Question about RCA WHP141 Consumer Headphones
The head strap keeps breaking on my whp141 headphones
I have purchased many whp141 headphones and like them...but the head straps break often
3 Suggested Answers
odiebugs
  • 949 Answers
SOURCE: RCA headphones - nicad or alkaline batteries WHP141
BATTERY INSTALLATION AND INFORMATION
Your wireless headphone unit requires two rechargeable AAA batteries.
Rechargeable batteries are uncharged when you purchase them. Before
you can use the wireless headphones, the batteries must be charged for
16 hours. Follow these steps to install and charge the batteries.
Installing the Rechargeable Batteries
Take care to follow these steps to correctly install the batteries.
1. On the right headphone, locate the battery compartment (1).
Use the finger depression on the compartment to turn the battery
compartment cover counterclockwise to remove the cover.
2. Insert two AAA rechargeable batteries, carefully following the
markings inside to ensure the batteries are inserted properly, with
the + and - ends in the correct positions.
3. Replace the battery compartment cover.
Charging the Rechargeable Batteries
To recharge the headset unit, follow the directions below. Note: The
cradle/transmitter on the WHP141 is not a recharging cradle, although
you may place the headset in the cradle during recharging.
Follow these steps to recharge the NiMH rechargeable batteries.
1. Make sure the ON/OFF switch (2), located on the right headphone,
is in the OFF position.
2. Connect the AC/DC main power adapter to the DC IN power
supply socket (11), located on the back of the cradle/transmitter.
3. Plug the adapter into an electrical outlet.
4. Connect the charging cable (10), located on the back of the
cradle/transmitter to the recharging input (3), located on the right
headphone. The headphones can either be placed in the
cradle/transmitter or placed next to the unit. If the headphones are
connected correctly, the charging LED indicator light on the
cradle/transmitter (8) illuminate.
Posted on Mar 27, 2009
  • 51 Answers
SOURCE: need service phone #
All RCA Television Support Numbers hours of operation are 9 AM - 9 PM Monday - Friday EST and 10 AM - 7 PM EST on weekends. bullet_2by2.gifRCA Audio / Video Product Support: 800-433-7316
bullet_2by2.gifRCA Digital Audio Product Support: 866-449-7112
bullet_2by2.gifRCA Clock Radios and Camcorders Product Support: 800-645-4994
bullet_2by2.gifRCA DVD Product Support: 866-444-6478
bullet_2by2.gifRCA Accessory Product Support: 800-264-8854
bullet_2by2.gifRCA Telephone Product Support: 800-511-3180
bullet_2by2.gifRCA MSNTV Product Support: 800-722-9599
bullet_2by2.gifRCA DRC8335 Product Support: 877-805-0519
Posted on Apr 05, 2011
Testimonial: "great! Thank You so much tom.bluett@yahoo.com"
Would earth strap break cause a break down?
yes, disconnected earth strap (body ground) will cause your car to break down.
Jun 11, 2013 | Holden Barina Cars & Trucks
My Frigidaire Affinity dryer keeps wrecking my clothes by breaking straps
In any front load machine, whether washer or dryer, the manufacturer will suggest to have the items with buttons or straps, or small items, put into a mesh bag. Now you can have a professional check to see if you have too much of a gap between the drum and the door itself.
Jul 27, 2012 | Frigidaire Dryers
I'm trying to get the bottom pulley off to get to bottom timing cover & can not get the bolt out, any suggestions?
There's only two ways to get it off...1) impact wrench, 2) you can try and use a strap wrench wrapped around the pulley to hold it in place while you remove the center bolt. Be sure and get a high quality strap wrench or the strap will just break while your trying to break the bolt loose. If you do a lot of diy mechanic work I would highly recommend an impact wrench. If you don't have a large enough air compressor you can get a cordless model that will do the job just as good.
May 13, 2011 | 1993 Toyota Camry V6
My DKYN is a ladies large D shape stainless steel case quartz. White leather strap. I have lost the tiny pin head that holds the strap pin in any suggestions please
sounds like a broken spring bar.They break all the time and can be replaced by any good jewellery store while you wait.
Aug 17, 2010 | Watches
I have this Schwinn Trailblazer Bike Trailer and Stroller. It is wonderful. However there is a strap that is bolted on to the main frame and to the spring end that connects to the bike hitch. My husband is...
This particular strap is a safety backup strap. This strap is just for in case that the first one securing the trailer to the bike breaks so it will still stay connected to your bike.
May 20, 2010 | Schwinn Trailblazer Bike Trailer
Changing gasoline pump but tank screws lose but dont come out , they keep turning..its a Bonneville 1995...does it have a bult on top...how do I take tank down??
The nuts on top are usually held with a weld, but not uncommon for them to break loose and spin. Should be 2 straps, and one bolt at one end of each. You may have to get wrench, or vise grips up in there to stop nut from turning. Lots of penetrating spray on them, they will probably be pretty rusted at the threads.
Dec 24, 2009 | 1995 Pontiac Bonneville
I haveolder radio shack 900mhz stereo head phones. it says it uses nimh 3.6volt 280mAh battery pack. I cannot find a replacement any where. Any help would be greatly appreciated.
Most of the battery can be build and replace. Look at specialist like onlybatteries.com where you can buy any kind of battery cells, with tabs if need that you can weld, or make weld at your local electronic shop repair. Keeps the old pack, open it with a xacto without breaking it or a dremel and check how its made. its usually AA nimh battery...
Oct 07, 2009 | RCA WHP141 Consumer Headphones
When it is running it moves a lot on the tile floor we have it on. What is the best way to stop it from moving? It is a GE Profile washing machine
You will need to replace the rubber straps. There is one one each conner, just under the top. If you push the tub over to one side and run your hand under the top and feel. You will find a rubber strap that connects from under the top to the outer tub. These are bad to break. You need to replace the broken ones before you use the machine again. These keep the outer tub from banging into the inside of the machine causing it to break and leak. When this happens, the tub list for around $160.00 and it take about two hours to replace it. It's cheaper to buy a new machine it the tub breaks. GE's are known for this problem.
Aug 19, 2009 | Washing Machines
Maxi Cosi Priori Shoulder strap folded and caught fast!!
Oh yes I have been there!
I am afraid it took me 2 days of brute force. You'll break before the clip does!
I recall using pliers..
Sep 03, 2008 | Maxi-Cosi Priori
RCA WHP141 Consumer Headphones Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
