Question about Econoline Fuel Injection Pressure Regulator for 2000 Ford E-350
Were is the fuse for break light - Econoline Fuel Injection Pressure Regulator for 2000 Ford E-350
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 84 Answers
In the fuse box usually located on the right hand side compartment.
Posted on Jan 06, 2014
Break lights will not turn off. Cruise control has failed.
Check your brake light switch on your brake pedal.
May 26, 2017 | Cars & Trucks
Which fuse is for the Brake Lights on a 98 Mercury Mountaineer. It is NOT listed on the Diagram fir the Interior Fuse Box !!
They're part of the turn light fuse. Replace the turn signal switch. All exterior lights run threw it, except the high mount brake light.
Jul 21, 2015 | Mercury Cars & Trucks
How do I replace my brake light fuse?
The break light have a fuse in the fuse box. If this blows then both break lights will go out. Its usually under the hood in the fuse box or its in the panel on the right or left inside where the front doors close. Some cars have a fuse box under the steering column. If this is not the problem then it may be a break light switch. These are located just up the break petal. Its a switch that gets released when the break is pushed with your foot.
Jul 16, 2014 | 2005 Chrysler Sebring Sedan
Where is the break light switch
what amp are the fusees u are using for the break lights and have u checked all wires for the break lights
Apr 16, 2012 | 1997 Jeep Grand Cherokee
Brake lights out
Hello
If your break lights are out, most likely it is not a bulb, because chances are slim that both would go out. And most likely it is not the connections where the break lights are because again, chances slim that both would go out same time. So, this brings us to fuse panel or the break relay. So, look in your owners manual it should tell you were your fuse panel is and what fuse is for the break lights. Most likely it would say break lights on the inside cover of the fuse box to tell you which fuse it is. Then if it is blown, you need to replace it with same amp fuse. I hope this helps, but I am pretty sure it is just a fuse. Thanks Mike
Sep 17, 2011 | 1991 Toyota Camry
My break lights dont go on but trunk breaks light goes on my fuses are good can you tell me what else to do ,one break light was gojng out i would tap it and it would go on so i replaced it but when i took...
i do not know about the camry but my truck brake fuse was under the hood, I used a tester,that cam with the fuse kit, til I found the blown fuse. Hope this helped Tim
May 04, 2011 | 1993 Toyota Camry V6
Brake lights not working. Niether stop lamps or overhead brake light bar work. All other rear lights work. Fuses for both lights are OK.
The most common problem for this fix is a New Replacment Brake Light Switch. It is located and mounted to the brake pedal assembly.
Feb 22, 2011 | 2000 Chevrolet Blazer
My flasher work but brake light not work just roof lighting went aply brake
Chk. fuse, emergency flashers, and middle break light, and the other break lights are on seperate curcit (a fuse for each), if fuse is ok than it could be break light switch, witch is located under dash on steering colume and works off break peddel arm.
Mar 28, 2009 | 1998 Chevrolet Blazer
Break lights not working
try changing one of the buls and see if that one then works
Feb 10, 2009 | Hyundai Motor 2002 Elantra
2001 ford explorer break lights
there will be a fuse for the brake lights.if the fuse is not listed start checking all fuses one at a time.if you do not find a blown fuse remove brake light bulbs and see if the elements are broken in the bulbs.
Nov 01, 2008 | 2001 Ford Explorer
Econoline Fuel Injection Pressure Regulator for 2000 Ford E-350 Logo
48 people viewed this question
Top Motorcraft Vehicle Parts & Accessories Experts
Bill Boyd
Todd Arndt
Todd Arndt
Jim Beaty
Jim Beaty
Level 1 Expert
Are you a Motorcraft Vehicle Part and Accessory Expert? Answer questions, earn points and help others
