door. Follow these steps:
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with a 2 x 4, it makes access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
If you still have the error code displayed, inspect the door latch mechanism for any broken, loose, or missing components. Next, open the top panel of the washer by removing the three screws in the rear of the washer that hold the panel in place. With the screws removed, the panel will slide back, then off. Locate the door latch on the right hand side behind the front panel. Inspect the wiring harness from the door latch to the to CCU. The CCU is located directly behind the wash tub in the top rear of the washer. Make sure all the connectors are snug and not loose or broken. In the majority of cases, a persistent error is a failed door latch. If all these preliminary checks are unsuccessful, replace the door latch. Follow these steps:
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
NOTE: Another method is to access behind the front panel from the top with the top panel removed. Either method works, but I have found that going through the front offers better access.
F28 is a serial bus error from the CCU (Central Control Unit) to the MCU (Motor Control Unit).
All you need is some Electronics contact cleaner spray and a 1/4 inch socket to remove the top of the machine and the back of the machine.
The CCU is the computer looking box at the top front right hand corner.
Find connector M13, (has red marking on it and only 3 wires) disconnect it by pushing the retainer tab back and pulling gently on the connector.
Spray the contacts of the connector and computer with connector cleaner.
Then re-assemble connector.
The MCU is in the back lower left corner.
Find the connector with 3 wires and red mark, and remove this connector in the same way you did the other, spray it and re-install.
Put the back and top back on.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 21, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Red light is on no paper jam no errors
Try unplugging it and opening every door possible and pulling every toner cylinder. Put the toner cartridges back in and close the doors and plug it in again and see if it works for you like it basically did for me.
I had the same error so I unplugged it and open every door where a paper jam could be. Pulled out every toner cylinder and put them back in. I wiped down where I accidentally spilled some toner (FYI Never pull out the front casing for all the toner without the printer remaining right side up.) I plugged it back in and then got a new error message - that it was out of magenta which I've been expecting for awhile. I replaced it and now it's good to go. Good luck.
http://support-us.samsung.com/cyber/popup/pop_troubleshooting.jsp?ia_cd=06010200&model_name=CLP-300
Apr 21, 2009 | Samsung CLP 300 Laser Printer
60 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
