Honeywell smartfit f7 fault code on acv boiler help
The boiler does not work and is showing an f7 then f5 fault code , the hotwater valve is continually closing even when switched on or off ,it doesnt try to open.
  • nina dobson Jan 19, 2013
    this boiler is electric acv
SOURCE: I have a honeywell smartfit
I had exactly the same problem. F4 code says the control valve has jammed --- but it hadn’t.
I ended up having to swap out the room controller and the base unit (I bought the pair since it was winter and I couldn’t ‘eff’ about)
On investigating (well, you have to don’t you?) I could find no obvious fault but did notice that a large electrolytic capacitor was across the actuator motor.
Since these things work by reversing the supply polarity to the motor to drive the actuator one way and the other it strikes me as strange that a polarity sensitive component, one that must be always connecter positive to positive, is used in the way that it is.
Bottom line, tough luck, mate. Replace the units.
Posted on Jul 31, 2008
  • 70 Answers
SOURCE: Installing CM900 Honeywell into Junior 24 Bosch Combi
What kind of boiler are using is this boiler a on the demand electric or gas? You need low voltage wires. If you get me make and model # of off boiler i can try and find wiring diagram . Tell me a little more about you heat system to. Like baseboard heat or in floor how many zones
Posted on Jan 16, 2009
  • 659 Answers
SOURCE: hot water boiler will not ignite
Check all your limit switches on this unit. One of them is either tripped or bad.
Posted on Apr 07, 2009
SOURCE: aeg fault codes
aeg santo fridge/ freezer
The fridge part of my appliance is not getting cold please help
Posted on Aug 05, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I have a Honeywell Thermostat CM67NG The flame
You may have a broken thermostat wire. Disconnect the wires from the thermostat and please note what colors are hooked to which terminals. Cross the R and W wires and see if your heating system turns on. If it does not, you have a broken wire or bad connection at the heating system. If it does start, you have a bad thermostat or bad connection at the thermostat.
Posted on Nov 30, 2009
My Smartfit room unit is showing no fault codes but boiler wont cut in I have no power at PL in control box or at L on boiler
Boiler make and model????
To which control box do you refer? The system junction box? Boiler junction box?
No power at L (line?) on boiler (and this is why the make and model is important) means boiler should show no signs of life at all, but then it's boiler specific, some have 3 wire power (L,N,E), others have an extra terminal called something like SL.
Jan 21, 2013 | Heating & Cooling
Fault code F5 & P10 on Ferroli opimax he 31c boiler
my air cond runs for 20 minutes than shows f5 and shut down compressor
Dec 02, 2010 | Heating & Cooling
Ferolli HE 31C fires up fine, hotwater works, but ...
diverter valve fault most likely. when you call for central heating do you get 3 swiggley lines coming off radiator symbol in the boiler display if you do and not getting central heating then definitely diverter fault
May 20, 2010 | Quasar HQ2051TH Air Conditioner
HEATING PROBLEM
have checked the pump is working ,is the pressure right on the boiler is there air in the pump or air in the rads?
May 11, 2010 | Heating & Cooling
Honeywell smartfit controller not adjustable
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 10, 2010 | Honeywell Heating & Cooling
I have a honeywell smartfit but it keeps coming up with a F4 error
Jul 30, 2008 | Honeywell Heating & Cooling
My central heating system comprises a worcester bosch system boiler and honeywell smartfit controls. The problem I am having is that the central heating doesn't seem to knock off at the preset temperature...
You could possibly have an ignition problem. The controller will go into a lock-out condition if flame is not established. Turning the temperature control down and then back up may be serving to reset the control system so it tries again.
May 21, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
129 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
