Question about Emerson CKS3020 Clock Radio
Display Off/Wave won't turn off
I just got this clock and the Off/Wave setting no longer works. It worked for a day and then quit. When I set it to Off/Wave, the display never turns off. Is there something I've done wrong or am not doing?
  • Anonymous Dec 26, 2008
    I have the same problem. I can not get the display to turn off when I set the display brightness control to "Off/Wave." I have tried just about everything (expept, of course, the possible solution that would work), including removing the battery and starting everything over. Any suggestions from anyone? Thanks!
I just purchased this clock too, and I can't get the Wave to turn OFF ! I have my alarms set to wake to radio...the Wave function is supposed to only function if you have the clock set to wake to buzz.
I may have to put a piece of duct tape over the Wave sensor to disable it.
Posted on Jan 30, 2008
How to set the clock on ge space maker micro wave
http://products.geappliances.com/appliance/gea-support-search-content?contentId=17872
Quoted from link above:
To set the clock on most GE microwaves:
  1. With the microwave door closed, press CLOCK.
  2. Touch number pads that reflect the time of day (1:45 would be 1, 4, 5).
  3. On some newer models, indicate AM or PM for morning or evening.
  4. Press CLOCK or START to lock in the time.
If you prefer not to display the time:
Disconnect the power for 30 seconds. After restoring power, do not set the clock. If your model has an ON/OFF clock display, you can choose not to have the time displayed. To choose this option, press the 0 pad for about three seconds. To Turn the display back on, press the 0 again.
Mar 21, 2018 | GE Microwave Ovens
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
How do I set the clock on the kenmore brew wave
To set the clock:
Find the OPTION button, it is the second top button to the left of the green clock display
1 - Press OPTION
2- Press 1 (to set the time)
3- Press the numbers for the current time of day - then press START (ie: 130 for 1:30 )
4- Press 1 for AM / 2 for PM
5- Time is set !
Jul 10, 2014 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Display not bright enough on Bose AWR1-1W clock radio
Yes...within a range. The display will automatically lighten and darken depending on the amount of light in the room. During the day or when there are bright lights in the room, the display will go to full brightness. When the lights go off or the room is otherwise darkened, the display will shift down to a lower brightness. You can make the "lower brightness" a bit brighter by holding down the CLOCK SET button and pressing the 'volume up' button.
Dec 26, 2013 | Bose Wave Am Fm Radio Awr1-1w Not Working...
I wrote a few days ago and did not get a response. Please, how do I change my bose raio/cd time back to regular time. It just went to military time. I do have grandchildren maybe they did something. ...
To set AM/PM (12 hour) or Military (24 hour) time
- Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
Jan 24, 2011 | Bose Wave Radio
My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Mar 26, 2009 | Bose Wave Radio
Have a radioshack atomic wall clock model #
1. Hold down WAVE/SET for about 2 seconds to enter the setting mode.
2. The time zone and DST (Daylight Savings Time) blink. Press + to select your time zone. Press - to turn DST On or Off. The default setings are PST and DST On.
3. Press WAVE/SET again to confirm the setting and enter the year setting mode.
4. The year digits blink. Press + or - to select the year.
5. Press WAVE/SET to confirm the year setting and enter date setting mode.
6. The date digits blink, press + or - to select the time.
7. Press WAVE/SET to confirm the date and enter time setting mode.
8. The time digits blink, press + or - to select the time.
9. Press WAVE/SET to confirm time setting and enter the clock and temperature setting.
10. The time format and temperature blink. Press + to select between 12Hr and 24Hr format. Press - to select between Celsius and Fahrenheit.
11. Press WAVE/SET to confirm whole setting.
SIGNAL: To aquire the signal for the first time, place the clock near a window facing Fort Collins, CO. If it fails, it will try again every 3 hours.
I hope this helps. I work for radioshack and i had a few extra minutes while at work.
Brett.
Mar 11, 2009 | SkyScan 86709 Atomic Wall Clock
Bose Wave Radio - clock display turns off after 1 minute
Hold down CD Mode button and press On/Off button to set display to always on.
Apr 09, 2008 | Bose Wave Radio
Wave Radio-dial face,display very dim.
Our Bose did the same thing after a power outage. This one doesn't have a CD button, so we tried holding down the Clock button and used the volume control and that seems to have fixed it.
Mar 23, 2008 | Bose Wave Radio
Emerson CKS3020 Clock Radio Logo
336 people viewed this question
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
