Question about Konica Minolta bizhub 350 All-In-One Laser Printer
C - 0998
How do you remove the malfunction detected error C-0998?
    New Friend:
    Problem Solver:
  • 6 Answers
Como puedo solucionar me sale error c1183
Posted on Jan 20, 2013
My ricoh photocopier machine is giving error code 522 pls what is the solution
Quoting link:
"This error is a fusing thermistor error, it can mean:
The fusing lamp is not connected. Reconnecting it may solve the problem.
Thermistor is bent or gone bad. You may need to replace it.
Or, the thermistor position is incorrect.
To try and reset the code press:
Clear Mode, 107, Clear/Stop and hold for 5 seconds."
http://terraofficesolutions.com/forum/index.php?topic=7.0
http://www.thecopierexchange.com/2017/01/updated-ricoh-error-codes/
Code
Possible Causes
SC500Main motor/transport motor lock/Fusing motor error
SC501Drawer 1 lift motor malfunction
SC5022nd or 1st tray lift motor malfunction
SC503Drawer3(or 2nd) lift motor error
SC504Drawer 4 or 3rd lift motor malfunction
SC505LCC Tray malfunction
SC506Paper tray motor lock
SC507LCT main/feed motor lock
SC508Rear fence drive motor
SC509Drawer 3 LCT right fence error
SC510LCT lower limit error
SC511LCC motor lock
SC515Drawer left guide drive motor error, Tandem rear fence motor error
SC516Drawer 1 side guide motor error
SC520Paper tray error/Duplexer jogger drive motor error
SC521Duplexer jogger driver motor error 2
SC522Duplex-Side fence jogger HP error
SC524Duplex-End fence jogger HP error
SC530Bypass feed motor lock/fusing fan motor error
SC531Fuser/Duplexer reversing motor error
SC541Fuser thermistor open/ Hot Roller thermistor open
SC542Fuser Temperature warm-up error
SC543Fuser overheat error1
SC544Hot roller fusing lamp lower limit temperature detected
SC545Fuser lamp overheat error 2
SC546Fuser ready temperature malfunction
SC547Zero cross signal malfunction/ Fusing temperature does not increase
SC548Fusing installation error
SC550Fusing web end
SC551Pressure roller thermistor open
SC552Pressure roller warm up error
SC553Pressure roller overheat
SC554Pressure roller low temperature abnormal
SC555Pressure roller ready temperature abnormal
SC557Pressure roller temperature does not increase
SC558Zero cross signal abnormal
SC590Exhaust/Fusing fan motor error/used toner collection motor error
SC591Toner supply motor error
SC592Toner bank motor error
SC599Copy exit tray motor lock
Troubleshooting Tips:
SC500:Too much load on the drive mechanism
Some gears or other rotating parting has been jammed.
Developing unit is over toned.
Main motor or its driving board is defective.
Before replacing motors or sensors, first check the mechanical load.
SC 541:Fusing thermistor open:
Machine is plugged into low line voltage.
Fixing thermistor is defective or out of position.
Some loose connection
Power Supply board defective
SC590:Left exhaust fan motor error
Loose connection of the exhaust fan motor.
Too much dust in the fan causing too much load on the motor driver.
(e) 6XX: Communication errors
CodePossible Cause
SC600Communication Error Between Main Control and Operation Panel Boards
SC634Key/ Card Counter Device Error
SC636Communication Error Between BICU & Paper Feed Control PWA
SC696Communication Error Between Engine Boad and Finisher
SC621:ADF connection error
An incorrect ADF is installed on the machines.
The connector of the ADF is removed while the machine is in the energy save mode.
(f) 7XX: Peripherals Problems
CodePossible Cause
SC700RADF Original Pickup Malfunction
SC702RADF Feed Motor Lock
SC703RADF Transport Motor Lock
SC704RADF Original Exit Motor Lock
SC705RADF Bottom Plate Motor
SC721Sorter Bin Motor
SC722Finisher/Sorter Jogger Motor
SC727Finisher Stapler Rotation error
SC728Finisher paper stack height error
SC733Finisher Lower Tray lift Motor
SC760ADF Gate Abnormal
SC770Display Editor Abnormal
SC700:ADF pickup problem
Home sensor is defective
ADF board or pickup roller mechanism is defective.
SC733:Finisher lower tray lift motor
stack height sensor or lower tray limit sensor may cause this problem
(g) 8XX: Controller Errors
CodePossible Cause
SC800Startup Without Video output End
SC804Startup Without Video Input End
SC818Watchdog Error, Software Malfunction
SC819Kernel Mismatch, Download Firmware again
SC820Self Diagnostic Error,Download Firmware again
SC855Wireless LAN card problem detected
SC857USB Interface Error Detected
SC868Incorrect Data is detected in the SD card
SC870Address Book Data stored on the hard disk was abnormal
SC 826:Self diagnostic error:
NVRAM on the controller board is defective and must be replaced.
