Getting error 5B00 on my iP4700 canon printer. Orange light keeps flashing continuously.
The waste ink counter is full, you need to reset it.
First, inbox me and i will send you the reset software, otherwise you pay. its canon service mode tools v2000
Step 1: enter in service mode in order to used the resetter:
Get your printer's service manual to help you in future:
http://www.gondack.com.ar/media/useruploads/files/ip4700-ssm.pdf
Good Luck!
Testimonial: "Lyton Reid is great!! Very helpful and skillful in his craft!! Best to learn from him!!"
Hi mate, please email me software to fix my printer. It will be such a big help! I've been without a printer for weeks now :-( Your assistance is so greatly appreciated! My email is: [email protected] and my name is Peter. Thank you so so much!!
Can you send me the soft?? my mail is [email protected] , Thanks!!!!!
please email me the soft to [email protected]
Please email me the reset software for my Canon IP4700 to [email protected]
Cheers
SOURCE: My canon ip1880 printer orange light flashing 7 times.
1. Press power button while plug in the power cord – green lamp.
2. While hold the power button press resume button twice – orange blink and return to green.
3. Release the power button, Then the PC will recognize new printer install.
4. You need the software for permanent reset.
5. Run the software and select printer port.
6. Then select Set Destination
7. Click MAIN and PLATEN button to reset waste ink counter to zero.
8. Finally test print by click TEST PATTERN button.
SOURCE: Canon iP4700 with error 6C10
It's probably a waste absorber issue.
A fix from FixYa Support:
1. Start with printer off
2. Press and hold resume Button (triangle in the circle) and click "Power" button. Green led should be on
3. While holding the Power button, release the Resume Button.
4. Without releasing the Power Button, click "Resume" button for two times and release Both Buttons.
5. Click "Resume" for four times then soon click "Power" button, to confirm the selected action (reset counter absorber).
6. Turn off the printer and turn on again
http://www.fixya.com/support/t5998845-error_code_6c10_mean
Hope this helps.
SOURCE: I have a Canon Pixma MX320 and get the error code
Try this
1. Turn off your printer
2. Press and hold the
STOP/RESET button
3. Press and hold Power ON button
4. While
holding the Power ON button, release the STOP/RESET button
5. While
holding still the Power ON button, press twice the STOP/RESET button
6.
Release the Power ON button
7. Wait until it display an "idle"
message. It will take about a minute.
8. When "idle" appear, open
the top cover to expose the cartridges.
9. Lift up the cover for
cartridge holder and take out both the black and color cartridges
10.
Return the cover of cartridge holder and turn off the printer
11.
Return the top cover and turn on the printer again
12. After the
printer initialize, return the cartridges.
1. Press and Hold the
STOP/RESET button and wait until it self restart.
2. Release the
STOP/RESET button the the printer is restarting.
3. Wait for a few
seconds
SOURCE: Check Printer (5B00)
try this -
1) Enter SERVICE MODE By pressing Menu-Scan-Copy-Scan
2) Enter NVRAM by presing <--- or ---> then OK
3) SET ABS-M LEVEL TO 0
4) OK
good luck
SOURCE: Canon iP1800 printer,flashing orange light under the green 'on'
Orange light is flashing 7 times and I get msgs that say cartridge not installed properly and cartridge cannot be recognized. I have refilled my cartridges more than once it worked fine for awhile. This is what Canon said.
Subject: Re: Response from Canon - SWSS Web Escalation (KMM10132386V40822L0KM)
> Dear Mike M:
> Thank you for your reply.
> We appreciate your response with the information for your iP1800
> printer.
> The ink cartridges are not designed to be refilled, and this would
> indicate the cause for the issue you are having. each cartridge
> maintain track of the amount of ink used in order to provide status
> information on the level of the ink in the cartridge. Wen refilling an
> ink cartridge, the status information is not updated, and will cause an
> issue such as this.
> The refilled ink cartridges should be replaced with new Canon ink
> cartridges and the printer will resume printing and working properly.
