Question about LG WM-1832C Front Load Washer
How do I make my washer ready for moving? I have an WM 1832 CW
    President:
  • LG Master
  • 2,651 Answers
You should ( ifyou have, reinstalla the origianl shipping brackets) thiswill preventthe machine from bouncingaround internally
Posted on Jan 26, 2009
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: How do I make my WM 1832 CW washer ready to move?
It is best to re-install the four shipping bolts in the back of the machine during the move. If you don't have them, contact a dealer. Please don't rate, as anything but a Fix-Ya lowers my score. Thanks.
How do I open a lock LG WM 1832 CW front end washing machine with water and clothes inside?
First you will need to get the water out and really the only way to do that if the unit won't drain it is to open the filter to get the water out and besides that, there is probably a blockage at the filter that is preventing it from draining in the first place. You will need a lot of towels handy or a wet/dry vac at the ready!
Nov 28, 2012 | Washing Machines
Washing machine WM 2077 CW
Yup. It's definitely a LG. Amazing. What's wrong with it?
Sep 27, 2011 | LG WM-2277HW Front Load Washer
Can the lg washers wm 1832 cw handle a twin sized comforter?
It depends on the thickness,content and weight of the comforter.
If you have to stuff it in, don't wash it in your machine..take it to a laundromat.
Or if it is down filled, take it to a dry cleaner.
If it is a cotton filled quilt it will get very heavy when wet and may damage your machine, so I would take one of those to the laundromat as well.
If it is a light weight polyester-filled comforter, twin size and fits easily in your machine with out stuffing it in, it is probably okay.
Dec 20, 2010 | LG Washing Machines
Need link for manual for LG washer WM 1812 CW
You could download the manual from ;-
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WM1812CW-_E
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 30, 2009 | LG WM-1832C Front Load Washer
LG WM-1832 C
the spin tub
or the entire tub itself?
if its the spin tub inside, it would be caused by serious issues
the whole tub is just a replacement of the suspention. access is through the rear.
May 28, 2009 | LG WM-1832C Front Load Washer
Machine will not discharge water
Any error codes? Pumps out OK?
Sounds to me as if the cold water inlet screen is plugged up, preventing rinse water from entering machine. Turn off the cold water to the machine and remove the cold water supply hose. Check the screen inside where the hose came off the machine. Run some water out the hose into the drain or a bucket before reconnecting to machine. Let me know if you still have problems.
Apr 19, 2009 | LG WM-1832C Front Load Washer
LG wm -1832c front loader making noise
when you take the panels off you will see that the barrel is suspended by springs on top and fake struts on the bottom. be careful when removing the panels. if the barrel is leaning forward it's the front struts, if it's tilting upward it's the rear. and be careful how much you load in a front loader
Feb 17, 2009 | LG WM-1832C Front Load Washer
Jan 26, 2009 | LG WM-1832C Front Load Washer
WM1832 CW washer with UE error
You should have access to the sides of the drum. Attatch foam to the either the drum or he outside casing.
The problem is caused by the drum moving too much (because of the defective dampers).
This is a cheaper fix than replacement dampers.
Jan 03, 2009 | LG WM-1832C Front Load Washer
LG WM-1832C Front Load Washer Logo
107 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
