Question about Intel Computers & Internet
System fan cannot be detected in MS 7352 V1.0
When i turn on my system a error appears on the screen "System fan cannot be detected" and suddenly turns off...
  • Intel Master
  • 3,606 Answers
Hello here is the homepage:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3459272&prodTypeId=12454&prodSeriesId=3459270&swLang=13&taskId=135&swEnvOID=1093
The bios is set to give a warning when the system fan is not working or goes dead (in this case it probably isn't detected or has gone out). You should be able to get into your bios and look for items such as "processor fan warning: on/off" "system fan warning: on/off...etc. If you turn the system fan warning to off it will resolve the problem you are having. The fan for the cpu, must be connected to the CPU_FAN connector on the mainboard.
If the problem is still there, replace the fan, and renew the thermal paste, between the cpu and the cooling element.
Clean also the pc out for dust, with compressed air.
BE CAREFULL when you work on the mainboard, and please take antistatic precautions.
Visit also a computer repair shop, if working on the mainboard is unfamiliar to you.
Good luck
Posted on Jan 20, 2013
  • 90 Answers
SOURCE: My Screen is blank and fan continuously runs.
your computer is not posting that is why you do not hear a beep. This can happen for 1 of 10000000 reasons but I would start with checking the RAM then all the other hardware to find a loose connection/dead hardware.
Posted on May 28, 2009
SOURCE: fan not found
Yes the fan was spinning. I found a soulution though. The right connecter did not fit the motherboard so someone rigged it to run but the motherboard did not see it because it was hooked straight to the atx power supply. I just broke the plastic off of where the original fan was plugged in and with the pins still intact I pushed the replacement fan connector down on it and the motherboard found the fan. Sweet Success!!!!
Posted on Sep 23, 2008
coolhandan
  • 102 Answers
SOURCE: The following message appears as soon as I turn PC
There should be a jumper beside your bios batery there should be 3 pins move the jumper to the last 2 pins for 5 seconds and put it back that should do it
Posted on Mar 23, 2009
  • 46 Answers
SOURCE: When I turn on my
First, turn off your computer, disconnect all cables.
Then, find the manual for this particular motherboard - locate in it where the "chassis intruder jumper" is. Then move the plastic jumper from pins 1 and 2 (left) to 2 and 3 (right). Keep them there for 10 seconds, then move the plastic piece back to pins 1 and 2. This should fix the problem.
Hope that helps! :)
Posted on Mar 02, 2011
  • 117 Answers
SOURCE: how can I upgrade the cpu for the ms 7352 V1.0
Check your documentation that came with the motherboard or computer.. Go to the computer web site for more info or call tech support for the computer or motherboard.
Posted on Mar 25, 2012
Intel ms 7352
check your ram slots and the video card try other video card and make sure that you had turned on the printer as well see if the power cord for the printer is plugin i have done that as well was unpluged
Mar 05, 2014 | Computers & Internet
N 1996 ms 7352 driver
ms-7352 ver. 1.0 lan setup download for window xp
Feb 12, 2014 | MSI K9VGM-V Motherboard
My msi ms - 7352 ver :1.0 won't display but wen i plug the power cable on the power supply the cpu fan and power supply fan spin but wen i turn the pc on it doesn't display
Auto power on the mother board means there was not found RAM or VGA adapter. If you herd Beep tones
follow this link to identify the error
https://forum-en.msi.com/faq/article/bios-beep-codes
if not pls check the power supply 4pin connector correctly plugged .
Also need to check the cpu and post error codes by post diagnostic card to identify the eror.
Oct 24, 2013 | Computers & Internet
Unauthorized device has been detected
Error Message: Error 003 Unauthorized Device Has Been Detected
Situation:
System is displaying error message: Error 003 Unauthorized Device Has Been Detected
Information:
This error code indicates the region the system was manufactured for is not compatible with the Wii System Menu update. This incompatibility has made the system unplayable and it cannot be repaired. Nintendo is not able to provide support for these systems.
It has been modified so you will have to buy a new console sorry.
Oct 22, 2012 | Nintendo Wii Console
Received 512 - chassis fan error on HP Compaq dc5100 ff - I replaced the front chassis fan after detecting fan was not working now when I attempt to log into windows - windows screen appears than...
if you download and install tune up 2010, it may fix your registry automatically for you however if it fails to, your operating system will continue to fail to shutdown or keep causing your system to hang at the f5 window which is the one your describing. Device drivers are very well known for causing this error and if you have installed a new device and your computer is not picking up the new device properly, then the computer will not shut down. There are several forms of viruses that cause the system to stay on, power problems may cause the system to crash during a storm and thus damage the computer registry. A system defragmentation, cleanup, along with a registry clean would be the first best ideas.
Jan 12, 2011 | Computers & Internet
if you download and install tune up 2010, it may fix your registry automatically for you however if it fails to, your operating system will continue to fail to shutdown. Device drivers are very well known for causing this error and if you have installed a new device and your computer is not picking up the new device properly, then the computer will not shut down. There are several forms of viruses that cause the system to stay on, power problems may cause the system to crash during a storm and thus damage the computer registry. A system defragmentation, cleanup, along with a registry clean would be the first best ideas.
Jan 12, 2011 | HP Compaq dc5100 Small Form Factor PC...
My camera view finder shows"Check
Good day,
The CHECK DIAG appears in the view finder when the camera's automatic self diagnostic function detects an abnormality.
From here you must first perform error checking on your camera by doing the following:
Press the menu dial.
This will perform the error check on the Digital Signal Processing(DSP) and the Memory Circuits.
When no error is detected OK will appear.
If an error is detected it will be displayed next to DSP or Memory on the screen. Diag Error will also appear.
If Diag Error appears contact your Sony dealer!
What this means is that the camera is doing a routine check or has detected an abnormality with the system.
I hope it is just performing a routine check and there is nothing wrong with your camera!
Best of luck and let me know if this was useful!
Kind regards
Dec 01, 2010 | Sony DSR-500 Mini DV Digital Camcorder
A message says "previous fan
my dell gx 280 fan failure how i solve it'
Nov 23, 2010 | Dell OptiPlex GX280 PC Desktop
HP PC suddenly very slow to boot up - the hp startup page (blue screen which has "esc=boot" etc) stays on for a number of minutes with the fan whirring away before a black screen appears which...
There are a number of reasons that may cause the issue but generally two factors: outdated hardware or poor system maintenance. For hardware part: you can get more RAM, higher CPU etc. For system part: there might be a lot of junk files, caches, errors etc out there, about 80% slow HP issues are caused by this reason, in this case you can rely on http://www.speeduphp.com/ to free detect and fix related issues.
Nov 01, 2008 | Computers & Internet
Computers & Internet Logo
788 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
