Question about Acer Aspire 5100 Notebook
Downgrade from vista to xp
Hi Ziraffa; I have two laptops that I want to downgrade from vista to xp. When I put the xp install disk in it will not let me install from bios boot or standard boot. What are your suggestions on this problem. I wanted to ask you because you did such a good job last time. Thanks Bryan. bryanfoshee@yahoo.com
  • bryanfoshee Jan 28, 2009
    It picks up the cd. It just won't start downloading the cd. Says windows running is newer than windows on cd.
    Genius:
  • Acer Master
  • 1,102 Answers
Make sure before you format
you write down your drivers in device manager for
AUDIO
DISPLAY
WEBCAM
NETWORK
If you can save any programs to disk or flash/memory drive
winxp cd in drive restart hit F7 a box will appear choose option to
cd cd/dvd then enter
should pick up cd you may have to restart a couple times.
( Not all systems can be downgraded ) and remember you can't use your vista product key for xp
Posted on Jan 28, 2009
  • DEKR
    DEKR Jan 28, 2009
    you may not be able to downgrade
    if you restarted and during restart hit F7
    and option start with cd then enter
    don't try and do after windows is loaded
    you have to restart F7 at the same time as restart then cd option then enter I think your letting windows load and it can't be down that way
    then put the cd in the drive and restart
    maybe if you wait to put cd in drive
    when the screen comes up start with cd press enter
    if you are doing it correctly and it still won't let you then a technician would have to do it
Can't install xp in compaq laptop
you mean you need to downgrade your computer from Windows Vista to XP?
if so is the case, you need to go to the BIOS in the Boot menu, select IDE from ACPI.
put the boot option to boot from CD first or disable Boot from hard disk.
then you will be able to downgrade your computer from Vista to XP.
Jun 07, 2010 | Compaq Computers & Internet
I have purchased an hp550 computer with the Vista operating system. i wish to downgrade to the win XP operating system. how is this done ?
Greetings.
There is no direct path to downgrade Vista to XP. You can’t simply insert the XP installation CD media into the CD-ROM drive and hope to ‘upgrade’ and replace the Vista with Windows XP usual install routine because Vista won’t allow it to be overwritten. XP will treat Vista as ’superior’ operating system and refuse to install over it. There’re actually few options available instead of completely uninstall Vista as listed below. But if you decide to downgrade from Vista to install XP, there is also a simple guideline that you can observe to ensure that the migration goes smoothly.
Option 1 – Dual Boot:
It’s by far the easier and best method to run XP instead of Vista if you have another partition or hard disk. Simply boot up any XP setup media and install XP into different partition or hard drive than the Vista installation. Once completed, you can choose to boot up either XP or Vista, and has the best of both world.
Option 2 – Virtual Machine:
Install VMware Server or Virtual PC 2007 (both free) or any other virtualization software, and then install Windows XP into the virtual machine
environment. You will get XP which runs inside Vista, with minor compromise on speed, performance and have to go through Vista first on every bootup.
Option 3 – Format the Hard Drive, Wipe Off Vista and Install XP:
For those who totally fed up with Vista and just want XP, or prefer a clean installation of OS has only this option to rely on. To downgrade to XP from Vista, you have to basically delete the whole hard disk that installed with Vista, and start anew with XP. Here’s a simple guide and procedures that you can try to follow to switch to XP. However, each system configuration is different, so you may have to adapt the steps to suit your own need.
1. Download all drivers for your system for Windows XP from the manufacturer’s website(in case if you don't have the CD/DVD installers). Copy the drivers files to a USB flash driver or external hard drive or burn them to CD/DVD.
2. Find a Windows XP installation CD (should be pretty easy to find or else you can search in torrent sites such as Demonoid to download via BT network such as uTorrent and BitComet or search and download via ED2K network client such as eMule. You can also use Volume Licensing (VL) CD, retail (FPP) disc, or system builder hologram CD provided by Microsoft.
3. You will also need a XP product key even if you legally can downgrade from Vista Ultimate or Business edition. The Vista serial number won’t works with XP. (try to search for XP product key on web).
4. Backup to USB flash disk, external portable hard disk or CD/DVD every data files and any other things such as documents, downloads, pictures, movies, programs and etc that you need and want to keep. You can also create a second partition with disk management utilities such as Acronis Director or Partition Magic, and then move the data files to the new partition.
5. Ensure that also you have CD or DVD setup media for the software applications that you want to install and use after wiping off your system from Vista.
6. If your OEM doesn’t provide you with recovery CD/DVD discs and Windows setup media discs (it’s because they’re stored in the hard disk in hidden location), you may want to burn a copy of recovery CD to CD/DVD first before you proceed, just in case the hidden partition is lost and you want to recover your computer to original state. (How-to Guide: IBM/Lenovo ThinkPad recovery CD)
7. If the system has SATA (Serial ATA) hard drive, locate the driver for SATA controller and put it in USB flash drive, diskette or CD first. If you have PATA (normal IDE) hard disk, simply go to BIOS CMOS to disable SATA or Native SATA mode if you don’t want to install XP on SATA hard drive. Else, you can also create an XP install disc with the SATA drivers integrated by using tool such as nLite.
8. In the BIOS, also set the CD or DVD optical drive as the first boot device in the boot sequence.
9. Put in the Windows XP installation CD into CDROM drive and boot up the computer by using the CD. You probably need to press a key when prompted with “Press Any Key to Boot from CD…”.
10. If you’re using SATA hard disk with driver on external media (not integrated into XP setup disk), remember to press F6 when you see the message at the status base: “Press F6 if you need to install a third party SCSI or RAID driver…” during the very initial stage of setup to load the SATA driver so that the SATA hard disk can be recognized.