SC855:Wireless LAN card error
Poor Connections between LAN card and the printer
Defective controller board.
Defective wireless LAN card.
Disclaimer:
Please note that this detail is just for information. Do not try to repair a machine if you are not a qualified technician. Technicians should also not take this information as a substitute of technician manuals.
May 02, 2018 | Ricoh Office Equipment & Supplies
What is error 30 for t3.
Error 30 means "Malfunctions related to the shutter have been detected". Recharge the battery, remove and replace it after about 20 seconds, then do a reset to default settings through the camera menu. If it still won't work you'll need send it in for repairs.
Aug 21, 2014 | Canon EOS 1100D / Rebel T3 Digital Camera
On the dash board it appears with is writing: Malfunction Detected, inform the service representative for the error code
Whats the make and modle of the machine? Also what are the numbers that fallow Malfunction detected.
Mar 12, 2011 | Office Equipment & Supplies
Yzf r6s error 30 how to fix or remove
Fault Code: 33
Diagnostic Code: 30
Symptom: Open circuit is detected in the primary lead of the ignition coil (# 1, #4).
Probable cause of malfunction:
Open circuit in wiring harness.
Malfunction in ignition coil.
Malfunction in ECU.
Malfunction in a component of ignition cut-off circuit system.
If the bike turns over but doesn't start I would check the kill switch and from there the wiring harness to the coils.
I’m happy to assist further over the phone at https://www.6ya.com/expert/walker_61ab9022a1a05bd2
Dec 28, 2010 | Yamaha YZF-R6 Motorcycles
Error f1 en sharp sf 2530
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} F1 00-sorter communication trouble detected
01-paper jog malfunction detected
02-transport motor malfunction detected
04-indexer lower limit detected
05- indexer upper limit detected
06-shift motor malfunction detected
Aug 01, 2010 | Sharp SF 2020 Copier
Error 80
Error 80 means "Malfunctions related to the electric control or images have been detected".
Try to switch camera off AND remove battery from camera. If it does not help - bring camera to service center, malfunction causing error 80 can be serious.
Jun 13, 2010 | Canon EOS 50D Digital Camera
Yamaha R1 2007 error code 36
Error Code #36 IS faulty ignition > "Open cicuit detected in the primary lead of ignition coil #4."
Probable causes are:
-open or short cicuit in wiring harness.
-malfunction in ignition coil.
-malfunction in ecu
-malfunction in component of ignition cut-off circuit system.
Hope this helps
May 13, 2010 | 2007 Yamaha YZF-R1
Printer displays c-0096 on display
C0096 Image Transfer Belt pressure/retraction failure
please have this services as this is a part of the printer that is not consumable.
Code Item
C0000 Main Motor’s failure to turn
C0001 Main Motor turning at abnormal timing
C0016 Bk PC Motor’s failure to turn
C0017 Bk PC Motor’s turning at abnormal timing
C0018 Color PC Drum Motor’s failure to turn
C0019 Color PC Drum Motor’s turning at abnormal timing
C001A Color Developing Motor’s failure to turn
C00l B Color Developing Motor’s turning at abnormal timing
C0040 Suction Fan Motor’s failure to turn
C0046 Fusing Cooling Fan Motor/1 failure to turn
C0048 Fusing Cooling Fan Motor/1 or Fusing Cooling Fan Motor/2 failure to turn
C004C Ozone Ventilation Fan Motor’s failure to turn
C004D Toner Suction Fan Motor’s failure to turn
C004E Power Supply Cooling Fan Motor’s failure to turn
C004F Cooling Fan Motor 2’s failure to turn
C0060 Fusing Drive Motor's failure to turn
C0061 Fusing Drive Motor turning at abnormal timing
C0094 2nd Image Transfer Roller pres-sure/retraction failure
C0098 Fusing Pressure Roller pressure/retraction failure
C0200 Cyan PC Drum Charge Corona malfunction
C0202 Magenta PC Drum Charge Corona malfunction
C0204 Yellow PC Drum Charge Corona malfunction
C0206 Black PC Drum Charge Corona malfunction
C0208 PC Drum Charge Corona malfunction
C0400 Exposure Lamp’s failure to turn ON
C0410 Exposure Lamp turning ON at abnormal timing
C0500 Heating Roller warm-up failure
C0501 Fusing Pressure Roller warm-up failure
C0510 Heating Roller abnormally low temperature
C051 1 Fusing Pressure Roller abnormally low temperature
C0520 Heating Roller abnormally high temperature
C0521 Fusing Pressure Roller abnormally high temperature
C0650 Scanner Home Sensor malfunction
C0660 Scanner overrun failure
C0900 Tray3 Elevator failure
C0910 Tray2 Elevator failure
C0950 Tray4 Elevator failure
C0960 Bypass lifting motion failure
