Question about GE Refrigerators
Light not working
Refrigerator light does not come on when door is open
    Problem Solver:
  • 11 Answers
First change your light bulb, if the light doesn't come on check the refrigerator section maybe at the top are the side your going to see a door switch if you depress it the light should come on if not take the switch out and check for voltage at the two wires if u have voltage change the door switch,, if no voltage is present then u will of to call a certified mechanic
Posted on Jan 20, 2013
Why won't interior lights go off
Bad door switch. Replace it or just ignore it. Use LED light so it will not produce heat in the frig.
May 03, 2014 | LG Refrigerators
The LG refrigerator door lights do not come on when I open the door every thing else works. French doors #LFC25760SW Hepl!!!
Were the doors left open at anytime? If so it has a thermostat that will shut off the lights to keep from getting too hot, If they werent left open, could be bad bulb or stuck or bad light switch on the door, all very easy fixes.
Sean
Mar 26, 2011 | LG Refrigerators
The water and ice dispenser stopped working, nothing on the control panel works at all
Looking over your wiring diagram I would go straight for the freezer door light switch. Part number 241547901 or 1037569 Switch-light lamp,freezer door. It is used as an interlock to disable the dispenser controls while the freezer door is open. I would unplug refrigerator and remove switch by prying out of its slot in the door frame. Use an ohm meter to test both ways. It has a three wire connection that while door is open lights are on and dispenser control disabled. When door shuts lights off and dispenser should have power. Let me know what you find, Thanks, Sea Breeze
Mar 19, 2010 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator just delivered lights were on, after filling fridge with food the lights dont come on when door is opened im talking the big lights on top of fridge
A lot of refrigerators now use the control board to time how long the lights are on. If the door is open for an extended period, the control will turn the lights off to pervent them from overheating. I suspect you have discovered by now that the lights are working again.
Nov 09, 2009 | Samsung RF265AA Bottom Freezer French Door...
The two lights are on refrigerator donot work
id be curious as to if there is a control board locatd on the sidewall next to the compressor, behind the refrig. usually encased in awhite housine mounted directly to the cabinet, ifso I'd open that boxup andlook for a burn mark, that s the culprit for no interior lights in refrig
Mar 12, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
I have a side by side Viking refrigerator and after leaving the door open a little too long the lights went out in both the refrigerator and freezer. I figured that they would go back on automaticlly after...
Remove the center grill of the top grill and shut the power off and back on, the lights should reset
When the lights are working open the Ref door then close the freezer drawer, watching to see if the light in the freezer shuts off. It should shut off when the freezer is about 1" from closing. If it stays on until the door is fully closed then there is a problem with the light switch in the freezer.
Normally when you leave the doors open until the lights shut off, it should reset when both doors are closed
Mar 06, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
Refrigerator door light is clicking when door open; light flickers, or does not work at all
check the door switch to see if its working. also check the bulb it may be loose in the socket.
Jan 21, 2009 | Whirlpool GD5SHAX Side by Side...
GE Side by Side Refrigerator
Door Alarm -
To set the alarm, press this pad until the indicator light comes on.
This alarm will sound if either door is open for more than 3 minutes.
The light goes out and the beeping stops when you close the door.
Jun 01, 2008 | GE PSS26MGS Side by Side Refrigerator
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