11. Run through the setup wizard at per normal. However, when prompting for where to install Windows Vista, delete (by pressing D and then confirmation), create and format the Vista disk drive or partition (if you have multiple partition). And then choose to install on that just formatted partition or hard drive.
IMPORTANT: If you choose the wrong hard disk or partition with data to delete, you will lose your essential data.
Note: If the setup does not allow you to delete or format the Vista partition or drive, you will need to find a third party software that can recognize and read NTFS filesystem to clear the drive or partition first.
12. Enter any product key for XP. Vista product key will not work.
13. If you own a legitimate Windows Vista edition that allows for downgrade (See Vista downgrade rights), call Microsoft after performing the clean install of Windows XP Pro to activate the XP installation. Notify Microsoft that you’re downgrading from Vista and require to activate XP Professional or other version allowed newly installed. You won’t get a new Windows XP product key though. You will have to read out the long Installation ID plus your original Vista serial key, and Microsoft will provide an activation ID that will make the XP usable.
14. Install the drivers for your system devices.
15. Reinstall any software programs that you want to use.
16. Move back the data files and documents.
Thanks
Nov 03, 2009 | HP Business Notebook 550
Nec versa want to downgrade from vista to xp but booting from xp cd it does not detect harddrive, why? what can I do about it?
Sometimes booting from XP disk wont detect your hard disk,the problem is because the IDE driver which is needed for the identification of the hard disks are not at all avaible with the XP CD. So u have to download the corresponding IDE driver for your hard disk and then u can install that from the floppy drive during the installation . I think on installation XP set up will ask for a driver installation (third party installation). U can do this by using a floppy disk . If the floppy drive is not all available in your laptop then u can use softwares which can mix the IDE driver along with the XP set up U have. A lot of softwares are available for download for this purpose
Thank u and please rate my solution
Oct 22, 2009 | NEC Versa FX Notebook
How want to downgrade win vista to xp pro hp compaq v3000
If you have a Windows XP Pro installation disk, put it in the optical drive, restart your computer, on startup, go to BIOS settings (usually press [Delete] and set the optical drive as first boot device. Save changes and exit. When the computer starts it usually says to press any key to start from CD. Press any key and the windows installation will start. Make sure you format C: and you will downgrade to Windows XP Pro. If you want to upgrade to Vista again, you will need to know the keyboard sequence to start Vista from Its partition or have Vista install disk.
May 25, 2009 | HP Compaq Presario V3000T Notebook
I need to install an operating system on a Samsung q1 ultra
Suggest you use an external DVD drive, and put your installation disk in it. Then access the BIOS Setup utility.
In BIOS Setup, find the Boot Order menu. (Generally, along the top headings of the main menu, in BIOS Setup, or located in Advanced BIOS Settings) Set the first boot device to be CDROM. Be sure to Save your change.
This way the handheld, will boot from the installation disk, in your external DVD drive.
Should you be trying to downgrade from Vista to XP, you have to change the first boot device, in Boot Order to CDROM. If not, Vista won't let you overwrite it.
Vista is an upgrade over XP.
Apr 21, 2009 | Samsung Q1 Ultra Tablet PC
No hardware found when downgrading from vista to xp
first of all you might want to check the laptop manufacturers website to ensure that it can be down graded. after this and if it can be downgraded you might want to download the thrid party sata/scsi drivers from you hard drive manufacturers website so they can be used during set up. if all this fails perhaps using thrid party slip stream software like NLite to copy all the set up files ready for install. hope this helps.
let me know if it doesnt.
Mar 30, 2009 | Computers & Internet
Installing windows xp
You cannot install Windows XP over WIndows Vista. Microsoft has put a lock on the Vista software and will not allow you to downgrade to a lower software. The only way you can do it is to wipe your hard drive completely clean first with a disk deleting software or with the command "fdisk" at the DOS prompt. However, this is dangerous and I do not recommend it unless you have someone professionally trained to do it. It will wipe everything off of your disk and then you can load Windows XP.
Don't forget to rate his solution with 4 stars before you log out.
Jan 27, 2009 | Compaq Presario C700T Notebook
Downgrade from Vista TO Xp
Hi Bienana,
Steps must be taken in advance. Laptops are different from desktops. They have proprietary drivers that need to be available for boot or bad things happen. For example the CD-ROM won't be there any more. Then how will you load anything?
What you will have is a plastic rectangle that keeps asking for an operating system you can't install.
First, create a boot disk.
Second, create another boot disk.
Test them both. Make sure the CD works.
Now for some alternatives to formatting your hard drive.
Click here for a site thats offering Windows XP recovery CD's to those Vista owners that want XP. The offer is good through July 31, 2009.
Click here For the Toshiba site specifically for downgrading Vista to XP. It's a source for the drivers that inevitably don't get copied, what rights you have for which version and so on.
Both sites will give you some important insight before you take the plunge.
Mike
Dec 01, 2008 | Toshiba Satellite P205-S8811 Notebook
VISTA uninstal
the first thing you have to do is go to acer support website to see if your model supports downgrade to XP, in other words XP drivers for the model you have, if it does get back to me for more help, if it doesn't your stuck with vista i'm affraid
kind regards
Nov 17, 2008 | ASUS Eee 4G Notebook
Trying to downgrade to Xp
Sounds like you need to boot from the disk.Put the windows XP disk in the cd rom turn the computer off then turn it back on.The computer should see the disk and boot from it.Follow the prompts.You cannot downgrade if you are trying to run the installer after you computer has already booted,but you can load the operating system if the computer BOOTS from the XP disk.
Nov 15, 2007 | HP Compaq nx6310 Notebook
Acer Aspire 5100 Notebook Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
