Question about DeLonghi EC155 Espresso Machine
Steam instead of water
Steam is leaking out instead of the water
My Cuisinart EM-100 Espresso Machine leaks water from the bottom.
Thanks Joe received ur gasket in mail installed it in 10 minutes and no more leak! The old was caked up above and below.
Dec 03, 2012 | Cuisinart EM-200 Espresso Machine
Steam iron dose not function well the water leaks out while ironing on steam setting
The problem you're having is often cased by a calcium and mineral build up, due to the tap water you're using. To solve the problem, if it's not to late. Do the following:
Empty any water remaining in the iron. Mix a 50/50 solution of White Distilled Vinegar and Bottled Distilled Water (enough to fill the iron's water tater holder).
Pour the solution into the tank, plug the iron in and turn it to steam. Once it starts to steam, turn the iron OFF, unplug it and allow it sit face down on a flat surface, covered by a towel. Allow it to soak over night. In the morning, empty the prepared solution and refill with just the Bottled Distilled Water. Plug the iron in and turn it to steam. Allow it to steam for 30 minutes. This will flush any of the solution's residue from the iron. Any remaining water should be emptied from the iron.
In the future, I would recommend using Bottled Distilled Water, instead of tap water.
Hope this helped you. Please let me know. Thanks.
Jul 13, 2011 | Heating & Cooling
Good day I have an euro pro iron and it leaks all the time leaving water on washed clothes.also it leaks out of the bottom??
The water may come out at the bottom instead of steam. this is due to insufficient heat produced. So switch on your ironbox and keep it in full temperature using the knob. then the water will be coming out as steam and not as water itself. Try again.
I hope this is useful to you
Thanks
Jun 27, 2010 | Sunbeam Euro Press 4045 Iron
Radiator Leak rust
what part is leaking ?what type of set up do you have? steam or water
make sure you completely drained and refill the system before use. your water level needs to be corrected or this will force water up the lines instead of steam
your radiators need to be pitched so that the steam (water) can return back when the system shuts off
as for the leak. where it is or what part is leaking
heres a manual for your system
http://www.ariston.co.uk/uploads/doc4947b0d538f79.pdf
hope this helps
Dec 24, 2008 | Water Heaters
DeLonghi EC155 Espresso Machine Logo
18 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