C0990 LCT Elevator Motor malfunction(Elevator malfunction)
C0991 LCT ascent motion failure(soft limit error)
C0996 LCT Shift Motor malfunction
C0997 LCT shifting failure
C0998 LCT ejection failure
C099C LCT Shift Gate malfunction
C099D LCT communications error
C0805 Finishing option Paddle Motor malfunction
C0B20 Finishing option Stapler Unit CDdrive failure
C0B2S Finishing option Stapler Unit SlideMotor malfunction
C0830 Finishing option Aligning Bar moving mechanism malfunction
C0B39 Finishing option Front AligningMotor malfunction
C0B3A Finishing option Rear AligningMotor malfunction
C0B48 Finishing option Exit Roller pressure/retraction failure
C0B4A Finishing option Storage Roller pressure/retraction failure
C0B4C Finishing option Exit Motor malfunction
C0B50 Finishing option stapling mechanism malfunction 1
C0B55 Finishing option Staple/Folding Motor malfunction
C0B75 Finishing option Punch Cam Motor drive failure
C0B76 Finishing option Punch Unit Board malfunction
C0B77 Finishing option Punch Side Registration Motor malfunction
C0B78 Finishing option Punch Motor malfunction
C0B79 Finishing option Punch Sensor malfunction
C0B80 Finishing option Shift Motor mechanism malfunction
C0BA0 Finishing option Elevator drive malfunction
C0F30 Abnormally low toner density detected Cyan ATDC Sensor
C0F31 Abnormally high toner density detected Cyan ATDC Sensor
C0F32 Abnormally low toner density detected Magenta ATDC Sensor
C0F33 Abnormally high toner density detected Magenta ATDC Sensor
C0F34 Abnormally low toner density detected Yellow ATDC Sensor
C0F35 Abnormally high toner density detected Yellow ATDC Sensor
C0F36 Abnormally low toner density detected Black ATDC Sensor
C0F37 Abnormally high toner density detected Black ATDC Sensor
C0F3A Cyan ATDC Sensor adjustment failure
C0F3B Magenta ATDC Sensor adjustment failure
C0F3C Yellow ATDC Sensor adjustment failure
C0F3D Black ATDC Sensor adjustment failure
C1200 Standard controller configuration failure
Cl 203 File Memory mounting error
C1204 Memory capacity discrepancy
Cl 220 Image Input Time Out
C1229 Image Output Time Out
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
C1250 Compressor 0 command buffer stop failure
C1251 Compressor 1 command buffer stop failure
C1252 Compressor 2 command buffer stop failure
C1253 Compressor 3 command buffer stop failure
Cl 261 Compression hardware timeout
C1265 Extraction hardware timeout
C1279 PCI-SDRAM DMA operation failure
C1290 Compression/extraction timeout detection
C12B1 Image processing ASIC failure 1
C12B2 Image processing ASIC failure 2
C12B3 Image processing ASIC failure 3
C12B4 Image processing ASIC failure 4
Cl 2C0 Hard disk recognition error
C12C1 Hard Disk Error 1
C12C2 Hard Disk Error 2
C12C3 Hard Disk Error 3
C12C4 Hard Disk Error 4
C12C5 Hard Disk ErrorS
C12C6 Hard Disk Error 6
C12C7 Hard Disk Error 7
C12C8 Hard Disk Error 8
C12C9 Hard Disk Error 9
C12CA Hard Disk Error A
C12CB Hard disk data transfer error
C12CC Hard disk unformat
C12CF Hard disk specifications error
C12D0 Controller hardware error
C13C8 New Transfer Cleaner Unit reset-ting failure
C13CA New Fusing Unit resetting failure
C13D1 Cyan Imaging Unit EEPROM access error
C1302 Magenta Imaging Unit EEPROM access error
C13D3 Yellow Imaging Unit EEPROM access error
C13D4 Black Imaging Unit EEPROM access error
C13D5 Cyan LPH correction data down-load failure
C13D6 Magenta LPH correction data download failure
C13D7 Yellow LPH correction data download failure
C13D8 Black LPH correction data download failure
C1800 Controller start failure
C3310 CCD clamp/gain adjustment failure
C3331 MSC undefined malfunction occurring
C3332 Scanner Section undefined malfunction
C3333 Engine Section undefined malfunction
C3E00;C3E01;C3E02 NVRAM initialization failure
C3F00 Vendor connection failure
C3FFC ROM contents error upon startup(LPH)
C3FFD ROM contents error upon startup(Scanner)
C3FFE ROM contents error upon startup(PRT)
C3FFF ROM contents error upon startup(MSC)
Aug 14, 2009 | Office Equipment & Supplies
Minolta Copier
The malfunction code is for a Polygon Motor malfunction. The motor that shoots the laser beam across the drum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 15, 2009 | Konica Minolta Office Equipment & Supplies
Malfunction detected C-0096
Code Item
C1240 JBIG0 Error
Cl 241 JBIG1 Error
C1242 JBIG2 Error
C1243 JBIG3 Error
Feb 10, 2009 | Kyocera Office Equipment & Supplies
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
60 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
