Question about Air Intake & Fuel Delivery for Jeep Comanche
1986 jeep Comanch 2.5L 5 Sp - won't idle when cold
Will no idle when it is cold.
  • Joe Edelmann Jan 21, 2013
    Will start but not idle when air is below 40 degrees. If I place a heating cable around the throttle body unit and a black box - 2" x 3" - next to the TB, it will start and run longer before stopping. After 10 or so tries, the engine has some heat and the truck will be ok to drive.
  • Joe Edelmann Jan 22, 2013
    The Throttle Body fuel injection does not have a choke. It is operated by electronics.
  • 60 Answers
Sounds like a choke problem to me...
Posted on Jan 22, 2013
1996 Jeep Cherokee 4.0 L has trouble accelerating
often times the engine needs to warm up to normal operating temperature. this varies from makes and models. if you cant wait that long, having it idle for approximately 5 - 10 minutes should at least lessen the acceleration problem, but the longer you wait the better it will be on the engine.
Jun 06, 2013 | 1996 Jeep Cherokee
Won't shift out of park
1st Suggeston mke sure youare pressing brake pedal while trying to shift gears.
2nd Suggestion if this doesn't work check your neutral safety switch on transmision .
Good Luck!!!
Sep 27, 2012 | 1986 Jeep Comanche
2002 jeep grand Cherokee change batt. Now it starts but won't run?
Because you disconnected the battery you lost the long trim value,you will now have to relearn the idle,start the vehicle idle it to 1500 RPM,hold for a minute,idle should stabilize,turn on A/C let it idle,for a minute,now your done,
Aug 19, 2012 | 2002 Jeep Grand Cherokee
1986 Toyota p'up starts, but won't stay running once i left off gas pedal
first i would look for a vacuum leaks get it as close to idle as you can when cold and spray carb cleaner around and also check to see if the egr valve is stuck open this will act as a vacuum leak but not detect as one spraying carb cleaner around carb cleaner with change the engine speed near a vacuum leak
Apr 18, 2012 | 1986 Toyota Pickup 4WD
2001 Jeep Cherokee Country 4.0 Litre Straight 6 , won't idle when warm
IAC (idle air control) can not maintain idle target speed4_14_2012_12_11_46_am.jpg
Apr 11, 2012 | Jeep Cherokee Cars & Trucks
Try to start run for a second if you press the gas it will stay on until you get off the gas
Sounds like a leaky injector, bad idle ,hard to start when warm, bad gas mileage. Or the temp sensor both of them that won't let it run rjght when its cold
Nov 09, 2011 | 1997 Jeep Grand Cherokee
Air Intake & Fuel Delivery for Jeep Comanche Logo
56 people viewed this question
Top Jeep Vehicle Parts & Accessories Experts
CrisO
Thomas Perkins
Thomas Perkins
Andrew Gaitan
Level 1 Expert
Are you a Jeep Vehicle Part and Accessory Expert? Answer questions, earn points and help others
