Question about Pool & Spa
Dream maker spa x-400 won't shut off keeps heating. I have turned it off and let it tottaly cool down the temp max temp is set to 95 and it never shuts off until it gets to 105 and overheats.
  • Brian Walter Jan 21, 2013
    Mine is reading the tempature correctly on the display. Did yours also display the tempature correctly?
I had the same problem last year, I talked to a spa guy and he stated that the temp sensor was probably covered in bio crud. He also stated that the tub should be cleaned with a hot tub flush. After doing that I have not had a problem with the temp settings.
Posted on Jan 21, 2013
SOURCE: Heater will only heat spa water to luke warm.
the water in my arctic spa hot tub took 2 weeks to get to 102 should it take that long ?
Posted on May 02, 2009
  • 12104 Answers
SOURCE: my dream maker spa does not work. there is
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
Posted on Nov 04, 2009
  • 990 Answers
SOURCE: E04 message on MiniMax NT 400 DV..Help!!
Your EO4 message tells you you have a fan problem. So ether your fan is diying wich you would hear or you have a bad presure sensor in your exaust. A new fan is a little pricey but the sensor is reasonable for heater parts. I can't be sure but I believe it ether screws onto or into your exaust and it just plugs on to your control board. If your sensor is going bad their is a reason and this should be addressed. It should be in your by-pass or your gas pressure. But as far as a new heater, not untill you have water coming from the cabnit. It is sometimes easer to sell new than keep up with new, Good luck let me know how you do.
Posted on Dec 03, 2009
john224
  • 1378 Answers
SOURCE: the heater starts and runs and heats, but on the
Thank you for posting your question here on Fixya.com.
The part you will need is called a thermistor; it is the part that reads water temp and converts it to a digital signal for the board to display. The part number should be 42001-0053S. If you need additional details or troubleshooting tips, try the owner’s manual, here. You should be sure that there is no potential problems with water flow prior to just replacing the part. In extreme cases you could have poor water flow and the water in the heater is way too hot (105) yet the pool is much cooler. Generally you will have other indications this is the problem, such as a lot of banging and popping, like making microwave e popcorn. If that’s not the case, the thermistor is the way to go
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jan 16, 2010
  • 990 Answers
SOURCE: I have a Jandy Lite
This sounds very much like spider webs in the gas orfaces. If you shut the power off and remove the wires to the gas valve then shut the gas down and remove the fed pipe from the gas valve you should be able to pull the burner tray out of the heater. Now if you remove the burners you should be able to remove the brass orfaces connected to the main gas feed pipe. If you use an air hose or a can of compressed air you can blow this out now. Now take the orfaces you removed and clean them with a tooth pick or a small piece of wire. The webs will look like small cotton balls or lint. They don't stop the gas they just slow it or disperse it and keep it from firing clean and evenly.
At this point you can reassemble the tray and install. This should fix your problem.
Posted on Nov 14, 2010
Spa was below temp, now it heats and won't shut off.
Is your spa overheating, heating up past 104 degrees?
If so, you have a contactor (or relay) stuck shut and the spa should go into OH at 108 degrees.
d
If your hot tub is only heating to 104 or what ever temp you have it set at and the motor runs 24 hours a day there are a couple of things you'll want to check.
First, make sure that you do not have the pump set to run 24 hours a day.
Second, you'll want to see if the pump icon is lit up on the control panel. You will want to check to see if the icon is on while the spa is supposed to be resting. During filter cycles the icon will be lit. If you are not in a filter cycle and the pump is on while the icon light is off, you have a stuck contactor (relay). The relays can be found online for less then a couple of dollars.
If you have any more questions feel free to ask.
Feb 23, 2015 | Dream Maker Spas Dream Maker Spa - X500...
How to I increase the temperature to 101 on the drreammaker spa fantasy model?
This may be a little late as you may have already found the answer. But most "Fantasy" spas have "Balboa" control system. They are either a heat control knob, or Up/Down arrows on the spa side control system.
If you have the know & it is all the way turned to max position, and still not hot enough, then you may well have a faulty "Temperature Sensor". Get a replacement from your local DreamMaker dealership. Easy to replace.
Dec 20, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Just filled my dream maker brand new has been filled for a couple of hours but all the temp says is ice do you know what that means
This spa is heated by waste heat from the pump. The manual says it can take up to 20 hours to get to 100F. I assume that is starting from 60F. Keep the cover on and let it run at least a day and you should have 100F+ water temperature.
Mar 01, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Power is on but jets arnt going and pumps not pumping
I was looking for an answer to your question. I have the same problem with my Dream Maker X-400 and it is less than 2 months old. The power is on but the tub is not heating now, its down to like 82 degrees and the pump is not working but it has power. It just stopped yesterday.
Dec 18, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
The power keeps turning off after 10 to 15 min ?
You may have a bad motor. Put a drop of water on the motor just after it shuts down. If it sizzles,you have a bad motor.
Sep 28, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
GFI plug is heating up on spa causing motor to not come on
unless plug is bad u will need to check the motor or heater one of them is pulling high amps heating up plug--oil motor may help--but will need to check the amperage on the motor and or if heater is cause if no amp probe --when system is cooled plug in and turn down heat setting let motor for a while if plug heats up or motor goes off on over heat know problem is with motor or plug-if no change now add heater if plug gets hot and turns off when heater is applied know heater is problem
Jul 28, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
My hot tub had a OH where the temp usually is, then went blank and i wasnt able to reset it. i just replaced the cord and resiliconed around the temp readout
This is probally your temp sensor. Where it is on your system is hard to say. If you have a book on the system it will be in there.
Jul 04, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
347 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
