Question about Exercise & Fitness
Err1 error message, york aspire treadmill
Treadmill counts down 3-2-1 but then err1 message appears. Ive checked all wires and around the running mat and cant see any loose wires or obstructions. its hardly been used so it cant be much
    Top Expert:
  • 12,223 Answers
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
Clean the sensor, test for open or faulty, tight the connector very well,adjust it, see the diagram attached.
God bless you
Posted on Jan 19, 2013
  • kate courtney Jan 19, 2013
    Hi, many thanks for your input, it all sounds a bit complex for me but I will have a go tomorrow. Many thanks for your time!
SOURCE: Hi, have lost the manual for my treadmill York
Error 7 is a Safety Key Error....
That's the red circular magnetic insert that slots into the front of the console...
The manual says : Simply secure the safety key in place and then
try again..
hope this helps
Posted on Apr 20, 2009
SOURCE: york t500 treadmill model no:LQ6010 showing err07 when turned on
that's the red magnetic circular thingy on the console.
Simply secure the safety key in place and try it again
SOURCE: my life fitness t30 treadmill ''running error''
startup error on life fitness treadmill
Posted on Jan 08, 2010
  • 3 Answers
SOURCE: i have a error reading of l5 or ls not too sure york fitness z16
The L5 message means that there is a problem with the speed setting switches. Some models have one set of speed adjusting stitches on the handlebar and another set on the console. One of them is defective and is causing the problem.
Posted on Feb 03, 2010
SOURCE: york t101 treadmill ls error
York treadmill T101 will not run has a error L5
Posted on Feb 20, 2010
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
Jan 19, 2016 | Exercise & Fitness
How long does it take for someone to help me, on this site.
How fast you get answers depends on many factors. I just picked up your question but have spent time finding and reading the manual. I am by no means a treadmill expert, but my first thought was treadmill belt tension was too loose to keep the movement sensor happy.
Moving the belt manually would be irrelevant as the electronics would not be monitoring to throw up the E1 Error..
The manual tells you to check all these things.
E1
Loss of Feedback Speed Sensor disconnected Check Speed Sensor
Connection
Speed Sensor Misaligned Check Sensor position
Faulty Speed Sensor Replace Speed Sensor
Loose Display Connection Check Display Cable
Connection
Faulty MCB (D2 LED on) Replace MCB
Faulty Drive Motor Replace Drive Motor
If BH Fitness are being no help, I would be asking them to take the machine away or get it fixed on-site.
So does the belt turn when you switch it on? Is the belt centrally aligned when it spins?
Page 35 shows belt adjustment and I would guess tension although not specifically mentioned.
http://www.bhfitnessusa.com/manuals/final/ts2.pdf
Jan 05, 2016 | Bh Fitness TS2 Folding Treadmill
What's the problem of error 1 on my york t520i treadmill that stopped working, I need your help please.
Error 1: Speed sensor error Turn the power switch off and on again to reset the treadmill. If the treadmill returns to normal operation, you may continue to use the treadmill. If treadmill does not return to normal operation, then call the dealer for advice.
ERROR 1 CODE This is a safety feature that can stop the treadmill from functioning. This error can occur because the computer is not receiving the correct information from the speed sensor located near the motor. As a precaution the computer stops the treadmill until it begins to receive the correct feedback. By performing a few simple checks, the error can be cleared quickly and easily, and the treadmill can be ready for use. The treadmill does not move and displays "ERROR 1" Switch off the treadmill at the mains, and then switch it on again. If "ERROR 1" still shows switch off and push the running mat round (1 cycle) using your feet. Then switch back on. If "ERROR 1" still shows, then UNPLUG from the mains and check all of the wire connections made during the assembly. (SEE BOLD PRINT) UNPLUG If the treadmill still does not move, then please contact the helpdesk. Doing this may reset the program error, and the treadmill will be ready to use. This should reset the sensor, and the treadmill will be ready to use. Once the cables have been checked, turn on the treadmill again. This should eradicate the problem. 1. 2. 3. When assembling, there are several cables that need to be connected. It is very common for these cables to look like they are connected when they are in fact not fully connected. Make sure that these cables are connected as tightly as possible. The connections may have come apart whilst assembling the treadmill. here is a link to your treadmill web site http://www.yorkfitness.com.au/uploaded/pdf_71T520i%20Treadmill_5562.pdf
Mar 02, 2015 | York Exercise & Fitness
I have a Sportsart 1050l give's error 1?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
ERR1 Definition: The display board CPU didn't receive the optic sensor signal. • Explanation: After processing by the drive board, the optic sensor signal travels the 16-pin cable to the display board CPU, which determines motor speed. Components involved include the optic sensor, optic sensor wheel, 16-pin cable, drive board, display board, and connections.
