Question about Exercise & Fitness
Reebok z8 won't turn on
Plugged into mains, on/off switch on. Can hear power going to treadmill but pressing start on console does nothing.
    Top Expert:
  • 12,223 Answers
See the video and fix it. see too the block diagram
God bless you
Posted on Jan 19, 2013
SOURCE: Reebok REM 11300 have moved my treadmill, it has
I had the same problem, this is how you fix it.
remove the two black screws near the power switch and the plastic switch section should come away from the frame. Inside you should find a yellow wire, if you find this is disconnected from the other yellow wire, plug them back together and you should find the solves your problem.
Posted on Aug 30, 2009
SOURCE: treadmill kph to mph
No need to take console apart, power up the treadmill, take the safety key out then hold down the start button and the incline down button at the same time then insert the safety key. You'll now be able to toggle between KPH and MPH by using start button
Posted on Jun 15, 2010
SOURCE: hi my reebok treadmill was plugged in during a
how do i replace the drive belt on8700es
Posted on Aug 07, 2010
  • 218 Answers
SOURCE: hi i got a reebok i run treadmill power light on
# get a 12-18 volt dc battery fully charged(like one from a cordless drill)
# Make sure it is fully charged, because it won't work if not
# attach the + and - to the motor red is + and black is -
# If the motor turns slightly your motor is ok, if not the motor is bad and would need replaced
# if the motor is ok then your motor controller(the board with the metal) is malfunctioning and would need replaced.
Posted on Aug 11, 2010
Mustgo
  • 2359 Answers
SOURCE: I have a New Balance 1400 treadmill (manufactured
The only weak spot on the main controller board is the small rechargeable battery or a lithium button cell.
The memory battery is to keep the parameter information.
When the battery is damaged the liquid (electrolytic) drips downward on to other electronic items.
Any items under the "drip" pathway will need to be inspected and clean.
The battery can be on the front or rear on the main board,
Spend some time to locate this battery,
A simple $12 item can stop the unit from operating!
Please email me the part number or spec, info on the battery on reply.
Posted on Jan 08, 2011
I have a Reebok ACD1 treadmill. It turns on the and panel works as if is starting the workout, but the belt does not start moving. Any thoughts on what the problem could be?
Measure the voltage at the terminal of Main Motor for DC, between 0-120Vdc. if there are NOT, the Controller Board Motor is Faulty. Replace it.
this Board has 3 power supply: 1) Console Board 2) Elevation Motor 3) Main Motor. Some IGTBs are defective.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
LED Blink Patterns on the Control Board Treadmill
Nov 04, 2017 | Reebok Exercise & Fitness
Error code E-02 on a reebok z8 treadmill
Hi. Have error code e2 on reebok z8 can you advise what this is.
Thank you.
May 31, 2014 | Reebok Exercise & Fitness
I believe that my Reebok 8700es was plugged in during a power surge. I bought a dedicated extension cord and plugged it back into the wall and turned it on. Nothing happened. There were no sounds a
Step 1:
1) Please NEVER use extension cord, this will bring dangerous spikes, glitches, that will affect to your treadmills.
Disconnect it and use the specific outlet wall, for your machine
2) I recommend that you use the Software calibration for easy diagnose, troubleshooting and fix it. This will be clear the information code appearing the display.
Go ahead
Step 2:
The Steps for Newer Style Console Calibration:
  1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
  2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
  3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
  4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
  5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
  6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
  7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
  8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
  9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
  10. Press ENTER. You should see "SS" or "55" in the console.
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
  13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
  14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Step 3:
Jan 07, 2013 | Reebok 8700 ES Treadmill - Silver Service...
Proform 560 crosstrainer treadmill powers on belt won't turn
LUBE THE deck belt+ rollers bearing too. God bless you
proceed according with the video attached.
Jan 07, 2013 | Proform Exercise & Fitness
Reebok z8 feels like its on an incline even when it's on zero incline
1) readjust the speed sensor, clean it and tight the wires connector well
2) see the block diagram.
3) RUN the software calibration for diagnose, troubleshooting , fix it
4) lube the gear and shift elevation motor.
5) adjust the POT, a little and see if you have a better improve.
6) see the diagram, and proceed
God bless you
Jul 09, 2012 | Reebok Exercise & Fitness
Z8 reset
1)adjust the reed switch, clean , and tight the wires connector very welll, see the diagrams
2) Tight the ribbon cables, from keypads. tight the display board vs lower board.
3= Try again and proof.
God bless you
Jun 14, 2012 | Reebok Exercise & Fitness
Console lights up but when I press any of the buttons it won't start
I am having same problem. The console lights up but none of the button works, including TV and the fan.
I actually took everything apart, unplugged and re-plugged the connectors on the PCBs of both side of the console, it still didn't help. Looking at the electronic configuration, TV, fan, left and right panels are relatively independent. I believe the driver/motor module is still working, the most likely cause of this is the controller CPU.
Jun 05, 2012 | Reebok Vista Treadmill - RBTL13305
Pro form 365 won't start
Dear Sir:
I will help you, please do the exact step:
PROBLEM: The power does not turn on
SOLUTION: a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor is plugged into a properly grounded outlet (see page 10). Use only a single-outlet surge suppressor that meets all of the specifications described on page 10. Important: The treadmill is not compatible with GFCI-equipped outlets. b. After the power cord has been plugged in, make sure that the key is fully inserted into the console. c. Check the reset/off circuit breaker located on the treadmill frame near the power cord. If the switch protrudes as shown, the circuit breaker has tripped. To reset the circuit breaker, wait for five minutes and then press the switch back in.
Finally: check, the breaker from the home, if there tripped, check this, and Reset.
I will recomend when you finally set up, install Stabilizer Voltage, is cheaper us$15,00 aprox
Thank you in advance, sincerely.
Blessing, if you need additional help, please contact me.
E.CUADRA MANAGUA, NICARAGUA.
Sep 26, 2011 | Proform Crosswalk 365 Console Treadmill
I have two cardio zone treadmills which won't start. console lights but nothing happens. checked the two fuses for continuity, both good. what else can i check? s/n 35005624 and 35005616
Dear Sir:
I will help you.
Please in all this check in, use The Vom digital:
1. NoPower
o 1 Make sure that the surge protector being used isproperly grounded and turned on. Check that the treadmill power cord isproperly plugged into the surge protector. o 2 Check to see that the key is inserted in theconsole. o 3 Check the circuit breaker on the frame near thepower cord. If the reset/off circuit breaker has tripped, wait 5 minutes andthen reset the breaker by pressing the switch in.
4)Check the circuit breaker from the main panel( wall) and Measure the Voltage for properly 115VAC. if there .
Hoping help you, contac me if there are something extra.
blessing.
E.CUADRA Managua, Nicaragua.C.A.
Sep 13, 2011 | Cardiozone Exercise & Fitness
Exercise & Fitness Logo
112 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
