Question about Canon IR1018J Black and White Copier
When I turn on my IR1018j canon copier if display SYSTEM ERROR E350, anyone can help me plc
Canon Fi19204, 220-240v, 50/60hz, 2.8A
spinal
  • 287 Answers
SOURCE: Error code E000020-0181
Hello Brass, This error code means that the yellow drum/developer unit has failed. Your machine has 4 drums, cyan,magenta,yellow and black. At best they are good for about 40,000 copies. You can order one online and it is fairly simple to replace. Let me know if I can help further.
Posted on Jan 05, 2008
Cogz
  • 1326 Answers
SOURCE: HOW TO CLEAR ERROR E350-0000
Did you recently clear RCON and tried to due a CCD adjust? The problem could be the that the left side glass retainer changed or mared or has a doc feeder been added or removed. There is a bar code on the under side of it. The part number for the 1000/3100 is FF5-4662-020, the 2400 FF5-8802-000
Posted on Feb 11, 2008
  • 18 Answers
SOURCE: ir 2000, system error E000
The main thermistor reading does not reach 40°C 14 sec after the fixing
heater goes ON. (fixing low temperature error)
If E000 is indicated, the RAM on the image processor will
retain the error memory of the fixing assembly after the power switch has
been turned off an then on. Execute the following in service mode, and
turn off and then on the power switch to clear the memory: #7
PRINTER>#4 PRINTER RESET>YES=(*).
Entering service mode: press "aditional function" and after "#(ID)"
Posted on Jul 16, 2008
  • 117 Answers
SOURCE: Canon copier show error code:E100
E100 means the copier is not warming up.Make sure all the wires to the fuser are properly connected, then open and close the front door.you may have to go into the service mode to reset the error code.Good Luck
Posted on Mar 26, 2009
  • 153 Answers
SOURCE: Canon imageRUNNER 2020 alternates between displaying Error Code E019 and saying "Waste Toner Full".
hi you have a waste toner error code, the waste toner is apart of the drum unit in these machines so you will need to order a new drum unit for it.
easiest way to fix the problem.
Canon Tech
Posted on Jun 01, 2009
Message says SYSTEM ERROR E100
This error is related with the laser unit. Disassemble that unit and clean the internal mirrows, if problem persist replace the laser unit
Apr 16, 2014 | Canon IR1018J Black and White Copier
Download driver free
http://lmgtfy.com/?q=Canon+IR1018J+driver
Nov 15, 2013 | Canon IR1018J Black and White Copier
SYSTEM ERROR E100 on canon IR1018
Main cause The laser driver/BD PCB is faulty (laser activation failure, BD
detection fault). The DC controller PCB is faulty. The image
processor PCB is faultly.
or drum is faulty.
Oct 20, 2012 | Canon IR1018J Black and White Copier
We can not enter Canon ir1018j , cause none knows the password for it . Is there any way to have it work.
You can reset it in service mode...
Procedure:
Press the Additional functions
key, 2key, 8key, Additional functions
key sequentially.
Choose:
#CLEAR > PWD and press OK
Turn the printer off and back on.
If this doesn't do the trick under clear choose ALL and ok. After clear all you will loose all data inside!
Hope that helps!
Sep 14, 2011 | Canon IR1018J Black and White Copier
CANON ERROR CODE IR1018J
Pls do the following :-
Press and hold #'s 1 and 9 and turn the machine On.
If the same message on LCD, pls call service center.
They will upgrade the firmware of the main controller of the machine using Service Support Tool which is available only in Canon.
Jul 26, 2011 | Office Equipment & Supplies
I have system error E100 on my canon iR1018J
You have laser related error, probablly because dc controller or laser unit.
May 13, 2010 | Canon imageRUNNER 1023iF Black and White...
ERROR ON iR1018J CANON COPIER
good morning i have one problem whit my copier machine IR 1018j
the copier display error system 247 .
anyone can help me?
Sep 18, 2007 | Office Equipment & Supplies
Clc 1150 error 350
Normally only the canon service center will tel you what the error codes means. Suggest you call them .
May 18, 2007 | Canon CLC 1150 Color Copier
Canon IR1018J Black and White Copier Logo
old marine
old marine
