Question about AOC Monitor
I am trying to connect my ps3 500 gb to my AOC monitor, i tried pressing and holding the ps3, i tried changing inputs etc, it still reads as "no signal"... help, i've tried everything!!!!
I have a new slimline ps3, i'm trying to connect it to my AOC monitor via HDMI, it keeps reading as "no signal" i've tried nearly everything, still not working.
SOURCE: AOC LM729 17" LCD Monitor Screen goes black
first take off the speakers. you'll see the cable for the speaker. in this slot u can put a screwdriver an pulloff the silver front carefully. then you will see the screws at the top and the buttom. but its better to take off the stand before removing the front. there are 4 screws behind a cover right near the stand. without removing the stand u wont be able to remove the display/electronic
Posted on Jun 11, 2008
SOURCE: Input not supported
1. Restart the computer.
2. When the computer begins to reboot, press the F8 key repeatedly in one second intervals until the "Windows Advanced Options" appears.
3. Select "Enable VGA Mode" and press ENTER.
4. Select your operating system from the list and press ENTER
5. Follow your normal log on procedure.
6. RIGHT CLICK with mouse anywhere on your desktop.
7. Select PROPERTIES.
8. Select SETTINGS then select ADVANCED.
9. Select ADAPTER then select LIST ALL MODES.
10. Refer to your monitor user's manual or Quick Start Guide for the recommended resolution or mode for your monitor.
11. Select OK then APPLY then OK.
12. Depending on your computer setting, you may need to re-start the computer for the changes above to take effect.
Hope its useful!
Posted on Aug 20, 2008
Democritus
  • 120 Answers
SOURCE: hi...my AOC 17" CRT monitor
Change to the lowest settings you can on the other monitor, then connect the 17" CRT. If you can see anything, go to display settings and slowly bring the settings up. If you lose the display, press "n" (there is a dialog box asking if you want to keep the settings, y or n). Most likely it is a refresh rate that is set to high. Try setting this to 60 Hz for starters.
Hope this helps.
Posted on Dec 12, 2008
  • 244 Answers
SOURCE: AOC 917sw 19 inch monitor resolution issue (same as above)
Have you try the following resolution values:
1280 x 768
Usually its the standard for widescreen view
Please don't forget to rate if answer is useful
Posted on Jun 18, 2009
  • 86 Answers
SOURCE: On Screen Display (menu) is Locked
Hi there - I read in another forum to use the left button instead of menu. Give it a try - power off and hold left button while powering on.
I'll cross my fingers for you :)
Posted on Aug 29, 2009
Aoc monitor shows error message while connecting with i ball tv tuner
What resolution is the AOC monitor capable of using?
What is default resolution of the device you are connecting?
If the default is 1080P and the monitor is not 1080P capable then that would be your problem. You could attach to another monitor or HDTV and possibly turn down the resolution then try again.
Feb 05, 2016 | AOC 917Sw 19" LCD Monitor
Osd unlock
To unlock the OSD (onscreen display control), turn off the monitor and then press and hold the Menu button on the monitor. Then press the power button to turn the monitor back on. Do not release the Menu button before pressing the power button. This same step (holding the Menu button and then pressing the power button) enables the OSD lock. The menu button is the top button on the right side of the monitor (on the bezel). The power button is the bottom button of the group. AOC has the documentation for the 2036sa here: http://us.aoc.com/monitor_displays/2036sa . See page 20 of the User's Guide for the OSD lock procedure. The picture of the monitor buttons is on page 19. The guide is available as a PDF on the AOC site. Note: you will need Adobe Reader or a similar program to read the file.
I hope this helps.
Nov 01, 2012 | AOC 2036sa 20"TFT LCD Monitor
When machine is starting that time my Aoc monitor(17") is showing INPUT NOT SUPPORTED and sometimes when i want to play some games this error is showing.can u tell me what is solution of it.
Try changing the resolution of the input device (video game console, computer, etc) to match your monitor's resolution. You can also make sure the frequency matches your location (60 Hz).
May 04, 2011 | Computers & Internet
When I'm trying to change the menu setting of my AOC Led Monier I get a error message saying "OSD Locked", What should I do to resolve this?
http://www.fixya.com/support/r4628438-aoc_monitor_lock_unlock_instructions
1) Press the MENU-button ( ) to activate the OSD window.
2) Press or to navigate through the functions. Once the desired function is highlighted, press the MENU-button to
activate sub-menu . Once the desired function is highlighted, press MENU-button to activate it.
3) Press or to change the settings of the selected function. Press or to select another function in sub-menu .
Press AUTO( ) to exit . If you want to adjust any other function, repeat steps 2-3.
4) OSD Lock Function: To lock the OSD, press and hold the MENU button while the monitor is off and then press power
button to turn the monitor on. To un-lock the OSD - press and hold the MENU button while the monitor is off and then
press power button to turn the monitor on.
5) Eco Mode hot key ( ) : Press the Eco key continuously to select the Eco mode of brightness when there is no OSD (
Eco mode hot key may not be available in all models).
6) Volume adjustment hot key : When there is no OSD , press Volume ( ) to active volume adjustment bar, press or
to adjust volume ( Only for the models with speakers).
http://www.retrevo.com/support/AOC-917SW-Monitors-manual/id/23449ag008/t/2/
Mar 23, 2011 | AOC 912Vwa-1 19" Monitor
My monitor is of AOC " e2043Fsk " . When I try
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Jan 03, 2011 | ASUS Computers & Internet
My AOC monitor lcd locked so im trying to unlock
If your AOC Monitor's OSD lock
press and hold the Menubutton(for 10sec) while the monitor is off
then press power button to turn the monitor on.
please let me know if doesnt help.
Jun 28, 2010 | Computers & Internet
My Monitor is flickering. I changed the monitor twice (CRT & LCD). But the problem does not solve. I read few forum, they said it is a common problem of magnatic field by TV, Refrigaretor, etc. But now...
if you can borrow a compatible video card to some of your friend replace it if your monitor still flicker then change the psu of your pc, hope this help
Sep 18, 2009 | Computers & Internet
Aug 29, 2009 | AOC 917Sw 19" LCD Monitor
Problem in monitor
1. First cheak the control panel microswitches. if any dry points on the panel ,solder the drypoints.
2. Replaced the microswitches
3. Cheak Control Proccer input voltage DC 5 V, from power section.
4. Changed the 7805 Reguletor. ( near to Control Procer )
Oct 03, 2008 | AOC LM729 17" LCD Monitor
Input not supported
Hope its useful!
Jun 30, 2008 | AOC 193P+ 19" Monitor
Computers & Internet Logo
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
