Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Pull start on my wild thing keeps jamming
Saw is almost new pull cord gets wraped around spring assem
  • Anonymous Mar 04, 2009
    Any suggestions?
You can not pull the starter rope out to full length. Just short rapid jerks. everyone has this problem
Posted on Mar 01, 2009
How to fix my Tanaka chainsaw rope to recoil back?
replace teh recoil section as there is a problem with the spring or the pulley section holding the cord.
Apr 26, 2015 | Tanaka TCS33EB/14 32 cc Gas Powered 14-in...
I have a wild thing. the rope pull starter is very hard to pull. when i take the spark plug out it is easy to pull. the saw was not used for about 4 years until yesterday. it ran for about 45 minutes fine....
one piston ring has expanded now having no or a very fine gap increasing the compression ratio causing this to happen. When the spark plug is removed it is very easy to pull on the cord in any means. A inspection is due of this engine or a new chain saw is needed
Jun 05, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Saw was running great ,then just stopped and would not start again
Always keep in mind that you need 4 things to make combustion happen: Fuel, Spark, Oxygen (Air), and compression. One or more of these is missing and we need to figure out who is missing the party.
Let’s start with the basics:
Does it have gas? (Fuel)
Is the kill switch on? (Spark)
When you pull the cord slow does it give intermittent firm resistance? (Compression)
Is the air filter clean (Air)
Now you need to look at a few details:
Pull the spark plug out and checked for spark. This requires you to hook the spark plug up and let the plug lean up against the metal part of the head. Pull the cord, should be easy (no compression) and check for spark. Don’t hold plug with fingers as you may get a jolt. If no spark, try a new plug, still no spark check the switch and wiggle it around. Even if you have spark I like to install a new spark plug for this next test. With new plug in, pull at least 10 times, pull the plug and see if it looks wet. If it is wet, it is getting fuel.
Hope this helps.
Apr 01, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
How do I change the pull start cord on a 2 stroke husqvana partner 750 cut off saw
open the 4 bolts. if old one is off, keep turning around the white inside bit against the spring until tight. you will see a hole on the white bit. Aline the hole on the white bit with the hole on the cover.shove your new pull cord in through the hole on the cover and the white thing then tie a knot on the inside of the white thing. then let the white thing go. It should spring around and wind up the cord. Hope this helps...
Nov 23, 2009 | Husqvarna Partner Gas Powered Cut Off Saw...
Drum clutch on a chain saw
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Oct 29, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My recoil inside the pullstart
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so i tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension to retract properly.
Both methods require about 2 turns of pretension to rewind the cord when pulled.
Jun 08, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan wild thing recoil froze up
You may need to replace the recoil assembly, check with poulan for availability.
Sorry I couldn't be of greater assistance.
Apr 17, 2009 | Garden
Broken recoil spring
A new spring comes wound tight enough to be dropped into place in the starter housing (Easiest).
Lou
Mar 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
249 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
