Question about Directed Dei Valet 561r Remote Start/Keyless Entry
Where can i get a wiring diagram on how to install my valet remote car starter in my 1999 Dodge Durango i can't seem to find the wires i need to hook them up to the romote starter
  • Anonymous Feb 18, 2009
    each time i go and hit the break it does not take it off the remote start
  • joseph pacheco Apr 13, 2009
    i bought a 1500hd chevy with a valet car starter it starts the truck no problem the radio and the power windows work but my heater and ac fan does not i think it is wired wrong but i don't have a wiring diagram or a manual on it
Shown me the wiring diagram the valet 561r
Posted on Jul 15, 2009
    President:
  • 676 Answers
Constant 12 volts RED & PINK/BLACK IGNITION SWITCH HARNESS Ignition 12 volts D BLUE IGNITION SWITCH HARNESS Starter YELLOW IGNITION SWITCH HARNESS Dome Light YELLOW (-) AT COURTESY LIGHT UNDER DASH ** Trunk Pin TAN/BLACK (-) AT SWITCH OR CENTRAL TIMER MODULE * Parking Lamp BLACK/YELLOW (+) AT HEADLIGHT SWITCH Lock ORANGE/VIOLET 10 PIN CONN. IN DR #203 Unlock PINK/VIOLET KICK OR CTM * Tach Signal BLACK/GRAY AT IGNITION COIL OR PCM * where can i get a - tab_rs.gif Ignition #2 BLACK/ORANGE IGNITION SWITCH HARNESS Ignition #3 D GREEN/RED ** IGNITION SWITCH HARNESS Accessory BLACK/WHITE IGNITION SWITCH HARNESS Neutral Safety BLACK/WHITE (-) AT SWITCH ON TRANSMISSION OR PCM * Brake Light WHITE/TAN (+) AT SWITCH ABOVE BRAKE PEDEL Reverse Light VIOLET/BLACK (+) AT SWITCH ON TRANSMISSION Rear Defrost N/A TIMER BUILT INTO SWITCH
Hope this helps
Posted on May 05, 2009
    Scholar:
  • 116 Answers
I can't post the wire instructions. It says too much text. Give me e-mail address so I can e-mail it to you. I am aving it for you. E-Mail me larry@cybersoundsaudio.com and I will be happy to send it.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
Is there another way to program a remote start remote, The way its suppose to work doesnt.:door open, ACC on, push valet then again and hold. I think the door is not hooked up to read open.
563T Your Valet Alarm W/Remote Car Starter - Dr.Detail
www.drdetailshop.com > MAIN > YOUR VALET
Featuring: Viper, Hornet, Directed Amps, Viper Audio, Compx Subs, Your Valet ... 563TYour Valet Alarm With Remote ... A Free Wiring diagram, Installation parts
Sep 24, 2015 | Televison & Video
Need diagram schematics for front wiring harness
hi, you've had your question answered.....what more do you need to know ?
Dec 07, 2014 | 1999 Dodge Durango
1999 Durango
try buuldog manufacturer on line help ,possibly needs programming via sequence on remote button
Jan 12, 2014 | DLX 500 Remote Car Starter
Instructions on how to remove REMOTE STARTER on Dodge Durango
look in owners manual for how to activate valet mode.
Mar 23, 2013 | 2005 Dodge Durango
Where does the orange armed wire hook up at on my 2001 dodge durango
The orange wire applys a negative ground output only while the system is armed (when you press the lock button), the wire will then go dead when you press unlock. The orange wire can be used to enable a starter kill relay if desired. If your Durango has the factory immobiliser chip in the key then a starter kill relay would be redundant and not required. So it is only an option.
Mar 17, 2010 | DEI Valet Keyless Entry System
Need a wiring Diagram for a 1999 Dodge Durango so i can install a remote start system. Or what colors I need to look for.
Most auto parts stores such and advance auto parts and autozone sell repair manuals. I prefer the Haynes manuel wich has the wireing diagrams printed in the back of the book and acuratley tell each color code
Aug 03, 2009 | 1999 Dodge Durango
I have a 1999 Dodge durango and the alarm is stuck in activate mode, the hand held remote won't shut it off, I can't start my car. Help! I have unhooked the battery....I have looked for a reset...
TRY LOCKING ALL DOORS,THEN UNLOCK PASSENGER SIDE FRONT DOOR WITH KEY..THIS SHOULD DISARM SYSTEM..IF NOT,REMOVE TRIM PLATES AT LF DOOR AND LOOK FOR ANY BROKEN WIRES UNDER TRIM AND CARPET..I HOPE THIS HELPS
Aug 01, 2009 | 1999 Dodge Durango
Trying to install a valet 561r in my 2000 dodge ram 1500 looking for good wiring diagram
http://www.the12volt.com/installbay/file.asp?ID=536
here is a link to the wiring diagram...
Jan 04, 2009 | Directed Dei Valet 561r Remote...
1999 Dodge Durango Starter Location
trace the big wire from the positive terminal of your battery to the starter,
that big wire is directly connected to the solenoid of your starter.
tnx 4 using fixya,
drcool
Sep 29, 2008 | 1999 Dodge Durango
Directed Dei Valet 561r Remote Start/Keyless Entry Logo
554 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Tygh Duval
Tygh Duval
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
