Question about Ingersoll Rand Ingersol Rand Diesel Kubota Generator Light Plant Tower
Where do i fing a user maual and data sheet for a Ingersoll Rand G16 3 phase generator?
G 16 3Phase Volts 220/220/380 Rated current Amp. 20,8/20,8/41,7
  • 98 Answers
SOURCE: what is the amt of oil ingersoll-rand 242-5n air compressor need
Fill to the top of fill spout
Posted on Jul 21, 2009
dontbother10
  • 2220 Answers
SOURCE: The oil fill plug broke on my Ingersoll Rand R 242-5n
Remove it and try a NAPA auto parts store. If they can't help I'd try Graingers.
Lou
Posted on Sep 02, 2009
agent91
  • 2100 Answers
SOURCE: wire size
I used to know all this stuff, the hardware store has a gauge guide to show you the correct size, i would guess that 8 would be ok, 10 would probably do it, hope this is right.
Posted on Apr 12, 2010
EMSRSERVICEG
  • 426 Answers
SOURCE: where do i find a
TRY GOOGLE.COM
Posted on Dec 27, 2010
steveo367421
  • 460 Answers
SOURCE: Why does a 7.5 HP Ingersoll Rand motor draw 200 amp at start up?
Sounds like the start capacitor is bad and is not giving it the intial "jump" it needs
Posted on Jan 05, 2015
Can i run a english 3 phase compressor on french 3 phase
I've done it the other way around. A European motor on North American system. The voltage slightly varies and they are 50hz instead of our 60hz. It will just run a little faster/slower than it should. If that is not an issue you should be fine. It probably wouldn't hurt to double check with a qualified electrical contractor in your area.
Nov 11, 2014 | Ingersoll Rand - Rand Type - 30...
My compressor keeps tripping the breaker
breaker needs to be motor rated to allow for the surge on inital startup
Feb 14, 2013 | Ingersoll Rand - Rand Type - 30...
Hello. I have a Ingersoll Rand air compressor, model 2475. I was wondering if there was a way to adjust the pressure gauge to create a larger differential. It is currently running between 150 and 160...
You can adjust almost all pressure switches
Compressors,Well Pumps,etc
Take off the cover & there should be a screw
to do just what you want to do,lower the cut out
pressure
Good idea, as the compressor will last many years
longer, the less it runs
Jun 29, 2011 | Ingersoll Rand - Rand Type - 30...
Where can I find a oweners manual and spec. sheet to download for a ingersoll rand g80 generator ?? I am wanting to wire a outside box with several plug on it.. 120v
Ingersoll Rand generator business was purchased by Doosan so you could probably email them and ask for the manual. Here is their web site:
http://www.doosanportablepower.com/americas/Pages/home.aspx
Here is the generator info
http://www.doosanportablepower.com/americas/products/generators/Pages/PowerSource%20G80.aspx
good luck
Mar 06, 2011 | Electrical Supplies
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
I have a new ingersol rand 80 gal 7.5hp air compressor 230volt single phase and was wondering what size breaker it needs to be put on
Your owners manual spec sheet should give you that answer. However since that unit at max loads should pull 32 to 35 amps I recommend 1.5 times max amps. So approximately a 50 amp breaker. This all based on standard wire size and length of wire run. Also when checking your voltage at load you should be showing 235 to 240 volts.
Jan 09, 2011 | Ingersoll Rand - Rand Type - 30...
Ingersoll-Rand G25 generator had been operating normally. Output stopped today with generator running and 120/240V breaker closed. Continuity test shows a short between ground/neutral and A phase with...
A ground to neutral short should not stop the machine and may be how the breaker panel was wired. Single phase 240 volt power just has two hot lines and the neutral just center taps the transformer winding supplying the 240 volts. The twin breakers that supply this voltage, should both trip even if only one line has a short on it. Check the resistance of L1 and L2 lines to neutral that feed the motor with the breakers off. Each should read nearly equal resistance which usually is only a few ohms when correct. Make sure the motor turns freely by hand as a locked compressor can certainly pop the breakers. If the compressor appears locked, remove the cylinder head(s) and try to turn again. If still locked, one of the connecting rods may have broken in the crankcase. The other problem could be a broken valve assembly in a head. If the motor has a capacitor start and/or run capacitor, it can cause a breaker trip because the motor cannot start with a defective capacitor. Hope some of this helps!
Jun 14, 2010 | Ingersoll Power Force By Rand PF235 Touch...
I wish to rewire a single phase electric motor with compositor's that is currently setup for 230 VAC to 115 VAC. The motor is a Ingersoll-Rand Air Compressor motor with the following nomenclacher. Single...
The motor itself should have a sticker which describes the wiring for 115. It is a small change involving a single wire moving from one pole to another inside the motor starter cap (the bump on the motor itself).
Aug 26, 2009 | Air Tools & Compressors
Ingersoll Rand Ingersol Rand Diesel Kubota Generator Light Plant Tower Logo
23 people viewed this question
Top Ingersoll Rand Electrical Supplies Experts
cwradio73
Tom Chichester
Rhonda Webster
Rhonda Webster
Are you an Ingersoll Rand Electrical Supply Expert? Answer questions, earn points and help others