ERR1 Condition: Press speed key; walk belt doesn't move; ERR1 appears. 1. Drive Board a) Inspect drive board components for signs of damage, like bulging, burnt or cracked spots. b) Inspect connections to the drive board, including the ribbon cable (at the display and drive boards), drive motor, incline motor, etc. loose connections are a common cause of ERR1. c) Check the drive board lED Turn on the unit. The should be lit. The EMG indicator should light up and then extinguish after the unit powers up. A lingering EMG light indicates drive circuit trouble, but it can also light up if drive board connections to motors and other components aren't secure. d) Test whether the drive board is sending power to the motor. Put the muttimeter to the DC setting. Disconnect the motor M+M- wires from the drive board. Place probes on the drive board M+ M- terminals. Put the treadmill safety key in place; turn on the power; walk on the treadmill so that the ClK lED lights (this preempts the display from detecting no optic sensor signaling and immediately giving you an ERR1 message, thus allowing you to get a power reading); press the speed up key. The meter should show some voltage. If there's no voltage, inspect the ribbon cable and display board. If they appear OK, suspect the drive board. e) Test drive board components for a short. See Components in the Basic Electronics. 2. Ribbon Cable a) Check the ribbon cable and its connections. Link a spare cable from the drive board to the display board, outside the unit. Test the unit. If it works with the spare cable, replace the original cable. b) Or, if you don't have a spare ribbon cable, test ribbon cable continuity. Wrap solder wire around each probe so you can insert probes into the ribbon cable connector, testing one wire at a time for continuity. 3. Display Board a) Press down on the display board ICs. If you have a working unit of the same kind, swap the display board onto this unit. Test. If all works well and no ERR message appears, replace the original display board. a) Reed Switch (Applies to models with magnetic safety keys only.) Put the safety key in place over the reed switch. Put the meter to the 200 Ohm setting. Place probes on both ends of the reed switch. Meter should show 0 Ohm. If the meter doesn't get a reading, replace the reed switch. 4. Treadmill Motor a) Rotate the motor. It should rotate smoothly. Grinding or sticking indicates wear. b) Check the motor brushes. Uneven wear indicates worn brushes. Minimum brush length: 1/2 inch. Turn the brushes around and reinsert them. Rotate the flywheel. If the motor grinds or sticks, put brushes back in their original position. c) Check motor resistance: Turn off unit. Disconnect the motor M+ M- cables from the drive board. Put multimeter setting to Ohms. Place probes into the motor wire M+ M- ends. Normal reading: 1 Ohm. Move the flywheel slightly and take another reading. Take a few readings, moving the flywheel slightly after each. Readings should be consistent. If the meter shows OL at any test point, replace the motor. 5. Transformer a) Put the meter to the AC setting. Place the meter probes on the transformer output wire connectors on the drive board. Turn on the unit. There should be output voltage. If not, replace the transformer. • 11XX/12XX brown-brown: 10.5VAC • 31 XXl32XXl61 XXl62XX white-white: 12.5 VAC • 6005 yellow-yellow: 11.0 VAC If ERR1 is not resolved, see ERR1 with walk belt movement. • • • • ERR1 Condition: Press speed key; walk belt moves; ERR1 appears. 1. Tachometer Wheel Make sure the tachometer wheel: a) Rotates in the middle of the optic sensor. b) Is clean and free of cobwebs and dust. c) Doesn't have broken or bent teeth. d) Is fastened securely on the motor bracket If the wheel has visible damage, replace it. 2. Optic Sensor Make sure that the optic sensor signal is getting to the drive board. a) With power on, turn the drive motor. The CLK indicator (an lED on the drive board) should light. This means that the optic sensor signal is reaching the drive board. If the ClK indicator doesn't light, replace the optic sensor. b) Push the treadmill belt while pushing speed up key. If ERR1 doesn't appear until you stop pushing the belt, and the display speed values increase, then the optic sensor is good. (On units without a ClK indicator, check optic sensor output voltage: (a) put probes on optic sensor output (b) turn the motor (c) if voltage doesn't vary, replace the optic sensor.) 