Kenmore 22812 Bagged Canister Vacuum
Problem for Kenmore 22812 Bagged Canister Vacuum
Brush is not turning
By anthony_char on Jan 26, 2009
There is suction, but the brush is not turning. The belt is not broken, but I don't what else to do.
Same Problem
Feb 25, 2009
-   I think this is a common problem. I love these vacs but the two I have had BOTH have done this. Whether it be at the handle that locks into the wand or the wand that locks into the powerhead, over time from the quick release of either one I think prevents these vacuums from lasting. I've never been able to get more than three years out of them. They work fine other than these two items I mentioned. I don't repair vacuums but was wondering is it easy to fix this yourself? -   mark40511
Best Solution
posted on Jan 26, 2009
Very Helpful)
reddevil6
Rank: Guru  Kenmore Expert
Rating: 88%, 1782 votes
You may not have power to the power head. Check the plug at the neck of the power head, also the wand connections to make sure they aren't burnt. Most of these powerheads also have a circuit breaker on the top of it, press it to see if it will re-set. At the end of the hose handle, there is a female plug where the wand plugs into, push it ans see if it will move inward or not. If it does, then it has broken loose inside of the handle and isn't allowing a connection to the wand. The switch on the hose handle may be bad. The power head motor could be bad. These are the most common problems when the power head won't run.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Kenmore 22812 Bagged Canister
Questions and Unsolved Problems for Kenmore 22812 Bagged Canister
Do you recommend Kenmore 22812 Bagged Canister Vacuum?
Answer
Answer
The motor made a highpitched whining sound and died.
Answer
How do you dissassemble the powerhead on a Kenmore Progessive canister vacuum in order to replace... (More)
Answer
I need to install part #PHP-236/C45ECUE. This is the connector in the top of the wand that connects... (More)
Answer
kenmore upright vacuum model 116.35923500. not rotating when on. Easy way to clean without taking... (More)
Answer
I had a bad connection between the Wire Harness on the handle and the Terminal Cover on the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Vacuums Experts
Top Vacuum Repairmen
(502) 348-4900
Authorized Dyson and Miele Service center. Work...
VACUUM SOLUTIONS
(877) 822-8227
When you browse our large selection by vacuum...
Vacuum Cleaner Shop
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
