Question about Dell Vostro 1510 Laptop
My pc does not recognizing optical drive
My DVD rom is not functioning or even not recognising by laptop. Even its icon is not being shown in my conputer.
  • Dell Master
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps.
Posted on Jan 19, 2013
  • 79 Answers
SOURCE: Doesnt boot from DVD rom
Hi
I know it sounds a bit odd but were u using a bootable disk to boot?
If yes, then try epgrading ur BIOS version it may help.
Posted on Jun 01, 2008
  • 211 Answers
SOURCE: my dell laptop does not recognize my cd-rom drive. I
Try to boot from bootable cd, if it wont boot then you need new cdrom.
Posted on Mar 12, 2009
brownleopard
  • 15 Answers
SOURCE: the dvd rom drive does not read nor write
Sounds like it could be a faulty drive. Will it play any CD/DVD like a data or music one?
Posted on Jul 18, 2009
  • 76 Answers
SOURCE: TSSTcorp DVD+-RW TS-L632H ATA drive not recognizes
hi there!
-go to this website http://support.microsoft.com/kb/314060
-download and run the FixIT found at the middle part of the webpage
Cheers!
Posted on Oct 03, 2009
rcw1962
  • 2571 Answers
SOURCE: dvd rom is not readable or not showne in my computer
I have had the same problem and error code.
It started as an intermitant fault and then just stopped working.
You can try going into device manager and uninstalling the dvd drive, it will automatically reinstall.
I had to buy a replacement off ebay for about £20, they want about £100 for a new 1
Posted on Jul 10, 2010
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
Acer aspire 5740 DVD not recognized
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Oct 25, 2012 | Computers & Internet
Sony vgn a-150 not recognizing empty dvd media of any kind, but will read it.
You could try this tool for resetting your DVD-Rom. If this does not work then it could be you need a new Optical burner.
ClickMe
Dec 21, 2011 | Sony VAIO VGN-A150 Notebook
How do I remove the DVD-ROM from my OLD Compaq Presario 1200 Laptop?! All the service manuals that have been posted online for troubleshooting show pictures where the CD Drive for this model is on the...
Not every laptop has a removable, swappable optical drive. Here is a pdf that show you must remove the palmrest and keyboard before getting to the screws that hold the optical drive in the laptop.
http://h10025.www1.hp.com/ewfrf-JAVA/Doc/pdf/c00000588.pdf
Sep 11, 2011 | Computers & Internet
When I put a cd or dvd in the drive computer does not recognise there is a drive at all it is an acer 5315
consider to replace your dvd rom, because maybe it caused the dvd or cd cant read the cd or your dvd, maybe it caused the optic (head) of your optical drive is weak because of thr dust or dirty, before you replace your optical drive you can try to clean the optic using dvd or cd cleaner
Jan 16, 2011 | Acer Aspire 5315 Notebook
My computer no longer "sees"
hello
at end of this instruction set, see link to review more questions/answers,as your issue with CD/DVD ROM will vary .
This document applies to HP and Compaq desktop computers with Windows XP, Me, and 98. Use this document to make Windows and the CD writing software recognize the CD or DVD writer drive. Start at Step 1; do not skip to other sections until Step 1 has been completed. Step 1: Does Windows detect the CD or DVD drive? Use Device Manager to determine if Windows is recognizing the drive:
  1. In Windows XP, click Start , and right-click My Computer . In Windows 98 and Me, right-click the My Computer icon on the desktop.
  2. In Windows XP, select Properties , click the Hardware tab, and then click the Device Manager button. In Windows 98 and Me, select Properties , and click the Device Manager tab.
  3. Click the plus sign (+ ) next to DVD/CD-ROM Drives (or similar) category.
  4. Do the following depending on what is listed in the DVD/CD-ROM drives category:
    • If the CD or DVD drive name is missing , the drive is not being detected by Windows. Close Device Manager and skip to the section CD or DVD drive is not recognized by Windows .
    • If a drive name is shown but is disabled (icon is marked with a red X, c00877300.gif ), the drive has been disabled. Right-click the drive name and select Enable . You may have to restart the computer to complete the enabling process. The drive should work correctly once it has been enabled. NOTE: If the drive cannot be enabled, a required service or driver that the drive needs is not functioning or has been disabled. Click the plus sign next to IDE ATA/ATAPI controllers and troubleshoot any problems found according to any error codes in Device Manager. Resetting the BIOS may also resolve this problem.
    • If a drive name is shown but contains an alert icon (an icon marked with an alert symbol, c00877301.gif ), then use the section Using Device Manager error codes to troubleshoot the problem. You may also use the next section Disc burning software does not recognize the original drive to reset the drive configuration.
    • If the CD or DVD drive is listed as normal but your disc burning software does not recognize the drive, Device Manager shows no special icons c00877302.gif . Windows is detecting the drive but the writing software does not. Leave Device Manager open and continue with the next section Disc burning software does not recognize the original drive .
here is a link that will give you several other questions and answers to CD/DVD ROM issues.
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=11843&tmp_task=solveCategory&lc=en&dlc=en&cc=ca&lang=en&product=443069
please rate me with 4 thumbs UP to keep my services active
Dec 01, 2010 | HP Pavilion a810n (PP164AA) PC Desktop
Acer Aspire 5920G wont play dvd, it wont even recognise them!
If it recognises cd but not dvd it means the drive is faulty. There is 2 lasers one for cd and one for dvd. The dvd laser is faulty. It also means that it is not dirty lens because it reads cd's.
Aug 18, 2009 | Acer Aspire 5920 AS5920 Notebook
Toshiba won't recognise my dvd drive
check whether the driver is installed or if necessry reinstall the driver. U can even check the connections of the drive.
Jan 10, 2009 | Toshiba Satellite A100-S8111TD Notebook
BIOS cannot detect DVD rom
That is due to faulty DVD Rom. You need to replace your optical drive.
Jul 16, 2008 | Acer Aspire 5100 Notebook
Dell Vostro 1510 Laptop Logo
Alun Cox
