Question about Panasonic DMR-ES25 DVD Recorder
Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
Panasonic DMR- EA18 DVD player/recorder - Remote control gets an error message "RC2"
i can not use the remote for anything ! everytime i try using the remote the unit displays "RC2"
is this a fixable problem ?
  • 2 more comments
  • m_mindes Jan 31, 2009
    same problem but mine says RC1
  • Anonymous May 12, 2009
    Panasonic makes worthless junk. had the same problem. It will not play my DVD's from other regions. This unit is going out with the e waste.
  • Anonymous Mar 23, 2014
    looking for codes to program my shaw universal remote to the dvd player. Called the satilite provider and the codes they have did not work.. help...
  • Anonymous Mar 30, 2014
    The DVD side works but cannot record
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Posted on Jan 31, 2009
  • james
    james Sep 09, 2014
    i have a rca rcrno4br remote and i did this and it did not work on my panasonic dmr-ez485v at all.tell me what up with this.
Panasonic DMR-EZ28 has RC2 display /l cant see an enter button to try pressing 1 then enter
the unit has been changed to remote control 2 mode. Look in the owner's manual and change the remote to mode 2 and you should be fine.
Feb 20, 2015 | Panasonic Televison & Video
Error rc 1 but cannot engage the setup in order to follow instructions provided by panasonic
press and hold the numbered button
corresponding to the code on the
remote control simultanously with OK button for approx 10 secondes
ex: if rc1 appear on panel press number 1 and ok button on the remote for approx 10 sec. ( if RC2 press number 2, if RC3 press number 3)
Oct 06, 2013 | Panasonic DMR-EZ28K DVD Recorder
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ485V. Remote stopped working when
Panasonic website under FAQs. Using code shown on dvd readout,
such as RC2, press 2 & enter or ok, hold for 2 seconds, and machine
will reset connection between remote & dvd recorder. So stupidly simple it works.
Feb 15, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
RC2 keeps appearing on my Panasonc DVD/VHS recorder...What do I do?
Hold down 1 or number after RC (RC1, RC2, or RC3), and enter/ok button on the remote for 6 second while pointing it to the recorder.
Jul 02, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Mar 14, 2009 | Panasonic DMR-EZ27K
RC2 problems
That solution works great! Thank you so much...just hold the Enter and 2 down for a couple seconds! Thank You!
Jul 04, 2008 | Panasonic DMR-ES20EG DVD Recorder
DMR--EZ48V
Your DMR is telling you that it is set to listen for RC2 but your remote is transmitting RC1.
Two choices for a fix:
1. Put the remote back into RC2 mode by simply holding both the ENTER and 2 button for at least 5 seconds.
OR
2. Reconfigure the DMR to listen for RC1 by going into the function menus and selecting SETUP. Look for the remote control option. Change it to 1, it will currently display the value 2.
Enjoy.
Mar 19, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-ES25 DVD Recorder Logo
1,159 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
