Question about Car Audio & Video
Looking for Spec's or manual for Hifonics Zeus ZX 4000 200 Watts x 2 Car Audio Amp
I need a manual for my zx4000 200x2 amp?
Posted on Sep 13, 2011
  • 15,935 Answers
CLICK HERE for the user manual you requested.
Thank you for Using FixYa - a Fix Ya rating is appreciated !!
Posted on Jan 26, 2009
How many watts is a hifonics Zeus series z200 100w×2
By your description allegedly 2 x 100watt. So 200w music power.
Nov 19, 2017 | Hifonics Car Audio & Video
Protect light amp
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
would definitely look at getting it repaired. These new amplifiers can't hold water to an old school Zed audio hifonics Zeus.
Jul 31, 2013 | Hifonics XX-Zeus Car Audio Amplifier
Does this amp have dual 2GA inputs-Hifonics XX-ZEUS
Mono amps have single power in so if it is stereo then it should have two.
Apr 25, 2010 | Hifonics XX-Zeus Car Audio Amplifier
Ive got a 5channel zeus z7oo & im hooking up
if i were you i would put the switch to 4ch and the run one sub from ch1-2 bridged and then ch3-4 bridged. I would have to bet this amp is stable only to 4 ohms bridged with so many channels
Mar 19, 2010 | Hifonics Zeus Z700 Car Audio Amplifier
Hifonics zeus z400 red diagnostic light blinks on a bench test ? whats that mean any one know.
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and or a channel or power supply and that is a very small chip on the board know as a op amp. needs to be repaired.
Jan 12, 2010 | Hifonics Zeus Z400 Car Audio Amplifier
I have two zeus 1000 watts amps four rockford fosgate phase 2 15 inch woofers why my protect light keep coming on when i turn up my radio up
The power draw may be eccessive, try placing a capacitor (or a bigger one ) on the lines to the amps.
Message for the expert bobdunhay: You are not allowed to share your address.
Thanks.
Sep 10, 2009 | Hifonics Zeus Z1000D Car Audio Amplifier
I have 3 hifonics zeus Size: 12 inch Impedance: Single 4 Ohms Peak Power Handling: 800 watts RMS Power Handling: 400 watts Sensitivity: 89.9 dB Aluminum Cast Basket American Spider For Reliable Performance...
Hello king3132,
Three 4 ohm subs can be wired parallel for a 1.34 ohm final load or series for a 12 ohm load. If you have the channels of the amp bridged, I hope that the subs are connected in series because the Sony XM-2200GTX is NOT rated for or stable at 1.34 ohms. It's only stable down to 4 ohms.
You definitely will not get the maximum potential of the subs from that amp. They can handle 400 watts RMS each (total 1,200 watts) and the amp is only capable of 500 watts RMS into 4 ohms (less at higher impedance), so each sub could only be getting a maximum of 166.6 watts RMS.
Hope this helps.
Jul 20, 2009 | Digital Audio Car Audio & Video
I HAVE A ZEUS ZS12 350 WATTS AND IT HAS THREE HOOK UPS ON THE BACK HOW DO i HOOK THEM UP
This is a dual coil sub . Go to :
www.colomar.com/Shavano/dvc_spkr_wiring.html
There are several ways to hook up this type of sub. The web site will explain.
Jun 30, 2009 | Hifonics ZS12 12in Zeus Round Version Car...
Make the sub pop and hum and no rca wire are hooked in?
first off nice choice on the amp check ur power and ground connections make sure the main battery to bady ground is good if questionable add a new one cant hurt to have extra grounds from the batt to the body make sure the amp ground is as short as u can make it make sure its grounded to bare metal if any of these dont work u may have a prob inside ur amp
May 06, 2009 | Hifonics XX-Zeus Car Audio Amplifier
XX- ZEUS MONO D- CLASS / 1600 WATTS RMS
It's likely that the amplifier has shorted output transistors. If that's the case, they will have to be replaced. If you have zero experience with electronic repair, you should pay someone to repair it instead of trying to repair it yourself.
Let me know if you have any other questions.
Jul 28, 2008 | Hifonics BX1500D Car Audio Amplifier
Car Audio & Video Logo
195 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
