Question about Olympus E-450 Digital Camera with 14-42mm lens
Problems trying to press the shot button - Olympus E-450 Digital Camera with 14-42mm lens
    Genius:
  • 1,019 Answers
The internal contacts are worn or damaged that will require repair.
Posted on Jan 26, 2013
I seem to not be able to figure out the button sequence for programming the shots.
Try pressing and holding the button until the quantity is what you want it to be. Then try it again with just the normal short press to start. If it brews the same quantity as the first one then it is now programmed.
Jun 20, 2015 | Coffee Makers & Espresso Machines
My fx 200ri shows E1 & didnt respond
plese read your owner manual for to fix the error codes. God bless you
If you have a more serious digital camera problem and the camera gives you an error message, check your user guide and this list of camera error guides to try to fix the problem. Good luck with your efforts to troubleshoot camera problems!
Another trick to try clearing the lens error message is to press the power button at the same time you press the shutter button. This is a long shot, but it does work on occasion
Nov 08, 2013 | Elinchrom Cameras
I am having problems with my PS D7360. Error code 0xc18a0306 keeps coming up. I have tried the pineworks suggestion but it did not work. The printer has been sitting for a while.
Found this here it's worth a shot. http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-and/Ink-System-Failure-C6180-error-0xc18a0306/td-p/161866
1. press * and # to enter a secret support menu.
2. Enter code 123
3. Press Right button until "System Config Menu". Press OK.
4. Hardware Failure Status. Press OK
5. Press OK to Clear.
6. Cancel
7. Press Right button to Ink Initialization Status. Press OK
8. Cancel and Cancel to the secret support main menu.
9. Press Right button until "Print Tests Menu". Press OK.
10. Nozzle Test. Press OK
11. Wait until the print test is finish.
12. Press Cancel and Candel until the error 0×00000000 appear and then power off.
13. Power On again. The error disappear.
May 28, 2011 | HP Photosmart D7360 All-In-One InkJet...
How do I shorten the shutter speed.
Shutter lag is one (of the many) problems with compact point&shoot cameras, not seen in bulkier (costlier, more complicated) dSLRs. You can reduce the lag by pressing the shutter release button halfway to focus and meter beforehand. Keep the button half-pressed while anticipating the key moment, then press the button the rest of the way.
You'll have to release the button and half-press it again if the distance to the subject changes, or it moves to/from light/shadow.
May 13, 2010 | Kodak EASYSHARE M763 Digital Camera
How do I delete Pic from me Cyber Shot ?
1. Press the Review button.
2. Press for previous/next picture/video.
3. Press the Delete button.
4. Follow the screen prompts.
Click on the link below to check delete button
http://www.cameras.co.uk/cameraimages/sony-dsc-s40-back.jpg
Its very easy to do it. Try it!
In case of any help let me know
Mar 21, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
Nikon D200 - problems formatting card
To use the two format buttons:
Press the "trashcan" format button and hold it. Then press the "mode" format button and hold it. Hold for approx 3~4 seconds. The screen will go blank and display "For" and the number of shots taken on the card.
Release both buttons. Then press the "trashcan" again followed by the format button. The screen will go back to normal, except the number of shots indicator, it will display "For". In a few seconds, your card will be formatted.
Although this may not solve your problem, you may have bad CF Card.
This is normal. Happens all the time.
Try another card. It should format fine. If it doesnt, take your camera to an authorized dealer/repair shop for maint.
Jun 27, 2009 | Nikon D200 Digital Camera
Canon EOS 350 timer problems
On the back of the camera there is a small button just to the right of the top of the LCD which has what looks like a little clock. Pressing this button will take you through the 3 modes of operation which are:
Single shot, multiple shots and timer. Watch the LCD panel and you should see the icon change when you press the button. When the single rectangle is showing, that is single shot, when it is multiple staggered rectangles that is multi shot and when you see a little clock that is timer mode. Usually I shoot with multi shot mode.
Mar 20, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Snap shot problems
try pressing the button in your cam maybe the snapshot window will open,
Jun 19, 2008 | HP VGA Webcam
Power key doesn´t work
There must be a problem with your batteries. If you have recently charged your batteries and it happens again, you should try a new set of rechargeable batteries.
You can try conserving charging power usage on camera by turning the flash off so that it doesn't precharge for the next shot.
Jun 04, 2008 | Samsung Digimax i6 PMP Digital Camera
DSC-F707 Shut Off
May I suggest you to do or have done following actions: Use a philipps size 0 screwdriver and open your camera body. Then look at all the flat cables, try and disconnect them thoroughly, rub them a little bit and reconnect them. Maybe if you have another digicam, it's a good idea to take pics of how the flat cables are connected and stacked, for easy re-assembly. All your problems sound like bad contacts. Maybe dust or corrosion... I bet your 707 can find a new youth!
Sep 12, 2005 | Sony Cyber-Shot DSC-F707 Digital Camera
Olympus E-450 Digital Camera with 14-42mm lens Logo
21 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