3. Ribbon Cable a) Check the ribbon cable and its connections. Link a spare cable from the drive board to the display board, outside the unit. Test the unit. If it works with the spare cable, replace the original cable. b) Or, if you don't have a spare ribbon cable, test ribbon cable continuity. Wrap solder wire around each probe so you can insert probes into the ribbon cable connector, testing one wire at a time for continuity. 4. Drive Board Check whether drive board components are burnt or cracked. Check component connections. A drive board power component short usually results in a huge burst of power, making the walk belt speed dangerously, before ERR1 appears. If the walk belt moves before ERR1 appears, but not very, very fast, suspect the optic sensor. 5. Treadmill Motor a) Rotate the motor. It should rotate smoothly. Grinding or sticking indicates wear. b) Check motor resistance. Turn off unit. Disconnect the motor M+ M- cables from the drive board. Put multimeter setting to Ohms. Place probes into the motor cable M+ M- ends. Normal reading: 1-2 Ohm. If there's no reading (OL), replace the motor. c) Check the motor brushes. Uneven wear indicates worn brushes. Minimum brush length: 1/2 inch. Turn brushes around and reinsert them; rotate the flywheel by hand. If it rotates worse than before, put brushes back in their original position. d) High amp draw can indicate a bad motor. Other factors would be a worn walk belt and deck. Run unit power through a current meter. Tum on the unit. Normal amp draw at 3 MPH with no load on the walk belt is 1/2 to 1 Amp. 6. Display Board ICs Make sure that IC contacts on the display board are good. Press firmly on the ICs. Make sure you have the latest CPU version. If ERR1 is not resolved, see ERR1 no walk belt movement.
Treadmill Parts for SportsArt Belts Motor Brushes SPORTSMITH net
Sep 15, 2013 | Exercise & Fitness
York treadmill t-801la T780 platinum error code 1
see the comentary ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
the signal is not reaching the display.7099b61f-975c-463c-9361-522952e1c927.gif
Run the software calibration for easy diagnostic and fix it. God bless you
Jul 08, 2013 | Exercise & Fitness
Motor not going on York Optimum 60100 - after a while E 1 appears
Dear Sir:
This is probably a 1) faulty speed sensor or 2)the speed sensor is not plugged in properly. Its also possibly a 3) faulty motor control board or lower board 4) Main motor faulty. . The error codes will differ between makes and models but could be e1.You must test
see my personal TIPS for diagnose and troubleshooting.
See if you can run the software calibration for diagnose and trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a.
Mar 05, 2012 | York Exercise & Fitness
I lost my manual for the York Pacer 3100, where can I download the manual? I also need to replace the running mat but I don't know the part number.
Try this 3 web page:
1) Free. http://fitness.manualsonline.com
2) Pay:www.fitnessrepairparts.com
3) Pay: http://manualsfactory.com
e.cuadra
May 24, 2011 | York Barbell Home Use Fold-Up Treadmill
E1 not ERR1 error appears on the display of diamond t300 york fitness treadmill??
Your problem might be that a magnet has fallen off. Here's an illustrated guide that will make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Jul 04, 2010 | York Yankees Bedding MLB Comforter
I have a error reading of l5 or ls not too sure york fitness z16
Dec 29, 2009 | York Exercise & Fitness
I got a E1 appears on my york 60100 and it's not working at all
the E1 error with yorks typically means that the speed sensor isnt communication correctly with the computer. Here is the series to try and get things communicating again. Turn off and on a couple times. No luck... Turn off and use your feet to rotate the running mat once around. Turn back on. No luck... Turn off and unplug. Check all wires to make sure nothing is unplugged inside or on the machine other than the main power plug. I would also just for good measure unplug and plug all wires I can easily reach and do so with. Once everything is buttoned safely back up plug the machine back in and turn on.
Jun 01, 2009 | York Yankees Bedding MLB Comforter
Exercise & Fitness Logo
207 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
