Question about Canon PIXMA MX330 Office All In One All-In-One InkJet Printer
Error message 5011 for Canon MX330 appears upon powering up -
Error message 5011 for Canon MX330 appears upon powering up Cannot find the answer in the manual (even though it says to check the manual). Extraneous loud grinding noise upon power up also. Nothing is visibly or audibly out of place in the printer. Can you help?
  • quadejay
    quadejay Jan 19, 2013
    Cleaned the encoding slip - no difference
komguy
  • 2306 Answers
SOURCE: Canon MP480- 5011 - Printer Error Has Occurred After Scan/Prt
You need to carefully clean the encoder strip. It's the clear strip behind the carriage that runs all the way from right to left. A damp Q-tip should remove any grease or fingerprints.
Posted on Jul 16, 2009
IB4G2008
  • 3587 Answers
SOURCE: Canon I960 No power
wow...that is unusual...nothing on the panel, nothing with the printheads moving?
that would suggest that the internal control board is blown..
let me check my service manual on that..
Posted on Mar 18, 2008
  • 212 Answers
SOURCE: MP620 making grinding noises
check any paper jam inside the printer
clean compleatly using one brush
Posted on Oct 31, 2009
komguy
  • 2306 Answers
SOURCE: Canon MX7600 error 5100, 5C20
Yes, 5100 means the carriage is not moving back and forth properly or there is grease on the encoder strip behind the carriage assembly. Grease spots make it lose count and slam into the side and grind gears. You need to clean the strip with a Q-tip moist with alcohol, but very carefully, not too much pressure on the strip.
Posted on Dec 13, 2009
  • 385 Answers
SOURCE: When trying to send a
Hey! If the take out the cover that's covering the receiving paper,Look in there and u will see a black lever with a green sticker on it!Make sure its clipped into place by pushing it upwards un till you hear the click sound!Then press ok!!Enjoy! Good Luck!
Posted on Jan 06, 2011
How can I fix an error msg #6A81 on the Pixma mg5320?
Error 6A81 is described here: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#5011
Description
A printer error has occurred.
Resolution
  1. Turn off the machine and unplug the power cord from the power supply.
  2. Plug the machine back in and turn the power on.
    NOTE- If you disconnect the power plug, all the faxes stored in the machine's memory are deleted.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility.
Feb 19, 2016 | Canon PIXMA Office Equipment & Supplies
How to solve canon printer mp280 error code 5011 ?
Was afraid this was the error that led me to toss a printer before. But after a quick search, found the following suggested fix for a potential registry problem. Problem with Windows Canon Mp280 Error 5011
Hope that does it.
Mar 02, 2015 | Canon MP280 All-In-One InkJet Printer
How do i fix error 5011?
The error message indicates that the print head may be stuck. Here are some answers I found for you:
Canon Printer Error 5011
Fix your printer
Dec 31, 2014 | Canon PIXMA MG4120
Canon mp237 error 5011
canon pixma mp 237 macet dikarenakan tdk bs dibuat ngeprint...problemnya dari error code 5011
Jan 15, 2013 | Canon PIXMA MP240 All-In-One InkJet...
I want to scan with canon mx330 without ink in the printer
I have a canon mx330 fax print and scan all in one printer
To scan without ink just hold the back button in after the ink message comes up it should eventually take you to the main menu then you can hit the scan button.
Mar 10, 2012 | Canon PIXMA MX330 Multifunction InkJet...
My canon pixma mx330 color cartridge is half full but it give an error of U163 replace color cartridge. How can I fax without color cartridge.
Please try this solution first, it might resolve your faxing transaction by resolving first the u163 error.
What happened when ink ran out from a refilled cartridge and the printer detected it?
The printer will display an error U162 or U163. All functions of the all-in-one printer will stop and your printer will not work. The next thing you will know is you are in the front of a computer shop and buy a genuine canon cartridge.
But wait, there is still a way to fix this. Reset it again using a different procedure. Reset the detections of reusable cartridge.
1. Turn off your printer an turn it on again
2. After the printer initialize try to copy or print. The error will appear.
3. When the error is displayed on the display panel of the printer, Press and Hold the STOP/RESET button and wait until it self restart.
4. Release the STOP/RESET button the the printer is restarting.
5. Wait for a few seconds and the pending print jobs will commence.
Please rate this answer.
Thanks for using Fixya.
Aug 17, 2010 | Canon PIXMA MX330 Multifunction InkJet...
Canon mx330 Error 5100 Error 5100 Printer error has occured. Turn printer off and then on again. If this doesnt clear the error, see the users guide for more detail.
Cancel printing, turn off the machine. Then clear the jammed paper or protective material that is preventing the FINE cartridge holder from moving, and turn the machine on again. If not remedied, turn off machine, unplug the power cord of the machine from power supply. Plug machine back in and turn power back on. If problem is not resolved, please contact service center. This info is from Advanced Guide Troubleshooting Section under An Error Message is Displayed on the LCD....error code 5100. This is a link to Canon to download Guides.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=18120
Nov 04, 2009 | Canon PIXMA MX330 Multifunction InkJet...
Jul 16, 2009 | Canon Pixma MP480 All-In-One InkJet...
Canon PIXMA MX330 Office All In One All-In-One InkJet Printer Logo
119 people viewed this question
old marine
old marine
