Question about Tappan TGF363 Gas Kitchen Range
Electric stove top making "beeping" sound
The "beeping" noise is similar to a sound that some trucks or buses make when backing up. The volume increases slowly. It occurred while cleanning the burners, taking out alumminum burner parts....I cannot see/find a seriall number. The house was built in 1965. It has three small and one large burners. The control knobs are on the right side in a separate rectangular panel going along the right side of the range. There is a red light (that burnt out years ago) at the top of the control knobs panel.
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
  • 4 Answers
SOURCE: Stove help
I'd like to know, too. Thank you for your help.
Posted on Aug 26, 2008
scottowa
  • 87 Answers
SOURCE: My oven is not workin
I take it this is an electric stove. The display and controller only are used for the oven operation. Check to make sure you have power coming in on all three contacts. If it's electric, it uses 1/2 of the 220 for the burners and the other for the controller. I assume you have already tried un-pluging it and plugging it back in. There should be a tech sheet in the back of the oven. If there is somebody that can read some simple voltage or has a meter make sure power is getting to the controll board. If it is, your controller is probably bad. Hope this helps.
Scott
Posted on Jan 23, 2009
  • 57 Answers
SOURCE: oven of gas range will not light
Replace lower burner.
Posted on Sep 22, 2009
  • 832 Answers
SOURCE: Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Posted on Sep 23, 2009
My Jenn Air Electric stove is making a clicking noise. When I put my hand on one of the cook top knobs I can actually feel a vibration when the click occurs. What is this?
Gas stove? LP? It is probably the electric spark ignitor. Many times when you clean the stove top water from the sponge gets below. The water droplets (align mysteriously) make the connection between the wires, and the stove thinks it's supposed to be igniting. When the water evaporates, the switch will work fine again & the clicking should only occur when igniting & then backed off.
This happened to me once before.
Nov 21, 2010 | Jenn-Air 4 in. JEC0536ADS Electric Cooktop
I have a Stoves 900EM electric oven and want to change the timer sound. I have lost the manual and can't work out how to do this
If it is like my gas oven, press the - button until it beeps, without pressing the function button first. Then press - again and it will change each time. Stop when it makes a noise you like, or just pick the only audible one, which is the default.
Nov 19, 2010 | Stoves Premier 900EMa Electric Double Oven
My window switch was making a busing noise then
Sound like a short or high resistance caused by an in complete intermittanant connection. Did it buzZ while you were using the raising/lowering the window?
Apr 22, 2010 | 1998 Subaru Impreza
I have electrical noise coming from the stove/oven
I'm assuming you're talking about a cooking stove/oven in the kitchen causing interference with your computer sound. If it is making enough of an arc to cause eletrical interference on your computer, it could be a bad short in the stove/oven and you should get someone to check it out as it could start a fire in your house. One thing you could check first is to make sure all the burners are turned off. You can pull the heating coils out of their plugins on the top of the stove for cleaning purposes. Take each burner out and check for burn marks on the contacts that plug into the sockets. Clean and re-insert the burners back into the sockets pushing them all the way in and then retry the stove to see if the problem still exists.
Nov 05, 2009 | Computers & Internet
No clicking noise when turning the nob..
Most modern gas ranges do have an electric pilot light. This one however does not. Normally you should always get the ignition (clicking noise) whenever you turn the temperature control knob. Provided that the stove is plugged into an electrical source. If you are not, then your ignitor could be out. Replacing it is fairly easy with a difficulty scale of 5/10.
But on to your problem. If you lift the lid on the stove top you will see two holes about halfway between the front and rear burners. Just connect the stove to a gas source and put a match or lighter to this hole. Don't worry, it won't blow up or flare up on you. You will need to do the same thing to the oven. If you open the broiler part of the stove, use a flashlight and look inside. You will see a similar type of gas line. Do the same with a match or lighter.
As with all gas appliances, ALWAYS check your gas lines for leaks using soapy water. If you see bubbles after spraying the solution on, then you have a leak and shouldn't turn the gas on until it's foxed. Use yellow Teflon tape or "pipe dope" on all gas connections.
Sep 30, 2009 | Sears 61301 Gas Kitchen Range
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Beeping Noise & Fuel guage not reading accurately
Could it be your back up sensor going off that is making the sonar sound?
Sep 08, 2008 | 2008 Mercury Mariner Hybrid
Slow heating and control panel clicking
I have a similar problem with my Frigidaire FAM156R1A Air conditioner. The unit is stuck on a temp setting and occasionally makes a beeping sound. Repair tech came out and told me the control panel was broken and that this is a common problem. I wrote more detail here: http://www.epinions.com/content_404700761732
Sep 23, 2007 | Frigidaire PLCF489AC Dual Fuel (Electric...
FRIGIDAIRE GAS RANGE LGLGF388DS
I WOULD TRY UNPLUGGING YOUR APPLIANCE. TURN GAS COCK "OFF" (BY LAW THERE SHOULD BE ONE NO FARTHER THAN 6 FEET FROM YOUR STOVE) PLUG STOVE BACK IN. SEE IF IT MAKES THE SAME NOISES. IF IT DOES, CALL THE GAS COMPANY TO SEE IF YOU HAVE THE PROPER GAS PRESSURE GOING TO THE APPLIANCE. (SOME GAS COMPANY'S STILL WILL CHECK THIS AT NO CHARGE". NEVER TRY TO REPAIR ANY GAS OR ELECTRICAL APPLIANCES YOURSELF. FIND A LISCENSED APPIANCE REPAIR COMPANY IN YOUR AREA (SEE IF THEY ARE LISTED IN THE BBB AND HOW LONG IN BUISNESS) UN FORTUNATELY, ALL THE NEW APPLIANCES WITH ALL THE NEW "BELLS AND WHISTLES" ARE USELESS AND COSTLY TO REPAIR IN MOST CASES. DONT GET RIPPED OFF MAKE SURE THE REPAIR COMPANY IS CERTIFIED TO WORK ON YOUR MAKE AMD MODEL. Joe_Rex (New Member)
Apr 26, 2007 | Frigidaire FEF329E Gas Kitchen Range
Tappan TGF363 Gas Kitchen Range Logo
302 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
