Question about Caterpillar CAT 150 KW Natural Gas Standby Power Generator
Natural gas generator starts but surges under load
Relocated and replaced gas regulator for same problem told by cat additional piping needed between regulator and engine. relocated 50 feet away. started and ran good but after replacing governor the problem returned.
    Prodigy:
    An expert who has answered 500 questions.
  • Caterpillar Expert
  • 573 Answers
Install a pressure gauge at the gas inlet regualtor, conform it isn't less than specs normall 11-13" WC pressure. test this when it is surging, it sounds like fuel, or also incorrect governor gain setting
Posted on Nov 17, 2013
Why is it surging under load?
Yep - the carb needs to be removed and cleaned out thoroughly to remove the clogging responsible for the surging. Motor needs a smooth supply of gas - look at what your car does when you jerk around with the gas pedal. Also check the governor area of generator since that keeps motor running at a certain fixed speed. If there is something wrong with it, that will also cause the problemo.
Sep 08, 2015 | Generac XG8000E - 8000 Watt Electric Start...
Generator is two yrs old only had a couple of outages maybe totaling thirty hrs Generator ran great and also ran every wk for its exerciser cycle. The generator didn't start on this cycle and the system...
Is this a natural gas fueled generator? Sounds like a fuel problem, i would go through the fuel system and find out whats wrong. If its a natural gas/propane unit its most likely a bad regulator or low pressure.
May 04, 2017 | Eaton Electrical Supplies
I have a Generac 60kw generator. When it runs under load the generator surges, causing the lights to go up and down. The only way to stop this is if I reach into the generator and grab what I think is the...
You did not specify fuel. If running natural gas or propane, check the diameter of your feed line. You need at least 1/2 to 3/4 pipe diameter on the NG or propane. At 60KW I would guess at least 3/4 maybe larger for NG.
Sep 16, 2013 | Generac Power Systems Commercial Series...
Surging
It definately sounds like a fuel problem, lack of fuel..I assume it is running on LP or natural gas. The hose running from the demand regulator goes to the carburetor/mixer. When it gets to the carburetor, there is an adjustable main jet. It is different on different models, but is usually easy to find. There is probably a screw slot in the end of the screw head and a spring under the head. Start it up after locating the screw and open the jet just enough to even out the running. It was factory set, but barometric pressure and altitude and different fuels in different areas will decessitate different settings.
Please let me know if this fixes your problem, Robert
Jun 27, 2013 | Kohler 30RESA 30kW Standby Generator...
Generator w/nat gas conversion kit sputters
THAT SOUNDS like a VERY LEAN condition. The exhause glowing is because its so lean. The stalling the sputtering. OPEN the gas valve more WHILE its running. With a load if possible.. If you have a tri fuel kit like I do, going from propane to nat gas I need to open the load block (gas valve) 2 turns more .Then it starts and runs great.
Jul 27, 2012 | Electrical Supplies
Generator with natural gas conversion intermittently sputters
running out of time and too rich
suggest that you call in an auto gas technician to check and adjust the regulator /converter for the gas to get it running right
Jul 03, 2017 | Grilling
The generator kicked the breaker of and was smoking and smelled like electrical
What type of load (electrical) was hooked up to this generation?? If the surge voltage and current was exceeded above the generator maximum for any length of time. There problems, it could be the regulator, insulation burnt off the windings.
I am taking a guess here. Now, 7100 Watts is it typical surge wattage. This mean that the generator will deliver 7100 Watt (voltage times current) this is know as the power factor. The actual operating load would be 6800 Watts and I would even operator the generator at its peak wattage. Something in the neighborhood of 10--15% less the peak wattage. Therefore a good positive theatrical Wattage would be 5800 to 6350 operating wattage. Then this generator would run all day.
Just remember Ohm's Law. Current plays a big factor in loading of a generator while the operation voltage is at 120 AC Volts. Example: electric motor; Now electric motor when starting will pull three time its operation current. Operating current for a 1/2 HP AC motor is 6 amperes but start this electric motor will require 18 amperes. This is one reason why they starting capacitors on smaller electric motors. Larger three phase electric motor can literal stop a generator cold...in its tracks. It put such a large demand on the generator it stops the engine powering the generator. I have seen crankshaft break because the generator could handle the heavy current load.
Remember, any time you are running a small gas powered generator. All ways figure what the load and surge current load will be before hooking up any generator. Normally this is figured in VA (volt/amps). Wish you lock. GB...stewbison
Sep 05, 2011 | Robin Subaru RGX7100 7100 Watt Gas...
I currently have a tank type natural gas water heater. My home is near Portland, Oregon, and was built in 1987. to change to a tankless gas water heater, can I use my existing gas vent pipe or will I have...
Depends on what type of vent pipe it is. Usually a house of that age, a better vent pipe is needed. Also, tankless water heaters need a more direct path to exit exhaust then the tank water heaters. Chances are you will need to either just replace the type of pipe to one that can withstand higher heat and/or relocate the pipe exit to a more direct route outside the house.
Mar 01, 2011 | Water Heaters
Do I need a part to convert my Maytag gas dryer/washer combo back from propane to Natural Gas?
Yes you can, but whether you should is another matter. I purchased a new dryer and needed it to be propane ready...you need to get the proper orifice (which lets the gas in to the burners) changed out. Natural gas orifice has a larger hole than a propane orifice. In addition, the regulator must be modified. It may involve flipping an insert under the cap (typical of stoves) or it may require conversion parts packed in the conversion kit (order one specific to your drier). This regulator is part of the piping within the back of the drier.
Incidentally, conversion orifice(s) should be included with the drier and screwed to the body in a clip. When you change it over and label the equipment as converted to propane, put the old natural gas orifice in the clip and screw it back onto the body. Put the instructions in a paper envelope and tape to the outside of the body of the drier.
Apr 27, 2010 | LG WD-3243RHD Front Load Washer / Dryer
Questions about replacing electric cooktop with gas (GE JPG331)
Hi, I can get you the regulator for $66.95. The part would have to be ordered. Yes it does need the regulator. I'm sorry but there are no generic regulators for this and for the safety of your family, you do not want to cut corners if possible. Yes you will need a threaded T to connect to existing pipe. Please let me know if I can assist you further with the [art.
THanks
Vic
May 17, 2009 | GE 30 in.JGP330 Gas Cooktop
Caterpillar CAT 150 KW Natural Gas Standby Power Generator Logo
165 people viewed this question
Top Caterpillar Electrical Supplies Experts
gbob59
Lawrence Oravetz
ray gallant
Are you a Caterpillar Electrical Supply Expert? Answer questions, earn points and help others
