Fujutsu ast18lsbcw ijust leaked water from right hand side? is pipe blocked main reason for this? best way to do it myself?
  • 400 Answers
Yes more than likeley drainpipe is blocked. The simplest way is to blow (by mouth) on the outside pipe. This should dislodge any sludge causing the blockage in the drainpipe or drainpan.
Posted on Mar 05, 2009
Siemens SE26T550GB/25 small leak from pressure chamber when filling unit. Further leak observed in the same corner of the machine further into cycle. Machine fills and heats OK but seems to stick with "1...
The pressure chambers and side tanks are prone to clogging up, you can back flush them but with limited success. By the time you have removed and flushed them you are just as well to replace them. Also there is a corrugated pipe about 1 inch in diameter on some models running down to the sump that blocks and water will overflow from the vent on the side tank. The sides will come off, usually 2 screws down the front frame visible with the door open and one at the back. The humming you are hearing with be the drain pump running as it is thinking it is flooded as there is water in the base causing the machine to end its program and drain before its finished and showing 0.01 on the screen.
Hope this helps.
Oct 30, 2014 | Washing Machines
Not filling with enough water
If you remove the lid and looking at the front of the d/w take of the lefft side panel, at the right bottom on the side you should see a pressure chamber with some micro switches and a red lever. This is possible blocked along with the hose that is attached to it (to the right, behind the chamber) clear them both and retest with the side panel off to check for good flow and to make sure you have not created a leak.
Good luck
Jul 08, 2010 | Neff 24 in. S5555X0GB Built-in Dishwasher
Ive got water pouring from the right hand side of the block when i fill my radiator. Its a ford focus saloon 2001 2.0
Hi !
When you sat "Block" you mean from the radiator block or the engine Block.???
Its easier to repair radiarors.
If its the engine block .... cleck if the water is leaking from the side wall or there is a drain tap that is not closed properly..... this is near the lower portion of the block on the right hand side .....if it is from the drain tap then you are lucky... just tighten it...
else.....
you will need to find the exact place of leak and block it with an industrial adhesive.
This usuall happens when you try to fill the radiator with cold water while the BLOCK is still HOT. The metal cracks.
Regards
Berry.
Feb 01, 2010 | 2001 Ford Focus
Washing machine pouring water out on final spin
The rubber pipe under the machine is usually parished......
Feb 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
BOSCH SPS5462GB/19 No water seems to be entering. Programmer switch moves to first position then cuts out. Have checked inlet water filter is clear. ??
Found the problem after stripping down around the main pump area.
The air pipe connected to the pressure switch on the front right hand side is connected to a small plastic box which in turn is connected to the flow pipe that fills the machine,and the box was completely blocked with slug which stopped the pressure switch from operating and so prevented the water input solenoid from opening. Hence no water would come into the machine
Jul 13, 2008 | Dishwashers
Maytag quiet plus II - leaking water
Check under while the washer is filling and draining. You could have a loose clamp on a hose, the seal on the shaft may only leak while doing these. On the other hand, more times than not, rodents seem to enjoy chewing on washer catch basins.
Jun 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Leaking water inside
Dear brians933,
If the air conditioner is window / wall mounted please make sure that it is tilted backwards about 3/8 inches. The front side should be upward and the out side portion of the AC downwards. If the drain pipe is blocked the water will leak inside. Please run a stiff wire or thin rod in the drain pipe and then **** the water out please donot blow in, the pipe is getting more blocked this way.
Hope this solve your problem.
Regards,
ramesh22
Jun 25, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
My is70c tumble dryer is leaking water from the main filter at the bottom?
This model is a condenser dryer, at the bottom of the machine if you open up the flap you will see the condenser on the left hand side, the manufacturer recommends that you clean this unit once every month and also empty the reservoir and clean the fluff filter after every use. While this may seem like a lot of hard work there is a very good reason for this. I suspect that your problem is due to a build up of fluff and or gunge in the condenser and bottom of the machine. Remove the condenser and give it a good clean of all fluff, you can run water through it either in the sink or bath as the best way to do this it is very fiddley using just your hands. Next check to see if there is a build up of water in the back the machine where the condenser usually sits, you will have to lie on your stomach and reach into the back of the machine (OBVIOUSLY ENSURE THAT YOU HAVE UNPLUGGED FROM THE MAINS SUPPLY BEFORE YOU DO THIS!) along the floor of the machine you will feel a channel cut into the plastic which runs into the sump at the back of the machine, if you have not cleaned the machine properly this is probably blocked and is the culprit. With this blocked the water is unable to travel to the pump that takes the water from the condenser into the resevoir at the top of the machine, and therefore it stays in the machine and can get thrown about onto the electrics and could cause the machine to cut out and trip your electrics! If this is not blocked check the black rubber pipe leading from the pump to the reservoir is not blocked, failing that perhaps the pump (in the plastic case at the back of the machine) is faulty and will need to be replaced.
Apr 29, 2008 | Whirlpool LER4634J Electric Dryer
WF000
hi the filter is located at the back of the machine you have to unscreew the pastic panel at the bottom..look inside at the right hand side black hose with big jublie clip the filter is inside there just undo the big clip ....expect WATER !!!!!!!!!! when done make sure you push the hose on properly !!! didnt do that myself ...and had to mop up again !
DONT FORGET TO UNPLUG THE MAINS LEAD !!!
Apr 27, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Fridge Leaking water from front right hand corner
yes, get a pipe cleaner and put in to the hole to try and clear if not from the back you will find the pipe which will be clipped to a plastic tray on the compressor. unclip and blow up the pipe this will always clear the blockage.
Oct 19, 2006 | AEG SK78800I Compact Refrigerator
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
