Question about Bowflex TreadClimber TC5
How can I adjust the tension on the tc5 treadclimber?
It's very hard to walk.
    Top Expert:
  • Bowflex Master
  • 12,223 Answers
See the video and fix it. God bless you
Posted on Jan 19, 2013
  • Jennifer Prevette
    Jennifer Prevette Apr 25, 2015
    How does that help. That was not her question. And my question is the same.
Walking Belt Fraying
The bow flex tc5 is an overpriced piece of equipment. The build quality is not great. There are ongoing documented problems with the belts fraying on this model. You can always order a new belt or adjust the side (loosening or tightening) your primary foot stepping side, but I would call bow flex and demand a new belt or replacement. You can mention there is a "risk of fall" due to poor workmanship. This will get their attention and you may even get a new treadmill or at least free belt. Call Bow flex customer service at 1-800-436-6549.
Mar 18, 2014 | Bowflex TreadClimber TC5
How to adjust belts on TC5
This is not a easy job. Too many steps to tell.
Nov 30, 2013 | Bowflex TreadClimber TC5
The console light up with dashes and doesn't display setup modes
1) adjust the REED switch, clean it, tight the connector and wires very well, test for open or faulty. see the diagram attached.
2) if your system has batteries replace by new ones with the same types ALKALINES, and clean the contacts from dirty, oxide, corrosion with wd-40
3) tight the ribbon cables inside, clean it,
4) tight the upper connector +lower connector and clean it
5) measure the input voltage to the display board see the diagram attached.
God bless you
Nov 26, 2013 | Bowflex TreadClimber TC5
The console doesn't display the time, calorie, distance and speed mode.
adjust the REED switch, see the diagram attached, clean it, and test for open or faulty, tight the connector very well.
2) tight the ribbon cable inside, and clean it.
3) tight the upper connector and lower connector and clean it.
4) measure the input voltage to the board display.
5) if your system has batteries replace by new ones with the same type alkalines (clean the contacts batteries very well from oxide, corrosion)
God bless you
Belt off center on tc5
see the video and proceed according. God bless you
Mar 29, 2013 | Bowflex TreadClimber TC5
Clunking sound with TC5
LUBEthe deck belt and rollers bearing too. see the video
Test the motor bearing +dirve belt too
Jan 22, 2013 | Bowflex TreadClimber TC5
I have a TC5 and the console is not working correctly
Dear Sir:
Please 1) adjust the reed switch attached is diagram
1a)Tight the flexible cable from keypad + tight the connector from display board vs lower board.
2) Run the software calibration for easy diagnose and troubleshooting.
If you can Not run your s. calibration see my personal TIPS, for diagnose and troubleshooting.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Feb 29, 2012 | Bowflex Treadclimber
Track sliping
Adjust walking belt tension at the front of the unit using the provided hex wrench on the exposed adjustment bolts located on each side of each front roller. Be sure to adjust both bolts on each roller the same amount as to not disrupt belt alignment. Tighten (turn clockwise) each adjustment bolt in full turn increments. After each adjustment, restart unit and check to see if belt slippage has been eliminated. Repeat if necessary.If slipping feel persists after several adjustments, stop and see if it maybe the drive belt. Remove left rear plastic cover to expose “v” belt drive line and motor. Tighten nut on the motor tension bolt located on front side of motor in 1/2 turn increments until drive belt slippage is eliminated - DO NOT OVER TIGHTEN. Replace cover when finished.
Jun 27, 2010 | Bowflex Treadclimber
When walking in my Bow Flexn as in regular treadmill mode it feels like it slips under my one foot sometimes any clue as to why ?
If belt hesitates or slips when walking on unit it may be caused by either a loose walking belt or a loose drive belt. To determine the cause perform the following test: Stand beside Tread-Climber® fitness machine and set speed to 2 MPH. Step on one treadle and attempt to stop movement. If one belt stops but roller at rear and other belt continue to turn walking belt tension should be adjusted. If both belts stop but motor is still turning the drive belt tension should be adjusted.
May 22, 2010 | Bowflex Treadclimber
Bowflex TreadClimber TC5 Logo
370 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
