Question about Canon C3380i Color Copier
Canon irc 3380 error code e00990-0000 - Canon C3380i Color Copier
5 Suggested Answers
canontech
  • 1219 Answers
SOURCE: Canon iRC 3380i error code E00025-002...help
Service Bulletin
Issued by Canon Europa N.V. Copier Color
HARDWARE
Revised:
Addition of the Affected Machines
Hopper Assembly
Subject:
Measures against E025 error due to toner leak
Detail:
<Symptom>
The toner leaking from the toner cartridge flows onto the inside toner sensor (PS3/PS4/PS5/PS6), causing erroneous
detection and E025 error (Error in the toner motor).
Model:
iRC2380i
iRC2880
iRC2880i
iRC3080
iRC3080i
iRC3380
iRC3380i
iRC3580
iRC3580i
Ref No.:
iRC3380-023 Rev. 2
(F2-T01-NO1-10097-03)
Date:
January, 2009
cartridge, the toner in the supply route between the toner cartridge and the
hopper may leak between the gap between the toner cartridge case and the holder of the machine.
<Factory Measures>
The gap between the toner cartridge case and the holder of the machine is covered with the plastic sheet and the shape
of the front unit cable guide on the toner sensor is changed to prevent the toner from flowing onto the toner sensor.
P-1 Position where the toner cartridge is installed
nside and replace the front unit cable guide into its new type.
Points to Note About Service Work:
When the front unit cable guide is replaced, implement periodic cleaning (every year) for the area around the photo
sensor (PS3/PS4/PS5/PS6).
For the affected machines or later, implement periodic cleaning (every two years) for the area around the photo
sensor (PS3/PS4/PS5/PS6) and the area of toner leak [1].
Service Parts:
Supply of the new part(s) will follow a normal supply pattern.
P-2 GUIDE, UNIT CABLE, FRONT
[2] Change Point
Parts Number Description Q'ty Interchange
ability Fig No.
Old FC6-9380-000 GUIDE, UNIT CABLE,
FRONT 1->0 N
620
New FC6-9380-010 GUIDE, UNIT CABLE,
FRONT 0->
and later IR C3580 230V EUR : CZS00218 and later
IR C3580I 230V EUR : CZT04670 and later IR C3580 230V : CZU00011 and later
IR C3580I 230V : CZY00752 and later IR C3580I 230V AU : CZZ00857 and later
IR C3080 UL 120V : DBE01554 and later IR C3080I UL 120V : DBF02861 and later
IR C3080 230V EUR : DBM00294 and later IR C3080I 230V EUR : DBN10330 and later
IR C3080 230V : DBT00011 and later IR C3080I 230V : DBU00714 and later
IR C3080I 230V AU : DBV01085 and later IR C2550 UL 120V : DCA03694 and later
IR C2380I 230V EUR : DCF16473 and later IR C2550I 230V : DCK00864 and later
IR C2550I 230V AU : DCL01033 and later
Posted on Jun 15, 2010
  • 37 Answers
SOURCE: CANNON IRC -2880
this code is for a bad OHP sensor, wich detects transprerencies.
Posted on Aug 26, 2009
  • 34 Answers
SOURCE: Describe error code E000732-0001 in canon iRC 3200
communication error. check all cables
Posted on Jan 04, 2011
eason3434
  • 12 Answers
SOURCE: I have a IRC 3380 that I am replacing the fixing unit in. How do I reset the E000003-0001 error code?
press *, press 2 & 8 at the same times then press * , again .it will bring you to service mode ,then press FUNCTION and then press CLEAR then press ERR and press OK ,then reboot the machine .
Posted on Jun 08, 2012
Testimonial: "Thanks for the quick response!!!!"
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Canon irc 4580 service manual and error codes
you need to buy that manual? or please especify the error in your machine
May 01, 2014 | Canon imageRUNNER C3200 Copier
Canon iRC 5185i with the erro code E000007-0201 . i need solution
Belt push-off temporary escape mode error.
Occurs when the belt deviation is not eliminated within 1 minute in the belt push-off temporary escape mode.
Oct 25, 2013 | Canon iRC 5185i
IRC 3380i error code E000001-0003 please help
get into service mode
To get into service mode.....
Press *
Then 2 & 8 together
Then *
then choose COPIER
then choose FUNCTION
then choose CLEAR
then choose ERROR
then press OK
turn power off and on
Sep 03, 2013 | Canon C3380i Color Copier
Jun 08, 2012 | Canon C3380i Color Copier
Canon IRC 2570 IC Error Code is E000012-0002 problem what is the solution
May 22, 2011 | Office Equipment & Supplies
CANNON IRC -2880
Aug 19, 2009 | Canon IMAGERUNNER 2230 Copier
Canon IRC 2880/3380 Scan to Email client
re install the system software , flash the machine, or clear mmi
Nov 07, 2008 | Canon imageRUNNER 2200
Canon C3380i Color Copier Logo
712 people viewed this question
old marine
old marine
