Question about Cameras
Toshiba u845-s400 screen will not come on
Working on laptop turned my back and screen wet out.
    Genius:
  • Cameras Master
  • 1,019 Answers
Dave, Were you doing an upgrade when this happened ? For some reason the Video has gone down, can't tell if LCD went out or video card quit. Try hooking up external monitor and see what you get.
Posted on Jan 26, 2013
My touchsreen isn't working anymore
Do you mean the touch function isn't working? Try reloading the lenovo drivers.
Do you mean the screen is dark or non functioning?
The usual cause is the flat cable from the body of the laptop to the screen is broken.
Warranty or repair shop.
Apr 12, 2014 | Lenovo IdeaPad S400 14in. LED Notebook -...
Replace keyboard on u 845
Instructions
    • 1 Remove your battery from the laptopicon1.png. Flip the switch underneath the laptop and the battery should pull right out with no tools required.
    • 2 Slide the flathead screwdriver underneath the keyboard securing strip at the top of the keyboard. Pull up ever so slightly, and it should pop off.
    • 3
    • Remove the three screws securing the keyboard to the laptop. The metal brace holding down the laptop will also come up.
    • 4 Flip the keyboard over onto the palm mouse. You will see your laptop connected to one more set of screws; remove them.
    • 5 Disconnect the cable holding in the laptop. The keyboard will now be completely free of the laptop.
    • 6 Replace or clean your keyboard, and reverse the previous steps to reattach a keyboard.
Read more: http://www.ehow.com/how_5942786_replace-keyboard-toshiba-satellite.html#ixzz2yyz9nnGU
Apr 04, 2014 | Toshiba Satellite U845-S406 laptop
Laptop to T.V. connectivity
Hello!
This is my first time using this site, but I will try my best to assist you.
From what I understand, you want to connect your laptop display to your T.V. In turn using your T.V. as a "monitor".
So you were wondering if you could use a S400 to HDMI cable to accomplish this. Unfortunately I don't believe this is possible with that cable. To my best knowledge, S400 ports are only capable of transferring DATA between devices, not VIDEO. A VGA or HDMI cable will accomplish what you want. I don't think your laptop has a HDMI port, so I recommend buying a male-to-male VGA cable.
I looked up your T.V. and it looks it should have a VGA input port. This is what I did for my laptop and 32 inch LCD T.V. when i accidently cracked my laptop's screen.
It may not be High Definition, but you should be able to get fairly decent resolution. Make sure your T.V. is on the "Computer" input channel. (Or equivalent)
I don't recommend buying a VGA to HDMI cable converter as it usually doesn't result in improved quality.
I hope this helps! Good luck!
Jan 21, 2013 | Computers & Internet
Add ram Satellite u845
Power down your Toshiba Satellite.
Unplug it from the wall.
Turn the machine over and remove the battery.
Locate the RAM compartment cover, which is usually located somewhere in the middle of the underside, and is about 4-by-4 inches.
Unscrew the RAM cover screw with a Phillips screwdriver and set aside.
Ground yourself by touching a metal object.
This will release any static electricity built up in your body, which can harm computer chips and components.
You can also use an anti-static wristband while you are working.
Remove RAM modules if needed.
This is most likely if you are upgrading the present RAM capacity with a larger RAM chip.
Press your fingers on the clips on either side of the chip to pop it out of the socket.
Pull the chip out of the RAM compartment, holding it by the sides of the circuit board rather than on the chip.
Insert the new RAM module into the socket. Align the RAM module so that the notch lines up with the tab on the side of the socket.
Gently lower the module into the socket. Press into place with your fingers.
Replace the RAM compartment cover. Insert the screw and tighten.
Replace the battery and secure with the lock.
Plug the Toshiba Satellite laptop back in and power up the system.
The upgraded RAM should be automatically recognized.
hope this helps
HOW TO INSTALL MEMORY UPGRADE TOSHIBA SATELLITE LAPTOP
not sure if this is the right laptop
http://www.youtube.com/watch?v=RdCzsjDp_lc
Oct 12, 2012 | Toshiba Satellite U845-S402 14" Notebook...
Toshiba wont power on
try turning off and then remove battery and plug in a/c cord.turn back on..still nothing let me knowRICHARDM69
Aug 24, 2009 | Toshiba Satellite A135 Notebook
Toshiba Qosmio X305-Q705 Laptop screen yellow
It is not a driver or video card problem. It is the monitor.
To be sure plug a full size desktop monitor into your laptops monitor jack. Every laptop has one. If the picture doesn't turn yellow that will confirm that your LCD is bad.
Aug 16, 2009 | Toshiba QOSMIO F15-AV201 Notebook
Toshiba a105 s2194 won't turn on.
Please try to remove the battery and just connect the power adapter to turn it on. You shoudl get the screen to work. After which, power off and then connect the battery back.
If this does not work, it maybe a hardware proble with the screen or the inverter
Mar 10, 2009 | Toshiba Satellite A105 Notebook
My toshiba laptop screen changed color
connect an external monitor (crt or flat panel monitor) at the back of your laptop and see if the display is fine. if the display is fine on the monitor then it means to say that the lcd backlight is not working properly.
Oct 07, 2008 | Microsoft Windows Vista Ultimate Edition
Cameras Logo
27 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
