Question about Electrolux EI26SS55GS Stainless Steel Side by Side Refrigerator
My electrolux refrigerater compressor and fan is not kicking on
  • Official Brand Answer
  • 4,342 Answers
Hello 1clevergirl - Make sure you have cleaned the unit's coils and behind the toe grille at the bottom/front o f the refrigerator. If you are not hearing the compressor running and it is not cooling contact a service professional immediately. The compressor is constantly meant to go on and off frequently to keep unit at a constant temperature. In this case the refrigerator could possibly have a coolant leak or an issue with the internal sealed system including the evaporator fan.
Posted on Jan 22, 2013
How frequently should the compressor run on a fridge?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The model number provided does not register. Your model number is located on the inside wall of your fresh food section.
Your freezer is your only source of cooling. It will meet its setting before meeting the refrigerator temperature.
The normal setting are -2 to +2 degrees F. for the freezer and 35 -40 degrees F. for your fresh food section.
Your freezer will go about 10 degrees F. above the set temperature. Then when it reaches 10 degrees F. below the set temperature the compressor will kick in.
You have condensing coils either under your unit or a canister in the back which gets ride of the heat. When the condensing coil is plugged up with dust, this could affect your cooling by as much as 40 degrees.
I do not think this is your total problem.
Feel the face of your separator wall between your freezer and fresh food section. Is it hot?
Your problem is your condenser fan in the lower right back of you unit is burned out.
So, you can not dissipate the heat.
Remove the lower back cover. Take a common household fan to blow air under your unit.
Your compressor is running to make up for the heat that the condenser fan can not dissipate.
Feb 27, 2015 | Electrolux Refrigerators
FREEZER PROBLEMS ELECTROLUX ICON MODEL E32AR75FPS2 READS AN E ON THE FREEZER CONTROL HAS LIGHTS BUT NO COMPRESSOR OR FANS
Hi - Typically error code E on Electrolux freezer indicates an error with thermistor. Since the compressor does not kick on, I suggest contacting a professional to move forward accurately and properly diagnose freezer.
Oct 16, 2012 | Refrigerators
All the coils on the unit outside froze up
Hello, if the inside fan was not running then the evaporator coil cannot absorb enough heat to vaporize the refrigerant, and the suction line will freeze including the compressor. Liquid refrigerat instead of vapor passes thru the suction line into the compressor. Lack of airflow or a low refrigerant charge is what will cause the line to freeze. In your case it was no airflow
Jun 14, 2012 | Goodman Heating & Cooling
My whirlpool refrigerater is not cooling properly, the freezer is working but the fan in back turns freely by hand but I haven't seen it actually start by itself
replace fan motor. same thing happened to me but I can't see other end of fan wires.I will have to cut and solder wires for new fan...I have question on how to get that darn relay box off compressor to see where condenser fan wires go!!!
Jan 28, 2012 | Amana ATB1832AR Top Freezer Refrigerator
I changed the air compressor and the dashboard control panel last year and it has done ok. Now the temp. fan and the compressor fan won't kick in and the air compressor won't kick in also. Checked all...
You say temp fan?If you mean the cooling fans,then the ac is out of freon most likely,the freon has to be in the system,and enough to kick the compressor on,therefore turning the cooling fan on.
Apr 06, 2010 | 1996 Chevrolet Monte Carlo
A/C UNIT FANS BLOWS NO COLD AIR COMPRESSOR KICKS ON THEN OFF
check fins in the condenser coils (the fins on the outside part) for obstructions or alot of bent fins. should be free and clear. but chances are the freon level is low. can be serviced, but may be cheaper to replace.
Jul 20, 2009 | Frigidaire FAS156N1A Air Conditioner
My freezer and refrigerater will not get cold
u would have a leak in your sealed system if the fan and compressor are working and still not cold very expensive to fix
Mar 18, 2009 | Frigidaire FRT21H8 Top Freezer...
Not cooling
Sometimes when the evaporator fan goes out, it takes part of the motherboard also. (part number WR55X10552, which also subs into a WR55X10656) If this is the case, I would not expect the refrig to be running either. (If your compressor still runs, check door switch.)
Dec 09, 2008 | GE Refrigerators
Electrolux EI26SS55GS Stainless Steel  Side by Side Refrigerator Logo
333 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
