Question about Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum
I have a Dyson DC 15.need to replace the motor cover assy. can't get the part under to pop off . what holds this down.
Broke the motor cover assy. need to take the cover below off also but when remove the screws it won't pop off. what holds it down. any advice on how to remove this part.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 36 Answers
Check the manual for the troubleshooter: Dyson Dc15 Manual
Posted on Nov 20, 2013
  • 5 Answers
SOURCE: Dyson DC07
Try this page: -
http://www.fixya.com/support/t192124-overheating_dyson_dc07
Regards Gualo
Posted on Mar 21, 2009
  • 83 Answers
SOURCE: Dyson DC-07 Hose Wand Spring Came Out. How to put back in?
You'll see that there is a round piece with a cross shape on the inside of the button wand release button - place the end of the spring over the cross - you'll see the same cross on the collar of the machine...it'll take some doing, but line the other end of the spring up with the cross and pop the button back into place - be sure to click it onto those two gray circular/oval shaped divets at the bottom where the release button connects to so that the button stays in place.
Posted on Jul 30, 2009
Dysonteam
  • 167 Answers
SOURCE: the brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 22, 2010
DysonInfo
  • 107 Answers
SOURCE: Dyson dc14 Animal motor brush replacement
By the time the brushes are shot, so is the armature. You need a motor.
Posted on Nov 30, 2010
SOURCE: dyson dc 15 brush roll
Open the right side of the vacuum with a hex head screw driver. There are 4 screws. Inside you will find a circuit board.
1. Make sure the varistor (S20K150) is not blown, these models seem to have an issue with this. It is a flat blue "quarter" looking component near the top edge of the circuit board.
2. At the bottom of the circuit board are two white wires connected via push on connectors. Remove these from the circuit board by sliding them away from the circuit board. Power on the vacuum and engage the drive button. If the lower motor still does not engage check step 3.
3. A blue and yellow wire runs off the bottom end of the circuit board. These are the wires powering the lower motor. Check continuity with a multimeter and make sure they are not broken. I have seen where these wires will break as they run through the housing of the vacuum. If they are broken, replace them with any wire of the same gauge.
Posted on Feb 20, 2011
My dyson dc 25 sparks near the rotator roller attachment, what can I do?
Hi Cindy, it's Jack at Dyson.
If you can see sparking coming from inside the cleaner head, please do not continue to use your machine until we can help resolve this. It's likely the cleaner head will need to be replaced - once we've taken a few further details, we'll be able to confirm if this is covered under your Dyson parts and labour guarantee.
At your earliest convenience, please call our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU) for further assistance.
Dec 16, 2014 | Dyson Dc 25 Animal Upright Bagless Vacuum...
Does anyone have "duct" assembly instructions for Dyson DC 24? (Not the owners assembly manual)
Google Dyson. co On the drop down window, find your model, type in Dyson DC 24, at bottom of page click on shopping info, click parts. you can order from there.
Oct 19, 2014 | Dyson Ball DC24 Bagless Upright Vacuum
Replace bearing on dyson dy-916217-01
I have a bad motor myself. The bearings make loud noises and the wife is on me to fix it. I can only replace the entire motor because the bearings are not available that I am aware of. The motor runs about $50, cheaper than having them fix it. Dyson does not have parts listed on their pages but you can Google the vacuum/parts and find them. Working on a Dyson is like working on an car. You have to take everything apart to get to what you need to replace. Good luck.
Nov 08, 2013 | Dyson DC17 Brushbar Motor Assy 916217-01
HOW TO TEST A DYSON MOTOR.
A DC-7 has a Panasonic motor which is the best part of it. I have never seen one of those fail within the life expectancy. You do have to consider that a Dyson was never designed to last more than 5 years. The newer Dysons are only designed to last 2 years. If the motor runs for 15 minutes and overheats, my first guess would be a faulty heat sensor on the motor. If it ran only 30 seconds or so, probably a bad motor.
Aug 08, 2017 | Dyson DC07 Animal Bagless Upright Cyclonic...
Brush won't turn on dyson dc07
There was a belt that was to be attached to the motor shaft under the belt cover, be sure that it didn't pop off. the recommended fix is to replace the clutch, not the belts in the clutch. if you only replaced the belts it could still be a bad clutch.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Feb 16, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Beater bar not working on newer ball pet unit
HighnTools posted this solution some time ago. I think it can help you solve your issue.
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
Aug 29, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Brush does not spin all the time
HighnTools posted this solution a while ago. This might be related to your problem:
The above was from HighnTools.
May 11, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Belt replacement
It's a fairly simple job. The belt just loops over the end of the beater bar and motor shaft. Need to take the cover off the beater bar housing to get to it. Most difficult part is stretching the belt while putting the beater bar back in the housing.
Charlie
Aug 30, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater brushes don't work, what to do? They only work when the canister is in about an 85 degree up position.
This appears to be a loose connection. The below post was answered by highntools a while ago. It probably is related to you problem.
There have been several people who reported loose or burnt wires to be the culprit for the brush bar not working. The DC15 does not use a belt, but a motor that is control by the circuit board. And I really believe that in your instance, the problem is a loose wire between the circuit board and the brush motor.
Jul 12, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Beater bar on Dyson upright won't turn when handle is lowered
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Dec 20, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Dyson DC15 All Floors - The Ball Bagless Upright Cyclonic Vacuum Logo
121 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
